WHEEL FITMENT GUIDE: Will these fit? What offset do I need? - Page 8 - Lexus IS Forum
 10Likes
post #106 of 1756 (permalink) Old 11-04-2010, 11:20 AM
Originally Posted by TR_IS300 View Post
thanks! ill jus run 18x8.5 +30 all around since ill jus need a minor roll should look ok
depending on how flush you want to be
Hate On
My own story, growing up along side my IS:
http://my.is/forums/f90/going-caterp...ctures-418028/
eastono is offline
post #107 of 1756 (permalink) Old 11-04-2010, 12:45 PM
this is me...225/35 on a 10j +25F +15R
2004 MSM IS300
| Tein HA | JoeZ | Blitz | Project | Work | HKS | Xerd | GROM iPod |
3 Steps to Fit your Wheels
jon4862 is offline
post #108 of 1756 (permalink) Old 11-05-2010, 03:34 AM
oo man thats sexy!
TR_IS300 is offline
post #109 of 1756 (permalink) Old 11-05-2010, 03:35 AM
well i was thinking maybe no finger gap possibly alittle lower
TR_IS300 is offline
post #110 of 1756 (permalink) Old 11-05-2010, 12:31 PM
tires are too stretched for my taste. kudos on making it work though
fake$hitfree is offline
post #111 of 1756 (permalink) Old 11-05-2010, 07:23 PM
Will a 18x8.5 all around with 40 offset work on a stock IS300 and whats the best tire fitment
0r 19x8 38 offset
Thanks in advance
02 is300 MSM 5spd Spec stage 1 with fidanza flywheel (Billet 6265,Tial BO, precsion wastegate,AEM gauges and stock everything else)Volk Gt-N 18x7.5f +43 18x9r+44 ,hotchkis sway bars,Megon LP coilover,Chargespeed Hood
94 Supra 76gts th400
93.5 TT supra 6266 1000cc injectors , TM stage 1 cams,TM 3500stall ,VPC.GCC,SAFC2
87 Turbo Buick WE4
SUPRA_IST is offline
post #112 of 1756 (permalink) Old 11-09-2010, 08:42 AM
Originally Posted by re-rx7 View Post
Lookin at sum wheels im interested in..options are 18x8.5 with a +30 offset all around or 18x10 +25 in the rear. what would the +30 all around look like?
8.5 +30 would be semi flush, depending on the type of tire you were running, if you wanted to run a 235 in the rear it'd probably be flush-er. I'd run a 215 up front if you don't want to run into rubbing issues, but you may need to do a roll if you run a wider tire then a 225 in the rear.
hi im getting a wheel set up and need some oppinions since im new to the is300
18" 8.5 +30 front
18" 10 +25 rear
will i need to roll my fenders? im currently dropped on Tein Super Streets
Yeah, run a 215 up front with a slight roll and you should be good, the 18x10, you will need to roll you fenders flat and even pull/flare them a good bit along with running stretched tire.
0r 19x8 38 offset
Thanks in advance
18x8.5 +40 you'll be good with a 225 all around and shouldn't rub and if you do it will be minor, a roll would take care of all that.
I can't provide much info on the 19's but you will probably need to do a roll with them.
Hate On
eastono is offline
post #113 of 1756 (permalink) Old 11-09-2010, 10:49 AM
18x8 +30 all around
im at stock height.
what fender mods and what tire size for these specs??
bran761g is offline
post #114 of 1756 (permalink) Old 11-09-2010, 11:12 AM
Originally Posted by bran761g View Post
18x8 +30 all around
im at stock height.
if you want to be on the super safe side you can roll all your fenders but this probably is not needed on stock ride height,
i'd probably run the recommended size of a 225/40 or you can do a minor stretch (if any) with a 215/40 do be REALLY safe.
Hate On
eastono is offline
post #115 of 1756 (permalink) Old 11-09-2010, 11:23 AM
awesome, thank you. if i drop it eventually, should i plan on a roll?
bran761g is offline
post #116 of 1756 (permalink) Old 11-09-2010, 11:32 AM
on a 225/40 yes, that would be your best bet.
Hate On
eastono is offline
post #117 of 1756 (permalink) Old 11-09-2010, 06:01 PM
thank you
87 Turbo Buick WE4
post #118 of 1756 (permalink) Old 11-10-2010, 05:37 PM
Quoted: 7 Post(s)
considering getting CCW Classics and I am having a helluva time understanding what is the most useful offset/tire size assuming 18x8(.5)x 18x9.5(10) and assuming I have Vertex/Chargespeed front fenders (+20mm somewhat debatable but whatever). DAILY DRIVEN mind you please.
I read and read about hella(insert clever whatever) and as dope as I think it is, it's just not my goal right now, need usable/traction with relatively even wear (currently on 3deg in front and 2deg in back and tired of chewing up tires).
would be much appreciative of any suggestions, I am finally painting the car again and got a fresh Visa with some wheels/tires written all over it.....
paypal the person that helps the most enough for a Fat Tire or a Terrapin of their choice....seriously
THANKS!!!
shinybell is offline
post #119 of 1756 (permalink) Old 11-10-2010, 08:31 PM
Quoted: 19 Post(s)
THANKS!!!
What size tires do you want to run?
You could probably do a 18x9 +35 with a 255/35/18 especially with Vertex Fenders.
You could do a 18x10.5 +45 with a 275/35/18 I think. TecKIs300 was running a similar setup actually.
Well, I searched for his thread
Brushed CCW's finally mounted! Pics on Page 4
He is on stock fenders so you'll have a little room up front. But be careful with the Vertex fenders since they are fiberglass.
Originally Posted by TeCKis300 View Post
Here's finally a pic guys! Fitment came out perfect.
18x9" +38 Fronts with 255/35/18
18x10.5" +48 Rears with 265/35/18. Still have room for a 285/30/18
Teaser pic
I would pretty much copy that setup It looks great.
And get some Figs Mega Arms so you can dial in your alignment. Possibly the Toe links too. And maybe some upper A arms. Figs has some he is working on, or Cusco's IF you can find a set since they are discontinued.
white_is is offline
post #120 of 1756 (permalink) Old 11-10-2010, 09:00 PM
Quoted: 7 Post(s)
10-4, I has Cusco front upper A arms sir .
snowcones chance in hell I could run at least a 40? Bit of a stretch is ok, and don't mind at all raising up just a bit...would have to when I put kit on anyway...more interested in making them fit and get best traction/life.
