b
Go Back   my.IS - Lexus IS Forum > 1st-Gen IS300 > Inside & Out
» Log in
Not a member yet?
Register Now!
» Featured Product
» Wheel & Tire Center
Sponsors
Sponsors
Old 02-26-2005, 10:03 PM   #1 (permalink)
Podiatrist
2005 ToyDrive Participant
SophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community memberSophieSleeps is an elite community member
How to open and paint your headlights
Courtesy of PGAis300
There are a lot of instructionals on this site of how to do this but I will explain the way I did it. I didn't take a whole lot of pictures so you can just look at the top of this post for the ones I did.
1. Remove the bumper. If you need to know how to do this do a search...I don't want to type all that out. It's not that hard.
2. Once the headlights are out, make sure to remove the HID bulb. Everything else can stay.
3. With the oven pre-heated to 250 degrees use a cooking pan that the light will fit on and do one light at a time. Put it in for about 7 minutes then check.
4. Make sure the tabs around the light are ready to come out and then slowly start to pull. It may not come out at first but at least get it started. (If the glue starts to come loose use a tiny flat head and run it through the seems the help break the glue loose)
5. If needed, put the light back in the oven for a few minutes and repeat step 4. Eventually it will come apart. Just make sure you don't over cook it.
6. Once apart, the part to paint will come right out. Take the clear turnsignal part out as well. (I painted this with RC car tint spray paint to match the black but still allowing light to shine through)
7. You can either paint the whole middle piece or do what I did and mask off your own rings (see pic). Just take your time with the masking making sure every part of the tape sticks. Also, make sure to use the blue masking tape so it doesn't hurt the chrome.
8. Use anywhere from 600-1000 grit sandpaper and lightly sand the part you are painting. It doesn't have to be completly sanded perfectly, just do what you can and get most of it.
8. I used about 3 coats of flat black paint. Just paint light coats until it looks right.
9. When unmasking, make sure and remove the tape VERY slowly so you dont peel off any chrome....the IS lights are very delicate.
10. After they look like you want put them all back together and heat the oven back up. Push the light as together as you can get and put it in the over for about 5 minutes.
11. Take it back out and you should be about able to push it until the tabs click back into place. If not put it back in the oven for a couple more minutes until you can.
12. Just to be sure I used a plastic/glass sealer I got from home depot to fill in where I thought was not back together like stock. This is good just to be sure no moisture gets in.
13. Repeat the steps for the second light and the fogs if you want and put your car back together....its that easy
Be sure to do this at your own risk. What I did worked for me but every little thing differs with everyone. Ex. Oven temps, year of car etc. I may have missed some stuff but this is the general idea of what I did.
difficulty 2001 6spd
First built 2JZ-GE Tri-Turbo
SophieSleeps is offline Reply With Quote
Old 10-27-2005, 01:54 PM   #2 (permalink)
Seven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community member
nice write-up, i did the same thing but about 8min each. and also i removed the ballasts, and all the rest of the bulbs/wiring just in case. i only left the auto-leveling motor in there.
tried to give you +rep but: "No Post specified."
Seven0Three is offline Reply With Quote
Old 10-27-2005, 05:24 PM   #3 (permalink)
lextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community memberlextasy623 is an elite community member
^^ maybe cuase this thread is like half a year old. Dont bump up this old stuff.
-Eric
lextasy623 is offline Reply With Quote
Old 10-27-2005, 06:07 PM   #4 (permalink)
i thought it might be worthwile to add that you might want to remove the other bulbs and the HID ballast just in case something were to happen. sorry, i'll keep my .02
Old 10-27-2005, 06:08 PM   #5 (permalink)
No, your cool, i just wanted to see if you had a reason behind it and you do so your good in my book
-Eric
Old 10-27-2005, 06:15 PM   #6 (permalink)
Threadlocker
irv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community memberirv_usc is an elite community member
bumping this with additional comments that might help out others is definitely a good thing.
much preferred to the standard bumping of YEARS old threads nothing to contribute
irv_usc is offline Reply With Quote
Old 02-20-2007, 08:18 PM   #7 (permalink)
MiaAltezza is an unknown at this point
Great info sophie! & I found a page that has pics! For fogs too!
http://home.comcast.net/~fusionmotorsports/
MiaAltezza is offline Reply With Quote
Old 02-23-2007, 01:13 AM   #8 (permalink)
peterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community memberpeterhoang1988 is an elite community member
350 degrees is how you melt ur lights. 290 works well for me. 10 mins per light and it comes off first time through.
peterhoang1988 is offline Reply With Quote
Old 02-23-2007, 01:25 AM   #9 (permalink)
2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member2002REDIS300 is an elite community member
did mine on 250* and left it in for 12 minutes
E-Shift/LSD | RED/BLK | Modified T-Netics | JDM FOGS | TRD SPOILER | Apex'i N1 | Tanabe | JIC | Defi Amber | AEM | PFS VB | AEM PnP StandAlone |
2002 IS300 AR (burnt)
2003 350z Track (got twins)
Looking for white 02+ manual soon...
Awesome Parts For Sale:http://my.is/forums/f99/f-s-huge-par...er-pix-349647/
2002REDIS300 is offline Reply With Quote
Old 02-23-2007, 08:32 AM   #10 (permalink)
Eminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community memberEminence is an elite community member
lolz the OG thread from 2005.
Eminence is offline Reply With Quote
Old 04-12-2007, 07:24 PM   #11 (permalink)
goingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community membergoingfast... is an elite community member
.....need to cook it in the oven huh......
goingfast... is offline Reply With Quote
Old 04-12-2007, 07:48 PM   #12 (permalink)
NOT Lextasy.com...
lextasyis300's Avatar
lextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community memberlextasyis300 is an elite community member
wow, from 05? damn...good one anyways
©2006 my.IS
2001 IS300
Megan :: Greddy :: K&N :: Hotchkis :: Bilstein :: B&G
If you try to fail, but you succeed, which have you done?
lextasyis300 is offline Reply With Quote
Old 02-19-2008, 12:11 PM   #13 (permalink)
IS-Bullet is an unknown at this point
what brand of paint should i use? im doing satin black but dont know what brand to get
Lexus FTW w00t!
IS-Bullet is offline Reply With Quote
Old 02-19-2008, 02:52 PM   #14 (permalink)
diablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community memberdiablooffire03 is an elite community member
krylon
01 IS300T 17psi 1.64 60' 11.8@120 -RIP-.
08 IS250awd. SOLD
06 Audi S4. SOLD
94 Supra Single Turbo 6spd. SOLD
diablooffire03 is offline Reply With Quote
Old 06-18-2008, 12:59 PM   #15 (permalink)
Ghostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community memberGhostly Echo is an elite community member
3 years later and this thread helped me out big time
For Sale Brand NEW Razo wr spec 114a shift knob
http://my.is/forums/f99/f-s-brand-ne...5/#post5705194
Ghostly Echo is offline Reply With Quote
You may not post new threads
You may not post replies
vB code is On
