i’ve read all up & down this forum about the p1656 code & everyone seems to have had success replacing the vvti solenoid & filter. i’ve done both, cleared the code & the problem still persists. i’m experiencing a rough, cammed like idle. i did the active test with a scanner the the car idled worse so i know the solenoid works. besides the wires & ecu being my other 2 possible culprits is there anything else that could be causing this code or contributing to it considering i’ve replaced the vvti solenoid. any help is much appreciated🙏🏽🙏🏽.
