Originally Posted by Coffee & Cream
Ok this is really starting to annoy me. It does not want to go into programming mode.
I get in the car.
Close the door. Lock it, unlock it (using the electric switch). Open the door.
Insert key, take it out.
Press Lock, unlock 5 times (using the electric switch).
Close door, open door.
Insert key, turn it to the "On" position, turn it to the "Lock/Off" position.
.....Nada. Tried 10+ times now.
Can anyone tell me what I am doing wrong?
Yeah...
Start with a locked up car. (use the original keyless unit or whatever)
Use your new key to unlock the driver door (using the keyhole)
open the door, keep it open!
Key in the ignition, then pull it out
5x lock/unlock
close the door, then open again, keep it open
5x lock/unlock (make sure you're hitting lock first)
key in ignition, turn it all the way to "ON" (just before turning it over)
key out - at this point, the locks automatically lock/unlock x1
hit the lock and unlock buttons for a second
then hit the lock button - this should lock the doors
open and close driver door.
