Can I change oil filter without draining oil? - Lexus IS Forum
post #1 of 16 (permalink) Old 08-05-2010, 06:07 PM Thread Starter
I've tried to change oil / oil filter yesterday for the first time.
Drained oil, wrestled with installed stock Toyota filter for 1 hour and gave up.
So I put new oil with and I'm driving with old filter today.
I'm getting proper oil filter cap wrench from NAPA today and will try to replace filter again.
Question is, do I need to drain oil again? Filter seems to be high on engine.
Can it be removed without draining oil? I have no idea where that oil level is.
IS300, 2003
vasiliy is offline
post #2 of 16 (permalink) Old 08-05-2010, 06:18 PM
Quoted: 18 Post(s)
Yes you can remove the filter with out draining the oil. You can remove it from the top of the vehicle.
Remove your tranny dipstick (auto only) and guide the filter out. This will be doable depending on how worn your engine mounts are. If you dont have enough room, get someone to get a pry bar to pry the engine a lil bit so you can get the filter out.
Boost and Stuff- 2004 CW Turbo IS300 5MT LSD
354rwhp / 320lb ft @ 7.5PSI
Daily and Stuff- 2003 AR IS300 5AT LSD
rL-gT is offline
post #3 of 16 (permalink) Old 08-05-2010, 06:32 PM
Bezik777's Avatar
Quoted: 36 Post(s)
Ive never had to pry or move anything to get filter out ...its snug bit it will come out ...
remember when you put new oil filter on put a little oil on the gasket and dont over tighten the oil filter on....
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #4 of 16 (permalink) Old 08-05-2010, 09:57 PM
For some reason mine wont come out unless I take the ECU cover off, and then it is JUST the right size for the oil filter to come out. There is a hose that will be in your way and you have to use magic to push the hose to go around and behind the filter.
Ryushenshi is offline
post #5 of 16 (permalink) Old 08-06-2010, 03:08 AM
I usually go from the bottom. I used to chart a complicated course of forwards, reverses, twists and inversions to get out through the top, but life is too short.
My pix whoring thread
Johnnysks is offline
post #6 of 16 (permalink) Old 08-06-2010, 10:19 AM
lol idk why people have such a hard time with it, it only takes 2 minutes for me to take mine out
Erin 2004 MSM IS300 MT LSD
~BC Racing Coils 14k/12k, HKS Carbon Ti, Wald Lip & Skirts, Joe-Z Intake, Manaray VR5 18x8.5
TofuMaster is offline
post #7 of 16 (permalink) Old 08-06-2010, 12:06 PM
Quoted: 35 Post(s)
there's geometry involved gotta come out at the "right" angle when it's against the intake manifold
-Mike
MY2J is offline
post #8 of 16 (permalink) Old 08-06-2010, 02:48 PM
Seriously
- Greg '03 BO SD 5-spd.
Originally Posted by EricK
I'm a f#$%&r then
MrGregski is offline
post #9 of 16 (permalink) Old 08-06-2010, 03:40 PM
Under House Arrest
mikefate's Avatar
It comes out eAsy top or bottom. If you ate messy or filter is too hot. Use a gall size ziploc. After unscrew filter let it drop in bag and seal it. Then you won't make a mess maneuvering it out.
And you can easily puncture a new filter putting it on. I highly frown upon using a wrench to put new filter on. Screw on by hand, make contact, and give it one turn. The pressure will pull the seal tight.
mikefate is offline
post #10 of 16 (permalink) Old 08-06-2010, 03:54 PM
gwl
I recently acquired an IS300, the old filter was a little smaller than the new one. It was quite easy to maneuver the old filter out from the engine bay. The new Mobil 1 filter took a little twisting to get it under the intake manifold.
2003 TCM SportDesign
1965 Malibu SuperSport
1997 Civic Hatch - Road Warrior now at 277,000 miles
gwl is offline
post #11 of 16 (permalink) Old 08-06-2010, 03:58 PM
Under House Arrest
mikefate's Avatar
I've used mobil1 filters, fram, purolator, wix, Toyota oem, Toyota japan oem filters. They are all easily accessible from top or bottom. Both manual and auto is300s. I can speak from hands on experience.
I find bottom easier and less messy and least chance of burning your forearm on a hot intake manifold or hot filter.
mikefate is offline
post #12 of 16 (permalink) Old 08-06-2010, 04:33 PM
Yeah, I use a plastic bag myself - no mess, easy to do.
I'm a f#$%&r then
post #13 of 16 (permalink) Old 08-06-2010, 06:46 PM Thread Starter
Thank you everybody for replies.
I replaced the filter. And I did not drain the oil again, which is nice.
I went from top. It did not take long. With "cup type oil filter wrench" it did not take long to take it out. No Pry-bar or engine dis-assembly required.
I've tried to use plastic bag, but it is almost impossible to hold the bag and turn the filter simultaneously. I could use only one hand there. So there was some "oil spill".
Next time I;ll try to go from bottom. Should be easier.
MrGregski, are you going from the top or bottom? I'd like to learn how to avoid spilling oil.
IS300, 2003
vasiliy is offline
post #14 of 16 (permalink) Old 08-08-2010, 08:28 PM
i feel like an idiot to have never tried the ziplock trick. ive been a tech for 8 yrs now and i normally just remove all the undertrays and liners a clean up the mess afterwards. might try this trick this week. i wouldnt think twice about just topping off the oil if you only switch out the filter. thanks
1986windsor is offline
post #15 of 16 (permalink) Old 08-08-2010, 09:27 PM
g55
Had the same problem the first time but i just muscled it out. And i always go from the top. But never had this problem again i have a theory . When installing it always put oil on the seal and hand tighten it when its tight just turn it a little to the left just a tab so the seal is position like its coming off so next time you change it its easy coming off. Ever since never had a problem.
g55 is offline
