Originall posted by Monetaryfund and edited by Sophiesleeps for tutorial purposes.
Pics to come.
1. Take the two "pop-off" pins off with a screw driver in the fender well and peel it back to create as much space as possible to get your hand behind the light.
2. Those two screws are the main "locks" for the headlight.. Take them off with 10mm socket wrench. You may need an extension.
3. While you at it, take this screw off which is the only hidden screw for the bumper on each side.
4. Take off the bolt on top of the headlight.
5. Take the middle screw off... If you have undone the screws on the opposite sides, you have taken out all the screws on top of the bumper. The grille will come off together with the bumper later.
6. Now, lay on your back and undone all the 10mm screws that attach the bumper to the plastic underbody cover. There should be about 7-9 of them. The picture shows just one of these screws and the tow anchor under the car.
7. Now, squat down on the side of the bumper facing the side marker and pull the bumper towards you just a "little" so that you can have space to unplug the foglight and side marker. Push bumper toward the front of the car to unmount it.
8. There are two clips under the light housing that used to hold the bumpers, pop them up with a screw driver will help you on moving the light forward.
9. Finally you can pull out the lights.
