DIY smoke tail lights
5.3K views 27 replies 10 participants last post by  SEAN
#1 ·
I know many of you are going for the smoke look for the tail lights, similar to the OEM smoke. I was browsing through dupicolor's websight and noticed MetalCast. It gives chrome pieces some color, in our case some smokeness. I'm going to try soon, but i just wanted to post this for anyone that has plans on painting their tail lights soon.
Here's the Website:
METALCAST
also found on kragen's website if you want to order:
Kragen
Note: you will also need to get adhesion promoter as well since chrome pieces can not be sanded down.
#13 ·
^ No, Duplicolor makes a smoke color for their Metalcast series. It's pretty much a tint type of paint for their smoke color. I played with the smoke color Metacast spray on some beat up Toyota badges, almost gave it that black pearl look, but yeah could of been darker.
#17 ·
where's the how to on cracking those puppies open before the paint? The painting part is easy, picking the colors and stuff. The hard part is getting in those babies. I did my headlights long ago. Easy. Tails, difficult, until I see somebody say otherwise.
#18 ·
http://my.is/forums/f90/taillight-tutorial-pics-202095/
I would give it a 4/10 in terms of difficulty because the dremel is hard to control at first, but after i got used to it.. it was cake. My first tailight took about 2 hours (very cautiously) and the 2nd one took about 30 min to rip open (with experience).
#21 ·
no, it's okay. I just thought that the metal case would show more chrome then it shows in the picture. For some reason i expected similar to Sport Design where the chrome is nice and shiney. But it looks good either way. How many coats did you put on? several thin coats, or just a couple thick coats.
#23 ·
i dont know about the new "smoke" version, but when i did mine about 2 years ago, i expected more of a "black chrome" look to the headlights. In the beginning, it did have a lot of reflectiveness due to the "flakes", but over time, it wore out and you get the color you see now. If you are looking for a transparent paint, this is not the item that you are looking for.
And to answer your question, I applied several thin coats and then a final thick coat.
