Engine- Chassis- Drivetrain- & Brakes
Brand New Synapse Synchronic BOV w/flange,
sealed in box, .
looks exactly like this one I opened...
$190.00 + Shipping & ppal fees.
Drilled-Slotted Rear Rotors - Used.
..with matching set of used EBC brake pads... no need to turn, but couldnt hurt & is cheap. plenty of mileage in both pads and rotors more than half in pads, rotors never been turned.
would rather not bother shipping,... it will be xpensive. Rotors are heavy. ..I will check it out & manage it if buyer pays...
$75.00 + ppal Fee
Like New OEM brake rotors, Painted Black Ft & Rr 2+ weeks of use.
$125.00 + shipping & ppal ....again the heavy parts shipping..$$$.
prefer not to, but if buyer really wants them i can
RPS Clutch - Used
Made for use with Lightweight Flywheel only, NOT a 'stock' replacement
450+ hp rated... I never hit more than 320 with this in the car... when it was running or boosting at all,.. so the 6 puck disc was a little bit of overkill for my power & the SC 's power character...it's perfect for a 400rwhp Turbo car...Save 300+ bux... RPS prices went up...
Includes Press. Plate & Sprung Disc, for a SINGLE MASS fly wheel...
..custom setup by RPS for 2jz w/single mass lightweight flywheels (RPS, Fidanza, Unorthodox Racing etc,)
Pressure plate:
Clutch Disc
..paid $500.00+ used for less than 3 mo total, I got sponsored & swapped it out... the car was down with broken SC's more than not that year... never drag raced, never abused, never hard launched, guaranteed
$225.00-Plus shipping & PPal fees
ALL these hose clamp & Insulating sleeve parts are BRAND NEW in the PACKAGING!!
Hose end clamp Blue Anodized 1/2in.,
Set of two. $10 + Shippng & ppal
Hose End Clamp Blue Ano. 1.25in.
set of two (Radiator..?) $15 + shipping & ppal
Hose End Clamp Blue Ano. 3/8th in.
2 sets of 2 (4 total) $10 for set of 2, $20 for all + shipping & PPal
Hose End Clamps, Vacuum lines- 7/32in. Red Blue Ano.
2 sets of 2 (4 total) $15 all 4 + Shipping & ppal
Pi-Thon Hose EndClamps 3/8th inch -
1 set of 2 -$21 + Shipping & ppal
Pi-Thon Hose EndClamps 5/8ths inch -
1 set of 3 $29 + shipping & ppal
Pi-Thon Hose EndClamps 3/4 inch -
1 set of 2 $25 + Shipping & ppal
DEI hose/harness Insulating ThermoSleeve 1/4 to 1/2 inch hose x 3ft.
$10 + Shipping & ppal
DEI hose/harness Insulating ThermoSleeve 5/8th to 1 inch hose x 3ft.
$12 + Shipping & ppal.
DEI hose/harness Insulating ThermoSleeve 1 1/8 to 1 1/2 inch hose x 3ft.
$15 + Shipping & ppal
550cc Injectors like new freshly serviced, rebuilt, matched & tested....
for modded fuel rails. Slightly too large for OEM fuel rail....full paperwork. w/clips, ready to solder in..
$275 + Shipping & PPal
Turbo Exh. Manifold, Never used, purhased 3+ years ago when I thot i was going to have to go turbo....
Still in perfect shape, Jet Hot ceramic coated inside & out, Solid unit...Re-inforced primarys.
$300.00 +Shipping & ppal fees
Rear Trunk Floor Bar original design Steel,Custom Painted Dark Metallic Grey like GGP w custom 'IS300' & 'Lexus' Logos w/satin clear. comes with hardware.
$50 + Shipping & ppal
Original OEM IS300 Wheel Locking Lugs w/Lug Wrench and Key.
45.00 + Shipping & Handling
OBX camber bolts...? i honestly do not know much about these but they are brand new, they came in a deal for my Megan rods...I never used them or tried to install.. 4 bolts total i assume they go in the rear lower suspension arms right under the hub...
$35 bux + shipping & ppal
Orig. RAYS Eng. Volk Blue alloy Lug Nuts w key -Used 3 shows-
$100 + shipping &ppal
Thanks for looking!
edward G.
