OEM Wheel Specs FAQ - ISP, F-Sport, IS-F, X-Package - Lexus IS Forum
post #1 of 1 (permalink) Old 02-25-2009, 01:14 AM Thread Starter
Ninja?
ISP Mode Wheels:
* Available Size: 18 x 8 and/or 18 x 8.5
* Bolt Pattern: 5-114.3
* Offset: 45 mm Front / 50 mm Rear
* Weight: 26.8 lbs Front / 26.85 lbs Rear
* Accepts TPMS Sensors
OEM Wheels (IS300):
* Available Size: 17 x 7 All-Around (Sedan); 17 x 7 Front / 17 x 7.5 Rear (Sportcross)
* Offset: 50mm/ 55mm Rear (Sportcross)
* Weight About 28lbs
* DOES NOT Accept TPMS Sensors
OEM Wheels (IS250/350):
* Available Size: 18 x 8.0 Fronts & 18 x 8.5 Rears
* Offset: 45mm Front / 50mm Rear
* Weight Front 28.25 / Rear 30.00 lbs
X-Package Wheels:
* Size: 18 x 8 inches Fronts & 18 x 8.5 Rears
* Offset: 45 mm Fronts / 50mm Rears
* Weight 27.30 lbs Fronts / 27.75 lbs Rears
IS-F Wheels:
* Size: 19 x 8 Front, 19 x 9 Rear inches
* Offset: 45mm Fronts / 55mm Rears
* Weight
GS350 Wheels:
* Offset: 45 mm
* Weight 29.65 lbs
G-Spider Wheels:
* Size: 18 x 8 inches F/ 18x8.5 R
* Offset: 45 mm F/ 50mm R
* Weight 27.65 lbs F/ 28.35 lbs R
TORQUE SPECS ON LUG NUTS = 76 lb/ft
OEM TPMS (pre-04/2006) = Programmable to (post-04/2006) OEM TPMS systems [thanks "mikes rx"]
©2006 my.IS
2015 F32 w/ N55 Alpine White
DO SUSPENSION FIRST!
kayotik is offline
Closed Thread
