Member Wheel/Tire Size Catalog - Lexus IS Forum
post #1 of 34 (permalink) Old 10-03-2009, 10:11 PM Thread Starter
SORRY I'VE BEEN PRETTY BUSY LATELY,
I WILL TRY TO UPDATE THIS AS SOON AS I CAN
IN THE MEANTIME, PLEASE HELP ME UPDATE THE LIST IF YOUR CAR IS LISTED BELOW, OR IF YOU WOULD LIKE TO ADD YOUR CAR IN!
Not sure what wheel/tire sizes would fit your car without rub?
Well, I was looking through the RSX forums and I came across this:
***List of Wheel Sizes, Offsets, and Tire Sizes for RSX. - Club RSX Message Board
I thought it'd be a great idea to do the same in our forum.
Basically, this way we will know that certain specs has already been done and proven that it has worked for others, meaning the less you have worry about for your own clearance.
Please post what specs you are running on by modifying the "chart" below.
Stock/OEM IS300 Sedans comes with the following specs:
Stock IS300 Sedan:
  • Front Wheels Specs:17x7 +50
  • Rear Wheels Specs:17x7 +50
  • Front Tires Size:215/45R17
  • Rear Tires Size:215/45R17
  • Negative Camber: 0
  • Lowered Ride Height: 0
  • Spacers: N/A
  • Fender Shave/Roll: N/A
  • Fender Pull: N/A
  • Aftermarket Fenders/Fender Flares: N/A
  • Fender Rub: None
Note: If you have a fender pull, aftermarket fenders, fender flares, or spacers, please state WHAT, and how much space is added, and a NUMBER.
18X8: twestman, xagenesis
18X8.5: PhillyB, baadhabit
18X9: nymidas, solo, xagenesis
18x9.5: twestman, PhillyB, baadhabit
18x10: solo
19X8: Vi3tBoY
19X8.5:
19X9: Vi3tBoY
19x9.5:
19x10:
Contributions: twestman, xagenesis, PhillyB, illroller, nymidas, solo, baadhabit
あなたが読むことができない日本
Jordan_Inc is offline
post #2 of 34 (permalink) Old 10-03-2009, 10:30 PM Thread Starter
here's an example I did for a few members on the forums
im missing some stuff, so please just let me know so I can have them updated, especially if you ARE that person!
for each member, we are limited to post only ONE picture of their car. if you want it to have it updated, then simply replace it.
Thanks!!
twestman:
  • Front Wheels Specs: 18x8 +28 (orig +38)
  • Rear Wheels Specs: 18x9.5 +33 (orig +38)
  • Front Tires Size: 215/40R18
  • Rear Tires Size: 245/35R18
  • Negative Camber: -1.5* F / -2.6* R
  • Lowered Ride Height: 2"+
  • Spacers: 10mm F / 5mm R
  • Fender Shave/Roll: Front = Flat / Rear = Flat
  • Fender Pull: +10-15mm Rear
  • Fender Rub: None
xagenesis:
  • Front Wheels Specs: 18x8 +35
  • Rear Wheels Specs: 18x9 +35
  • Front Tires Size: 215/40/R18
  • Rear Tires Size: 225/40/R18
  • Negative Camber: -2.8F -3.4R
  • Lowered Ride Height: ?
  • Spacers: 0mm
  • Fender Shave/Roll: Rolled F&R
  • Fender Pull: N/A
  • Fender Rub: Fronts, only at full lock against the fender lining.
PhillyB:
  • Front Wheels Specs: 18x8.5 +25
  • Rear Wheels Specs: 18x9.5 +20
  • Front Tires Size: 215/40/18
  • Rear Tires Size: 255/35/18
  • Negative Camber: Not sure. Its just set on coilovers with a alignment. nothing major is needed.
  • Lowered Ride Height: Coilovers Ride Height?
  • Spacers: None
  • Fender Shave/Roll: F: Vertex +15mm / R: Rolled Flat
  • Fender Pull: Pulled then had a body shop clean it up.
  • Aftermarket Fenders/Fender Flares: Vertex +15mm front fenders
  • Fender Rub: Front fenders fit perfect no rubbing at all sits flush. Rear rubs depending on what tire you go with. To play it safe go with a Falken Etc.. Or go with a 245/40
illroller:
  • Diameter/Width Size: F: R:
  • Offset: F: mm / R: mm
  • Tire Size: ?
  • Camber: 0
  • Ride Height: 0
  • Spacers: 0mm
  • Fender Shave/Roll: 0
  • Fender Pull: Front & Rear
  • Aftermarket Fenders/Fender Flares: None
  • Fender Rub: Minor
stage2:
  • Tire Size: ?
  • Camber: 0
  • Ride Height: 0
  • Spacers: 0mm
  • Fender Rub: Minor
nymidas:
  • Diameter/Width Size: F: R: 18x9
  • Offset: F: mm / R: +35mm
  • Tire Size: ?
  • Camber: 0
  • Ride Height: 0
  • Spacers: 0mm
  • Fender Pull: None
  • Aftermarket Fenders/Fender Flares: F: Wald Fender Flares / R: Wald Fender Flares
  • Fender Rub: Minor
solo:
  • Diameter/Width Size: F: 18x9 / R: 18x10
  • Tire Size: F: 225/40R18 R: 235/40R18
  • Camber: 0
  • Ride Height: 0
  • Spacers: 0mm
  • Fender Pull: None
  • Fender Rub: Minor
baadhabit:
  • Front Wheels Specs: 18x8.5 +41
  • Rear Wheels Specs: 18x9.5 +49
  • Front Tires Size: 225/??R18
  • Rear Tires Size: 225/??R18
  • Lowered Ride Height: F: -1.3 / R: -1.6
  • Spacers: R: 10mm
  • Fender Shave/Roll: F: Rolled Flat / R: Rolled Flat
  • Fender Pull: R: Minor
  • Fender Rub:?
Vi3tBoY:
  • Front Wheels Specs: 19x8 +42
  • Rear Wheels Specs: 19x9 +45
  • Front Tires Size: 245/30R19
  • Rear Tires Size: 225/35R19
  • Spacers: N/A
  • Fender Shave/Roll: F: Stock / R: Rolled
  • Fender Pull: N/A
  • Fender Rub: Front Minor Rub
white_is:
  • Front Wheels Specs: 18x8 +45 (+42 w/ spacers)
  • Rear Wheels Specs: 18x9 +45
  • Front Tires Size: 245/35R18
  • Rear Tires Size: 255/35R18
  • Negative Camber: F: 1.5 / R: 2.5
  • Lowered Ride Height: F: 2.5" / R: 3"
  • Spacers: 3mm up front for BBK
  • Fender Pull: Tires flared front fenders a bit
  • Fender Rub: Front rubs when going around hard corners at fast speeds.
Juic:
あなたが読むことができない日本
post #3 of 34 (permalink) Old 10-04-2009, 03:40 AM
Juic's Avatar
I was going to make a thread like this. I think you should rename it to "Member Wheel/Tire Size Catalog" There is a thread like this of ISF and it's great:
Member Wheel/Tire size catalogging - ISfanatics.com
PPL should only post 1 pic and a link to more pics so it doesn't become a pic thread.
Juic is offline
post #4 of 34 (permalink) Old 10-04-2009, 04:09 AM
good job on this thread. put some work into it. and its a great idea.
right now my setup is pretty basic so i dont think it will really help anyone. hopefully real soon it will be something worthy to be on this.
back in action with a sportcross.
kai_10 is offline
post #5 of 34 (permalink) Old 10-04-2009, 03:37 PM Thread Starter
thanks, im gonna try to update this as much as I can, please contribute if any of you guys can.
あなたが読むことができない日本
post #6 of 34 (permalink) Old 10-04-2009, 05:28 PM
Under House Arrest
xagenesis:
Diameter/Width Size: 18x8 18x9
Offset: F: +35
Tire Size: F: 215/40/18F 225/40/18R
Camber: -2.8F -3.4R
Ride Height: ?
Spacers: 0mm in photo
Fender Pull: 0
Aftermarket Fenders/Fender Flares: 0
xagenesis is offline
post #7 of 34 (permalink) Old 10-04-2009, 05:59 PM Thread Starter
Originally Posted by xagenesis View Post
xagenesis:
Offset: F: +35
Camber: -2.8F -3.4R
Ride Height: ?
Fender Pull: 0
updated, both front and rear is +35 offset?
also, for ride height, how much are you lowered to?
あなたが読むことができない日本
post #8 of 34 (permalink) Old 10-05-2009, 08:51 AM
Juic's Avatar
Juic:
  • Front Wheels Specs: 18x8 +45(+42 w/ spacers)
  • Negative Camber: F: 1.5 R: 2.5
  • Lowered Ride Height: F: 2.5" R: 3"
  • Fender Shave/Roll: F: Rolled Flat R: Rolled
Pics are in my sig.
For those that aren't sure about how low they are dropped, measure from the center of the wheel hub to the top of the fender. Then subract that number from these:
Rear: 15" 5/8
Front: 14" 3/4
Thanks to strumgol for the info.
Also, I think you should add "NO CONVO" to the title so it keeps the BS down to a minimum. If anyone has anymore questions about someone's setup they should just send them a PM, or search.
Juic is offline
post #9 of 34 (permalink) Old 10-05-2009, 10:09 AM Thread Starter
Please keep all conversations at a minimum level, only post when you can contribute to updating the thread to make our list longer. Thank you.
あなたが読むことができない日本
post #10 of 34 (permalink) Old 10-05-2009, 10:21 AM
Class III Aficionado
1 more thing you may wanna add.
what wheel they have
Vice President and CTO of The A.S.S
Im sorry, but having a DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. - Jezza
drunkenmonkey is offline
post #11 of 34 (permalink) Old 10-05-2009, 10:38 AM
Quoted: 19 Post(s)
illroller:
Diameter/Width Size: F: 18x9 R: 18x10
Offset: F: 25mm / R: 25mm
Tire Size: F: 215/40/18 R: 225/40/18
Camber: 0 ?
Ride Height: 0 ?
Spacers: None
Aftermarket Fenders/Fender Flares: Custom pulled Front fenders that were reinforced with fiberglass
Fender Rub: Minor
white_is is offline
post #12 of 34 (permalink) Old 10-05-2009, 10:49 AM
Quoted: 19 Post(s)
white_is
Diameter/Width Size: F: 18x8 R: 18x9
Offset: F: 37mm / R: 37mm
Tire Size: F: 215/40/18 R: 235/40/18
Camber: F: -2.4* R: -2.7*
Ride Height: Not sure
Spacers: None yet. Will add to be more flush.
Fender Shave/Roll: Rolled fronts and rear.
Fender Pull: Very slightly if any. By accident.
Aftermarket Fenders/Fender Flares: None.
Fender Rub: Rear bumper tab on the passenger side. My rear coilovers are too soft. Stiffen it up and I'll be fine.
Wheels: Gold SSR Professor MS1
18x8 +37 Normal Disk
18x9 +37 Super Low Disk
white_is is offline
post #13 of 34 (permalink) Old 10-08-2009, 02:55 PM
baadhabit's Avatar
a few minor changes
baadhabit:
Front Tires Size: 225/40/18
Negative Camber: 0
Spacers: R: 10mm
Fender Shave/Roll: F: Stock / R: Rolled Flat
Fender Rub: yes on big dips
i dont know what my "lowered ride height" is but if you say its F: -1.3 / R: -1.6 i'll take your word for it
also i believe Solo's set up with the Sara's was 18x9 and 18x10 +27
need to add some posts on Apex, Missy IS300, Mr Singh, TDS_IS, Kdog1818, Da2Is to name a few with nice wheel fitment
baadhabit is offline
post #14 of 34 (permalink) Old 10-08-2009, 03:02 PM
baadhabit's Avatar
Kdog1818:
Front Wheels Specs: 18x9 +33
Rear Wheels Specs: 18x10 +38
Rear Tires Size: 235/40
Negative Camber: ?
Spacers: R: ?
Fender Shave/Roll: ?
Fender Pull: ?
Aftermarket Fenders/Fender Flares: ?
Fender Rub: ?
New wheels again *Flush*UPdate new pics added. More pics added 10/05
post #15 of 34 (permalink) Old 10-09-2009, 07:48 AM
PhillyB's Avatar
Awesome thread heres an update on mine:
Wheels: Work Emotion CR-Kai
Negative Camber: ? Not sure. Its just set on coilovers with a alignment. nothing major is needed.
Lowered Ride Height: Coilovers Ride Hight?
Spacers: None
Fender Pull: R: Pulled then had a body shop clean it up.
Aftermarket Fenders: Vertex 15mm front fenders.
Putting stickers on fake wheels to pass them off is the same as a girl rocking a fake Gucci or a Lamborghini kit car or some fake Jordan's. If you can't afford to play then rock the lower end brands and stop playing yourself.
PhillyB is offline
