Hiya all
New IS200 SE owner (UK 2004)
Need help with remote bit. Been about a week now, tried for almost 3 hours, so now asking for help please.
Got a blank key (with transponder) cut and got the "Key Programming (Starter Chip)" bit working, new key will now start engine, security light goes out on inserting this new key.
"Remote Programming":
Car locks don't cycle, don't think the car goes into programming mode.
Noted also that occasionally during the process the security light starts flashing very rapidly.
Questions:
*) I'm assuming that for "Remote Programming", you do not need to do anything with the pedals and that I can now forget about the immobiliser part of the procedure.
1) Close and lock all doors. Unlock and open drivers door.
-How do you unlock the driver's door? Power switch or normal latch? Because the power switch would unlock all the doors.
2) Put key into ignition and remove. Do not turn it on.
-Is this key the original master or the one I want programmed?
4) Close and open drivers door.
-Does it need to be fully open or just a fraction?
-I have noticed that it is variable as to whether the dome light comes on.
7) You will see the door locks cycle by themselves.
-Never make it here
-Actually did make it once but got flustered & fluffed it up, don't recall if it was single or double lock cycle.
Help please
