Fender liners and lowered cars - Lexus IS Forum
post #1 of 16 (permalink) Old 04-14-2011, 10:05 AM Thread Starter
Technical Poseur
Quoted: 29 Post(s)
Seriously all these people with rolled fenders and such that say they have no rubbing. My car is slightly higher than all the helladouche cars and has a hella functional fitment yet after I rolled the fenders I still rub on hard corners/bumps on the fender liner...so my question is did some one send out a memo to remove that or are people modifying them some how? What am I missing here?
-Tom- is offline
post #2 of 16 (permalink) Old 04-14-2011, 10:52 AM
Patriot
Quoted: 11 Post(s)
I think people use a heat gun, reshape the fender liner, and then use a wet rag to cool it off and keep the shape they want to get them out of the way.
2004 Black Onyx 5 speed
Koni | Eibach | SRT | Megan | Apex'i | ACT | Fidanza | Mizu | Ralco | PLP | Figs | Valentine One
2010 Mercedes-Benz C63 AMG, 426 rwhp
VFA-11 The Red Rippers
chrisridebike8 is offline
post #3 of 16 (permalink) Old 04-14-2011, 11:44 AM
Juic's Avatar
LOL, helladouche.
I removed mine when I installed my Euro fenders. I have some GS300 fender liners wiating to be installed that require some modding to fit but according to ISMAN they offer more room. But I'm still rubbing on my fenders when I go around corners too fast. I need to roll/pull them more to fit my next setup.
Juic is offline
post #4 of 16 (permalink) Old 04-14-2011, 01:40 PM
Yeah you pretty much reshape them with a heat gun. Have a bucket of water and a wet rag ready and wherever you see that its rubbing, heat the fender liner up until you see that its softened. Then grab your cold wet rag and push it against the part you just heated until its cooled down. Just be careful not to heat up the liner too much to the point that its melting. Hope this helps!
Your friendly neighbordouche haha
JIzzy415 is offline
post #5 of 16 (permalink) Old 04-14-2011, 03:53 PM
I just took mine out.
When I installed my Chargespeed fenders, I asked edgy what he did with his liner and he said he just cut it.
I also asked Easton and he told me he took his completely out, so that is what I ended up doing.
Too many people try to impress others and build their car to what they know someone will like.
You lose sight on what you like, when you simulate your likes around others dislikes.
-PhillyB
What the Fitment
N V ME is offline
post #6 of 16 (permalink) Old 04-15-2011, 01:59 AM
Been without liners for a while and everything is fine
2004 IS 300 - Sold
1992 NSX - Traded
2000 S2000 - Traded
2002 IS 300 Sport Cross
Powerdrift is offline
post #7 of 16 (permalink) Old 04-15-2011, 02:14 AM
Went without a front bumper fora while during fitment of said bumper and the plastic rubbed the tire at high speed due to wind, so they're eaten away at one point. Wouldn't bother me so much if it wasn't so obvious (due to the big mouth on the bumper)
Heat gun it or take them off completely. Wish I hadnt screwed mine up. Anyone wanna send me the ones they just "pulled off"?
NismoZRyder is offline
post #8 of 16 (permalink) Old 04-15-2011, 02:18 AM
I'm lowered on L-Tuned springs with Koni Yellows set on the lowest perch and I too, rub my fender liners from time to time when going fast on deeper dips and on fast corner turns
anyone have a heatgun i can borrow? haha
L-Tuned Stage II Black Onyx w/ LSD + Push Start
Member of S.T.O.L.T.!!
leedoobert is offline
post #9 of 16 (permalink) Old 04-15-2011, 02:32 AM
Hey Albert, I can lend you mine but its kinda broken....only works on the highest setting and i think it stops working after long periods of use. Then again I did grab the cheapest thing I could find from the hardware store heh
JIzzy415 is offline
post #10 of 16 (permalink) Old 04-15-2011, 02:57 AM
I just cut the portion that rubs off with a razor blade so at least half of it is still on.
'14 NGP IS350 Fsport
'04 GGP Altezza'd out IS **past =[
plusONE +1
specONE is offline
post #11 of 16 (permalink) Old 04-15-2011, 04:54 AM
Mine rubbed just like yours did and I have the same type of hole. I'm just ordering new and shaping them as needed. I've done it before without problems. You can also use a propane torch if you are CAREFUL!
Fast - Cheap - Reliable
Choose 2
cOmpressor is offline
post #12 of 16 (permalink) Old 04-15-2011, 08:10 AM
Well I kept mine and rubbed a HELL of a lot more when they were in. I had massive burn holes toward the inside and it would pop out of the tabs if I hit them to hard. One day I hit a bump that the fender liners didn't like.
For those that don't know, the fender liner is connected all together from tire to underside of car to tire. Well, It came loose and the wheel liner and underbody liner dragged under my car from the middle of Texas til I got home in New Orleans, talk about loud scraping.
I had tried trimming it and sure it helped a little, now I roll without it and have had no problems over the past 6 months, other than the fact of me having to relocate my HID fog ballasts.
Hate On
My own story, growing up along side my IS:
http://my.is/forums/f90/going-caterp...ctures-418028/
eastono is offline
post #13 of 16 (permalink) Old 04-17-2011, 02:34 PM
I only cut portions of the liner.
aristo123 is offline
post #14 of 16 (permalink) Old 04-17-2011, 02:43 PM
^Exactly. I did the same. Reshaped most of the liner and cut out some areas and now I don't rub. Less beefy tires help too.
Joe-Z|Blitz LM|Apexi WS2|Stance GR+|FIGS
Turbo East|BC Stage 2|TITAN (-4)|B&M|NGK|ARP Studs|PLP|RMM
XXR 521|Ichiba|GROM|3K HID Fogs|JDM Smoked Altezza Grill|BP Emblems
Is300_4life is offline
post #15 of 16 (permalink) Old 04-17-2011, 02:57 PM
What are the specs on the wheels and tires?
I don't have any issues with rubbing, though my fenders are shaved, if that makes a difference.
03 IBP E-Shift
WTB: SUPERCHARGER KIT!
3M 1080 |Alpine | A'PEXi WS2| BBS LM| Bilstein HD | Cusco | Eclipse | H&R Sport| Tein H-Tech | JIC-Magic | Joe-Z | K&N | Mangowalk | Pioneer Z2 | Scosche | SPW | Supra | Viper | XPel |
XRflip05 is offline
