WHEEL FITMENT GUIDE: Will these fit? What offset do I need? - Page 3 - Lexus IS Forum
 10Likes
post #31 of 1756 (permalink) Old 07-17-2010, 01:55 PM
Ok here we go. Id like to run 17x9's all around. My tires are 225/45 front 235/45 rear. My question is what would be the best offset. +45 or +35? Thanks!
03 IS300 5spd -My Build Here-
04 IS300 - Sport Design #667
98 4Runner- Build Here
71 240z -Sold-
93 SE-R Turbo -Sold-
~KnuckleDuster~ is offline
post #32 of 1756 (permalink) Old 07-17-2010, 03:16 PM
17x9+35 will be the only offset to work.
17x9+45 will hit the upper suspension upright in the front...
I'd get some 10mm spacers for the rear to even out the poke.
+35 (front)
+25 (rear + 10mm spacer)
Oh, and staggering tires on non-staggered wheels is retarded.
'04 Infiniti G35 6mt Coupe
'02 Lexus IS300 - SOLD
twestman is offline
post #33 of 1756 (permalink) Old 07-17-2010, 03:53 PM
Ok so heres what I can do, 17x9 +35 front, and 17x9 +22 rear w/ spacers and I should be good to go.
I already have the tires so Ill have to roll around like a tard I guess. There really isnt enough size difference to be that bad though My plan was to go staggered but the wheels I want look horrible in anything under a 9" wide wheel..
71 240z -Sold-
post #34 of 1756 (permalink) Old 07-18-2010, 02:17 PM
Hey guys I need some help, Im looking to get some xxr 552s, will 19x8.5 +38/19x10 +40 fit? or will i have to run crazy camber to prevent rub? I've read most of this thread, yet offsets and everything still confuse me.
WWIS300 is offline
post #35 of 1756 (permalink) Old 07-30-2010, 10:41 PM
Patriot
I am trying really hard to understand this but I can't so please help me out...I am lowered on tein S-techs will this rim fit and what size tires will I need...thanks a lot...btw if anyone needs help in banking that I am good at and can explain much better than wheels...lol...thanks again folks...
STAGGERED
(2) 19 x 8.5
(2) 19 x 9.5
Offset: +35 front
Offset: +45 rear
Bolt Pattern: 5 x 114.3
Lip: 1" front
Lip: 3" rear
©2008 my.IS
HELLO: Reiger B8 A4 S-Line, Volvo XC60
SOLD: 2001 Turbo IS300...Goodbye...you will be missed!!!
4drsupra is offline
post #36 of 1756 (permalink) Old 07-30-2010, 11:15 PM
I was looking to run 245/40/17 tire set up all around but was told tires would rub upfront.
whats a good tire combo non-staggerd for 17x9.5 +28 all around.......no stretch!
Is3gte is offline
post #37 of 1756 (permalink) Old 07-30-2010, 11:20 PM
Nothing. Without pulling your fenders 1.5" and running more than -3* of camber, you won't get away without stretching tires with a 9.5 up front.
twestman is offline
post #38 of 1756 (permalink) Old 07-30-2010, 11:37 PM
I want a non-staggerd setup will i have to go down to like 8.5 or 9 for anything to work with no stretch (streetable track car basicly)
Is3gte is offline
post #39 of 1756 (permalink) Old 07-31-2010, 11:36 AM
Yes. Read the first post and do the math yourself. An 18x9.5+28 is 28mm *over* the front fender limit.
twestman is offline
post #40 of 1756 (permalink) Old 08-02-2010, 05:14 PM
Okay... So, I found 18x8.5 et45 and 18x10 et51 Just want to ensure my calculations are correct.
Front:
8.5 * 25.4 / 2 - 45 = 62.95 (OK)
8.5 * 25.4 / 2 + 45 = 152.95 (OK)
10 * 25.4 / 2 - 51 = 76 (BAD)
10 * 25.4 / 2 + 51 = 178 (OK)
Now these rims come with tires. Can I use them if they are:
Rear 265/35/18
Front 225/40/18
I know it's the rear that will need work, but is a 265 too much in the rear? What can I do for a mild stretch on the rear? 255? or is 265 okay?
Thanks in advance!
ISrt300
SRT w/ECU | Figs Heat Shield & Hood Props | Tuned Parts Vented Radiator Panel | OBX Headers | Magnaflow Cat Back | Hotchkis Front & Rear Sways | Front & Rear Upper Strut Bars | Tein Super Street w/EDFC | Tanabee Front & Rear Under Brace | VIS Carbon Fiber Hood & Trunk | Carbon Fiber B Pillars & Mirrors | Clear Front & Rear Markers | JDM Clear Fogs | RMM Front Lip | SSR GT3 18x8.5 and 18x10 | Pirelli PZero | JDM Shorty Antenna | Led Dash & Interior | Stoptech Front BBK
ISrt300 is offline
post #41 of 1756 (permalink) Old 08-02-2010, 08:18 PM
Patriot
STAGGERED
(2) 19 x 8.5
(2) 19 x 9.5
Offset: +35 front
Offset: +45 rear
Lip: 1" front
Lip: 3" rear
any help on this guys?
©2008 my.IS
4drsupra is offline
post #42 of 1756 (permalink) Old 08-02-2010, 09:39 PM
Quoted: 19 Post(s)
STAGGERED
(2) 19 x 8.5
(2) 19 x 9.5
Offset: +35 front
Offset: +45 rear
Lip: 1" front
Lip: 3" rear
Front:
225/35/19 if you want. A 215/35/19 would fit easier. You'll still need to roll the fenders unless you are running a good amount of negative camber.
Rear:
245/30/19 or 235/35/19. You'll have to roll flat and trim/attempt to roll the bumper tab.
Front:
Rear 265/35/18
Front 225/40/18
Thanks in advance!
Front will fit fine with no roll or anything.
You'll probably be fine in the rear too. Just roll the fenders flat/trim the bumper tab. If you have to step down to a 255/35/18.
white_is is offline
post #43 of 1756 (permalink) Old 08-02-2010, 10:18 PM
^^^ White Is, the fronts will not work. They come out to be 72.95 and the clearance is 65 That there already you have a problem even with a streched tire and all.
Guys am I correct?
now for all you tire guys out there, how much smaller of a rear should I be aiming for?
ISrt300
ISrt300 is offline
post #44 of 1756 (permalink) Old 08-02-2010, 10:32 PM
Quoted: 19 Post(s)
Guys am I correct?
I'm running an 8 +17 with a 215 up front.
8 *25.4 / 2 - 17 = 84.6
I also only have -1.7* of camber up front.
And I just said you can make the 265 work. A 255 will obviously give you more room though. It depends how much you want to roll the fenders.
Again, I'm running 9 +27 with a 235 in the rear. And only -1.5* of camber.
9 * 25.4 / 2 -27 = 87.3
As long as the 265 isn't a tire that runs wide, it should fit VERY similar to my 235 on a 9. You will have to roll the fender flat and mod the bumper tab, but it will fit. And you'll have to do almost the exact same mods to get a 255 to fit so it's your choice.
white_is is offline
post #45 of 1756 (permalink) Old 08-02-2010, 11:30 PM
Sorry, I read that last post wrong... I thought you were someone asking. So, I picked up the wheels tonight. Authentic SSR GT3s 18x8.5 et45 and 18x10 et50.
Thanks for the help!
+Rep
ISrt300
ISrt300 is offline
