power windows - Lexus IS Forum
post #1 of 10 (permalink) Old 04-01-2008, 07:43 AM Thread Starter
hello all
i have a little problem with my power windows...
the auto up feature brings the window up, but it immediately goes back down when it is closed...
does anyone know whats wrong?
hello world,
i would like to know if anyone knows how to reset the pinch protection on my 2001 is300 auto windows.
where is the switch located, or how do i reset it?
thanks,
mattster of disaster
mattster of disaster is offline
post #2 of 10 (permalink) Old 04-01-2008, 02:07 PM
i have the same freaken problem when i put it on auto and pull it up the window goes up and automaticly goes down intill the middle..then i have the take it up with the regular way (not auto)
pearl_IS is offline
post #3 of 10 (permalink) Old 04-01-2008, 02:10 PM
Squareback's Avatar
Need your "pinch protection" reset. Might need to go to dealer to do it, not 100% sure.
Squareback is offline
post #4 of 10 (permalink) Old 04-03-2008, 01:04 AM
i got mine fixed with the same problem and it cost me 100 dollars from a local electrition
pearl_IS is offline
post #5 of 10 (permalink) Old 04-03-2008, 06:56 AM
for a hundred dollars just take it as a inconveniance and do it manual
kinoplay is offline
post #6 of 10 (permalink) Old 04-03-2008, 07:35 AM
Originally Posted by mattster of disaster View Post
hello all
hello world,
thanks,
You need to do this:
HOW TO RESET POWER WINDOW MOTOR (RESET SWITCH AND PULSE SWITCH)
If the jam protection is not functioned properly, perform the following procedure.
HINT: It is necessary to reset the power window motor (in initial position for the limit switch) when separating the window regulator from the power window motor or operating the window regulator with the door glass not installed.
Remove the power window motor. HINT: Place the matchmarks on the power window motor and window regulator gear.
Connect the power window motor and power window switch to wire harness of the vehicle.
Turn the ignition switch ON and operate the power window switch to idle the power window motor in UP side direction for more than 6 rotations or less than 10 rotates (4 seconds or more).
Assemble the power window motor and regulator. HINT:
Install the motor when the regulator arm is below the middle point.
Align the matchmarks on the power window motor and window regulator gear.
Assemble the power window regulator and door glass. HINT: Never rotate the motor to the down direction until the completion of the window glass installation.
Connect power window switch to wire harness and turn the ignition switch ON.
Repeat UP and DOWN operation several times manually.
Check if AUTO UP -> AUTO DOWN operates in automatic operation. HINT:
Take care that the jam protection function does not operate just after resetting.
Reset the regulator again when performing the reverse operating after closing the window fully by AUTO UP operation.
Check the power window function
The window motor needs to be clocked, most glass installers are clueless, so never do. To fix it, the motor must be removed from the regulator, then the switch plugged back in. Hit the down button, and let the motor turn until it stops, then bump it back up until the gear has made six full turns. From there, just reinstall the window motor, and you'll be good to go.
CorrPerformance Tuning
02 MSM 5MT/LSD...SOLD
03 GGP Auto/SportDesign...SOLD
01 MSM Auto/LSD...SOLD
el-guapin is offline
post #7 of 10 (permalink) Old 05-15-2008, 05:31 PM
i am having same problem and this sounds like a complex way to fix...is there any easier way to fix?
2002 IS300 5MT
RiversideS13 is offline
post #8 of 10 (permalink) Old 05-04-2010, 05:11 PM
yea this thread is like 2 years out but im trying to fix my window, the above instructions are confusing i cant even get the motor dismounted
937DYTBOI is offline
post #9 of 10 (permalink) Old 08-23-2014, 08:21 PM
Okay I successfully reset the pinch protection on a IS300 today. So I thought I would share the highlights of the procedure.
Removing the assembly is actually quite easy. I found it easier than replacing the mabuchi motors in the door lock assembly. You do NOT have to remove the speaker that is riveted in.
Once you have removed the 6 bolts mounting the rails & motor and the 2 bolts mounting the window to the rails, you can remove the assembly. You will fold the rails together and pull the assembly out of the large access hole. Don't forget to disconnect the electrical harness.
I followed the youtube instructions here
For the IS300 - here's the differences.
* I followed the reset procedure in the video - wind the motor upwards for 4 seconds.
* There is no spring on the IS300 rail assembly. Skip this portion.
* you must clock (orient) the rail assembly in the down position. Not in the middle like in the video. If you're wondering what the down position is - you can mock it up against the door to be sure.
* Now you must mate the motor to the first tooth in the gear. Install the 3 torx bolts.
* Reinstall the assembly in the door. WARNING: You must orient the short rail (top most rail) with the U-shaped end towards the right. The flat side goes to the left. This is important because it determines the travel of the rail assembly. If you orient it backwards the window will not travel completely upwards.
* When reinstalling the window, you can only install one mounting bolt (left most) The other one doesn't have enough clearance to insert. I installed that the second bolt after finishing the reset procedure.
* Like the video, roll the window up and down 3 times. Then verify auto-up works properly without triggering pinch protection.
* Move the window down to align with the access hole for the 2nd bolt. Install the second bolt.
Good luck! It was easier than the door lock motor replacement (less time) once I figured out the rail orientation.
Jeff310 is offline
post #10 of 10 (permalink) Old 09-09-2015, 11:44 PM
The window has a sensor to detect any foreign objects obstructing it's path. It automatically opens when something interferes w it's task.
4g63tojz is offline
