b
Go Back   my.IS - Lexus IS Forum > 1st-Gen IS300 > Inside & Out
» Log in
Not a member yet?
Register Now!
» Wheel & Tire Center
Sponsors
Sponsors
Old 04-26-2009, 08:39 PM   #1 (permalink)
supes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community membersupes is an elite community member
*DIY* Repaired and Painted Stock Rims *pics inside*
So I have been wanting to do this for a while in preparation to get my current wheels off of my ride and put on the sexy / classy 5 spokes...However, the 5 spokes that I got with my ride had curb rash, nicks, and scratches on them and needed new tires which I purchased recently (BF Goodrich F1 A/S 215/45/R17)...
With the purchase of tires completed I just needed to repair and paint my rims to get them ready for the tires and car mount...I followed the tutorials I found online as best I could and decided to take pictures along the way to help anyone interested in trying something similar...
Materials...
320 grit sand paper (wet sanding)
400 grit sand paper (wet sanding)
600 grit sand paper (wet sanding)
3M bondo
hose and lots of water
cloth for cleaning and drying
Dupli-Color Scratch Filler Primer - 1 can (< $5 pep boys)
Dupli-Color High Performance Wheel Coating (silver) - 1 can ($5.99 pep boys)
Dupli-Color High Performance Wheel Coating (clear) - 1 can ($5.99 pep boys)
100 pack of 3x5 index cards (walmart, $0.44)
Paint Prep rag I got from Pep boys ($1.99)
Painters tape (walmart, few bucks)
First I wet sanded all five rims with the 320 and hosed / wiped them all down after that...I then did the same thing with the 400 and 600 grit papers and then let them air dry for a while when I was done...
After this I then applied bondo to any area of the rim with a deep scratch, curb rash, or various other nicks that they may have had...I let that dry for about a half over then sprayed the rims down and then got to work with the 320 grit...Here you need to remember not to use your finger and sand hard as you will lose the bondo in the scratch...the trick is to sand with a block of some sort to match the surface of the rim...
I then used the 600 grit on the bondo to get rid of the excess bondo and do the final prep before paiint...I used the paint prep pad on all of the rims (one pad worked for all of the rims; can be found at Pep Boys for $1.99)
Then I used blue painters tape (you can use masking tape) to tape up the valve stems...Then I used the index cards to protect the tires from paint (see pics)... I then did 3 coats of scratch filler primer...I made sure to get all parts of the rim on each rim and then moved to the next 4...I then went back to the first one and in the end I did 3 coats of primer on all five rims (took about 40 minutes)...
I let them dry for a half hour and then took care of some over spray with 600 grit wet sanding...after this, i wiped them with the paint prep again (same one if it still is moist) and then started with the silver color coatings...I did 4 coats of this making sure to avoid over spray and to keep the coatings lights...
I then did 4 coats of clear (didnt know how to guage this so I just did 4; hopefully it isnt too much gloss or too little gloss). Here is the end result...
Overall, this cost me about $20 as I already had most of the sandpaper, index cards, prep pad, tape and bondo)...Money well spent to make the stock classies like new again...
The wheels are going on this bad boy next week...
supes is offline Reply With Quote
Old 04-26-2009, 08:47 PM   #2 (permalink)
kraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community memberkraven9 is an elite community member
Yeah. You got the stocks looking good. Ditch those other wheels as soon as possible. +rep for the DIY.
R.I.P - Alexander Ramirez 5/30/09
03 BO is300 e-shift formerly powered by a vortech S/C, work vs-xx with falken fk 452, bilstein shocks with eibach pro kit....pshhh yeah right R.I.P 2/11/09 .
03 BO is300 aka twin?
Originally posted by twestman...
I would stab myself in the eye if I had to look at either of those sets of wheels on my car.
kraven9 is offline Reply With Quote
Old 04-26-2009, 10:11 PM   #3 (permalink)
skubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community memberskubasteevo is an elite community member
How does the color compare to the stock color?
steve
2001 MSM IS300: HKS | Blitz | DIY JoeZ | TRD Reds
skubasteevo is offline Reply With Quote
Old 04-26-2009, 10:30 PM   #4 (permalink)
02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member02IS-GTE is an elite community member
whats wrong with the AMG style wheels on the Lex????
lol j.k stocks looking good. good move with putting the stocks back on. +rep
CP-BC-Carillo-HKS-GReddy-Apex'i-TRD-JIC-CUSCO-L-Tuned-Axis-Volk
street/track whore 219rwhp/217rwtq
Elizabeth Hyun a.k.a. AsianGirl007 10/28/68-07/18/09
Originally Posted by OKCIS View Post
Youve got balls the IS300 3rd gear is the only thing to have ever scared Chuck Norris
02IS-GTE is offline Reply With Quote
Old 04-26-2009, 10:32 PM   #5 (permalink)
rseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community memberrseifer is an elite community member
Very nice job. Looks as good as new, maybe even better than new.
Ralph Seifer
Koni's, TRD sways, Tom's chassis braces, Tom's strut
bar (rear), PLP strut bar (front), StopTech 332mm (front) , stainless lines F&R, Optima, Wet Okoles (front), 5Ziggen muffler, Passport 8500, Mobil 1 since new.
rseifer is offline Reply With Quote
Old 04-27-2009, 12:33 AM   #6 (permalink)
leonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community memberleonard_is300 is an elite community member
Here is a link that i found, i thought it was some good info and since someone posted a DIY with some good info I thought I would help out some.
Repairing Scratched Alloy Wheels & Rim Damage | How-to Guide
--2001 Imperial Jade Mica E-shift--
Stage 2 cams and cam gear check!
Tripple gauge pod check!
Boost gauge check!
Oil pressure gauge check!
Everything else needed........check soon!!
leonard_is300 is offline Reply With Quote
Old 04-27-2009, 12:45 AM   #7 (permalink)
moswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community membermoswantedaltezza is an elite community member
wow... thats a great job... too bad my stocks are chrome... lol...
Greddy / TRD / JDM / Sport Design / L-tuned / Eibach / Tokico / HKS / SRT /
"She might be GOOD from far but she can be FAR from good!"
moswantedaltezza is offline Reply With Quote
Old 04-27-2009, 12:45 AM   #8 (permalink)
zet
zet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community memberzet is an elite community member
nice bumper
2004 Bluestone Metallic | Injen SRI | Greddy Ti-C Catback | SD Grill | Tanabe GF210 | Tokico Illumina | JDM Tails | Short Antenna
Canon 5D
zet is offline Reply With Quote
Old 04-27-2009, 01:53 AM   #9 (permalink)
acrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community memberacrylick is an elite community member
Wow they look good.. Thanks for the DIY! I'm gonna have to do this for my stockies.. Lots of curb rash on it from the previous owner
2001 MSM
LAKERS!
acrylick is offline Reply With Quote
Old 04-27-2009, 08:17 AM   #10 (permalink)
SupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community memberSupraMan1784 is an elite community member
nice DIY +repz
2005 MSM Lexus IS300 5-Speed
Stock?
SupraMan1784 is offline Reply With Quote
Old 04-27-2009, 06:28 PM   #11 (permalink)
Very similar. I was a little worried about it not matching but it looks great.
I will be ditching them. The plan is progressing as expected.
Originally Posted by zet View Post
nice bumper
Thanks!
Yea, it was totally worth it. The prep took the longest but in the end, you are left with basically a new set of rims.
Rep to those who complimented.
Old 04-27-2009, 08:49 PM   #12 (permalink)
Riot is an unknown at this point
im a fan of painted stock rims, good work!
Riot is offline Reply With Quote
Old 04-27-2009, 09:03 PM   #13 (permalink)
noudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community membernoudles is an elite community member
great DIY! i definitely need to do this to my wheels.. curb rash on my stocks annoy me terribly. +rep
2oo2 Lexus IS300
-Completely Stock [lol]
noudles is offline Reply With Quote
Old 04-28-2009, 05:57 PM   #14 (permalink)
Steeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community memberSteeda is an elite community member
looks awesome!!!! Thanks for the DIY
Steeda is offline Reply With Quote
Old 04-28-2009, 06:05 PM   #15 (permalink)
1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member1GenIS is an elite community member
Great job, cant wait to see them on the car! Rep for the pics
1GenIS is offline Reply With Quote
You may not post new threads
You may not post replies
vB code is On
