ISX50 Wheels on IS300 - LOOK HERE - Page 3 - Lexus IS Forum
post #31 of 320 (permalink) Old 02-06-2007, 11:24 AM
Here's a link to someone who just recently did this:
Check It Out New Rims !!!!!!!!!!
Browse around or do a search. It helps a lot.
pn0yvstyle is offline
post #32 of 320 (permalink) Old 02-07-2007, 09:21 AM
The IS250/350 with 18" wheel option has the follwing specs:
F18x8.0 +45 225/40R18 (25.1" tall)
R18x8.5 +45 255/40R18 (26.0" tall)
Your IS300 with the 17" wheel option has the following specs:
17x7 +50 215/45R17 (24.6" tall)
If you are buying those IS350 wheels & tires as is, there are two problems
1) Overall Diameter. The IS350 is designed to run shorter tires in front and taller in the back. Both front/rear measurements are bigger than the diameter of the IS300 so your speedo will be thrown off and shows you a lower speed reading when you're actually going faster (i.e. showing you 60mph when you're actually going 62mph).
2) Fender Clearance. The IS350 wheel/offset/tire combo fits the IS300 front's nicely, should have no problems. The rear wheel/offset/tire combo will not fit without modifications to either your fender or changing to a smaller tiresize. To fit a 255 wide tire on 8.5" rim your wheel offset needs to be +55, the IS350 rear wheel is only +45.
The ideal way to use IS350 wheels on an IS300 is to buy four IS350 front wheels only (18x8 +45 225/40R18). But I guess your current situation is that you came across a set of staggered IS350 wheels and you want to know if it will fit "as-is". The anwser is no.
For the guy with the link posted above, he had to change out the rear tire from 255/40R18 to 235/40R18. Or you can roll your rear fenders and hope the rears will fit Either way, some work will be involved
PowerTrip likes this.
Neova is offline
post #33 of 320 (permalink) Old 02-08-2007, 01:20 AM
hey that is my iswith the 350 wheels you could run a bigger tire if you are not dropped or if you run a smaller profile tire like a 255/35/18 i have the 8.5 in back and i thought the back rims are a +50 not +45
eibach sportline, trd drop filter, joe Z intake, Figs hood kits, Sun ground kit, IS 350 wheels 18", tusdo ss 2.5" catback pipe and magnaflow muffler. black head and fog lights.
solo66 is offline
post #34 of 320 (permalink) Old 02-08-2007, 01:22 AM
and yes the bolt right on ...
solo66 is offline
post #35 of 320 (permalink) Old 02-09-2007, 09:40 PM
I will be putting these wheels on soon as well and thinking about 245/40/18 or 245/35/18 in the rear. Would I be better off with the 35 series tire? will it look noticeably different if I run a 40 series in the front and 35 on the rears?
lloyd xmas is offline
post #36 of 320 (permalink) Old 02-11-2007, 12:54 PM
IS350 18 1/2" 45/50 offset wheels with General Exclaim UHP 225/40 and 245/40 tires. No issues at all with stock setup.
carpemanana is offline
post #37 of 320 (permalink) Old 02-11-2007, 07:18 PM
There is one incorrect statement in this though...... the rear is a 18x8.5 +50, not +45. You can run the stock setup on an IS with the exception of running a 235 or 245 tire due to rubbing issues.
After selling my current setup today, I believe this is what I'm going with. When I look at the rear 255 tire on the 2IS, it's a little too fat for my taste. Here's the only pic that I have now.
1997 Custom Red 1JZ SC300 - Sold 2005
2001 Jade Mica Green IS300 - Sold 2011
2000 Platinum Edition MSM GS300 - Sold 2012
2001 Graphite Grey Pearl IS300 - Sold 2015
2006 Black Onyx IS350 - Current
2005 Mercury Metallic LS430 - Current
MrJamison is offline
post #38 of 320 (permalink) Old 02-17-2007, 09:30 PM
Pic Above.
post #39 of 320 (permalink) Old 02-19-2007, 03:07 AM
I've been looking into getting 2IS wheels for my car as well. I like the look of the X-Package wheels in particular (anybody here have them already?) and only want a 1" drop. Anybody have pics, pls post them
dsp979 is offline
post #40 of 320 (permalink) Old 02-23-2007, 09:31 PM
My IS300 w/IS350 wheels. Pics of my previous rides also.
So......... I finally got around to taking some pics of my car because the weather was so nice. They're not too creative because I didn't have a lot of time. I went with some IS350 staggered OEM wheels with Ryken tires. The fronts are 225/40 on the 18x8 and the rears are 235/40 on the 18x8.5. I'm currently running stock suspension. Anyways, here are the pics.......
post #41 of 320 (permalink) Old 02-24-2007, 08:05 PM
Hot!
01 GGP / Stealth On Wheels
Lexotic Concepts NE014
Elusive Media
Gray Rider is offline
post #42 of 320 (permalink) Old 02-24-2007, 08:29 PM
Do you know the offset of those rims?
bluealteza is offline
post #43 of 320 (permalink) Old 02-25-2007, 09:15 AM
Back road boosting
RollinIS300's Avatar
Location: Where the Cows out number the people(Vermont)
I really like how that looks
2001 448rwhp IS300 (sold)
RollinIS300 is offline
post #44 of 320 (permalink) Old 02-25-2007, 10:16 AM
The fronts are 18x8 +45 and the rears are 18x8.5 +50.
post #45 of 320 (permalink) Old 02-25-2007, 10:21 AM
looks good man
'01 DWP = RMM front lip and sides = 18" OEM G Spiders w/ Michelin Pilot Sport A/S Plus = Black painted OEMs with snow tires = 18" Chrome Gianelle = SRT intake = HKS Drager II = Brembo Slotted Rotors w/ Red Cailpers = PLP Heatshield = Aluminum Dash = 2 12" subs w/ 1200 watt amp = Altezza Z Edition Grill with Lexus emblem
thisISit is offline
