Evap hell - Lexus IS Forum
post #1 of 4 (permalink) Old 03-20-2017, 02:34 AM Thread Starter
Evap hell
Hi so i am new to the forum world. I have been trying to fix an issue on my IS300. I have a 2003 Auto Is300 with 150,xxx miles. As soon as i got it i did all maintenence. After about a month and a few thousand miles, after replacing my Valve cover gasket, i had a Check Engine Light and Traction Control Light flashing. I originally broke a little black box(part #23818 - PIPE, FUEL VAPOR FEE PIPE)that i guess is part of the evap system and i replaced that through ebay. I also have leaking a gas cap and a stain all the time from gas leakage and no i never spill gas!. So... I replaced the gas cap and reset the code.
It came back on a few days and a few hundred miles later!!!! I then scanned it and it said P0446, P0442, P0446P, and P0442P.
Theen i read that it could be a loose or cracked hose. So i replaced all the hoses that touched after gasket replacement. Annd even checked other hoses..I also made sure they are in the right spot.
The next step was to clear the code and make sure it doesnt pop up again... Guess what? it came again a few hundred miles/days later! so this time i went ahead and ordered the vsv 79.99 and did it myself.
Keep in mind, i took my car to autozone so the could scan it and they said either a 299.99 part or 79.99 for the same 2 codes. Its the charcoal canister or purge valve..
Well i found out my cvc shaft/boot is leaking and left a full circle of grease and muck.. i think it clogged the vsv.. i replaced it and cleared the code again.
This time it came on a week later and after a hard canyon run.. what do you think it is at this point?!?!? i need to get a fix it ticket signed off for exhaust and i hear it is an automatic fail if check engine light is on and im getting an exhasut check. Would it matter getting oem fuel cap from dealership? i got aftermarket with lock on cap. Thanks in advance
Ohhthatalex is offline
post #2 of 4 (permalink) Old 03-20-2017, 06:13 AM
Quoted: 67 Post(s)
Sounds like You are chasing your tail. So to speak. Why don't You get it smoke tested To see where the leak is. That way you don't keep throwing money at it.
post #3 of 4 (permalink) Old 03-20-2017, 12:41 PM Thread Starter
That was my next step, I will attempt to do it tomorrow and see what the results are.
post #4 of 4 (permalink) Old 03-20-2017, 01:09 PM
Quoted: 43 Post(s)
All hoses plugged back in? Ive heard others forgetting to plug hoses back in and getting these codes. I don't know if those codes would come on if the overfill check valve was at fault but I had P0440 come on my car and I had to replace mine. You could always check. Good luck.
01 IS300 with a p0440 (pic)
allturbo98 is offline
