b
Go Back   my.IS - Lexus IS Forum > 1st-Gen IS300 > Inside & Out
» Log in
Not a member yet?
Register Now!
» Wheel & Tire Center
Sponsors
Sponsors
Old 12-02-2009, 10:54 AM   #76 (permalink)
IanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community memberIanH is an elite community member
Originally Posted by DenverCruiser View Post
So why would it be any harder than to 1. Get key cut. 2. Swap key remote from one old busted shell to new shell?
yes that works.
I brought new shell and two of what i believe is a used core in a new shell.
Got them cut.
Changed my old core into new shell.
programed both new "used" core in new shell.
didn't have an issue with the 4 max immobilizer, it must just overwrite the other keys.
BTW got my shell with Lexus L and complete key / cores from remotes4less.com
they shipped me the RX300 by mistake, got an RMA and shipped back, they sent correct ones very fast. no problems reaching them by phone.
and they work fine.
2004 IS300 MSM LSD Manual 5 speed.
2003 Pathfinder SE 4WD
IanH is offline Reply With Quote
Old 12-15-2009, 06:47 PM   #77 (permalink)
dewsc is famous around these partsdewsc is famous around these partsdewsc is famous around these partsdewsc is famous around these partsdewsc is famous around these partsdewsc is famous around these partsdewsc is famous around these parts
Thanks for this tread is was great and very helpfull.
dewsc is offline Reply With Quote
Old 12-19-2009, 10:53 AM   #78 (permalink)
Street Sniper is an unknown at this point
Ok, here's one for you...
I bought the car used and it came with a non-remote key that I use to start the car and a blank remote key that I use as the remote. Upon inserting the cut key into the ignition, the "security" light stays lit for a couple seconds and goes off. Obviously, this is a valet key. When I try to insert the blank into the ignition, it will only go in about 1/2" but the security light goes off immediately.
Does this mean that I have a blank master key and I just need to get it cut? Is that even possible? To have a blank master?
Powered by YooHoo... tuned by G-Tech.
Street Sniper is online now Reply With Quote
Old 12-19-2009, 12:14 PM   #79 (permalink)
Welcome to Lexus Key Hell !!!
Yes it sounds like you have the master remote with the transponder chip in a new shell.
So yes just get it cut.
But if you really have a Valet key you should get it cut at a Lexus dealer or someone else from the key code because the Valet key normally doesn't open all the locks, however since I dont have a valet key I cant be sure about this for the IS300....anyone else comment ?
What i am getting at is not to copy the Valet key onto your new key
Old 12-19-2009, 12:16 PM   #80 (permalink)
And get a new master and get it programed before you have a problem with your one master module.
Old 01-07-2010, 05:22 AM   #81 (permalink)
bswizzle is an unknown at this point
What if I wet my key and my only transponder is not working can I buy one from eBay and reprogram it my self.
bswizzle is offline Reply With Quote
Old 01-07-2010, 07:56 AM   #82 (permalink)
REDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community memberREDL1NE is an elite community member
Very informative, thank u. Bookmarked!
1997 SUPRA SINGLE
2002 IS300
REDL1NE is offline Reply With Quote
Old 01-08-2010, 05:50 PM   #83 (permalink)
Location: 87.9 mi – about 1 hour 42 mins from east parking lot
black86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community memberblack86 is an elite community member
alright i found i found the directions for the transponder (engine immobiliser). as far as i know both the wireless and transponder programming, the following instructions, only work for 02-05 (1st gen) is300 WITH a working master key.
heres a post to do the "Wireless Door Lock Control Programming" http://my.is/forums/4020231-post30.html
i had to use these instructions on two ocassions
deleting all existing keys. so no one else can unlock using the wireless, and no one can start it. then added the new/existing keys.
also vald_a had a way to further enhance the stock security system. you have to pull out the driver side door/window control switch and either cut or de-pin a green/black wire. by doing so, this activates the stock alarm even if someone manually opens the car (ie, the key that was deleted but can still physically open the car) but they cant drive away!
sauce
MAZZURI V2! toke'd
help...? VOLKS FOR SALE!
black86 is offline Reply With Quote
Old 01-16-2010, 02:57 PM   #84 (permalink)
admanc is an unknown at this point
Worked like a charm. Thanks!
I called my Lexus dealer a few months ago to ask about getting some new keys cut for my car. They quoted me $200+ for each key, including the cutting and the labor of programming them. I went online and saw this thread, went to e-bay and bought two new keys for $60 each. I took them to the dealership and had them cut the keys for $18 each, went home and programmed them to my vehicle. It took a couple of tries for each key, but they both work great now. All in, it would have cost me over $400 at the dealership, but this way, I'm only out $156. That's a big difference I can be happy about. Thanks very much to the original poster who provided these directions!
admanc
Chicago
2004 Onyx IS300/Automatic
admanc is offline Reply With Quote
Old 01-23-2010, 12:29 AM   #85 (permalink)
da69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community memberda69cote is an elite community member
AWESOME thread very helpful! saved me some coin on getting a new key reprogrammed! THANKS A MILLION.
da69cote is online now Reply With Quote
Old 02-04-2010, 01:44 PM   #86 (permalink)
macktownboi is an unknown at this point
Originally Posted by 410IS300 View Post
Remote Programming
6. Put key into ignition. Turn to "ON" , turn off and remove.
7. You will see the door locks cycle by themselves.
For this step, what ifi order a used key with remote, to program just the remote. will it work? Meaning the used key won't be able to switch the ignition. How can i just used it was a wireless remote? Like the other toyotas and hondas...
macktownboi is offline Reply With Quote
Old 02-06-2010, 03:50 AM   #87 (permalink)
ryan555 is an unknown at this point
anyone tried bypassing the immobilzer? so you dont have to program keys, and just start the car without the chip, and use an aftermarket alarm for opening the doors and popping the trunk?
ryan555 is offline Reply With Quote
You may not post new threads
You may not post replies
vB code is On
