Replacing Strut Mounts - Lexus IS Forum
post #1 of 14 (permalink) Old 02-11-2012, 01:13 PM Thread Starter
I am replacing my suspension and my mechanic said when i do it im going to need new strut mounts.. i spoke to lexus they said factory mounts from them are going to cost $400.. does anyone know of aftermarket mounts? i found some kyb front mounts but cant find any rear mounts.. any help would be great!
bluebird03 is offline
post #2 of 14 (permalink) Old 02-11-2012, 03:55 PM
Yogujuhere's Avatar
Why do you need all 4 replaced? Are they damaged? I'm sure you can still use them, I haven't seen one yet thats damaged. The only thing I've ever seen was a stud snap off the mount. At any rate,
http://www.autopartswarehouse.com/sh...xus/is300.html
For around $90 you can get all 4. Note the rear is only replacing the bushing, not the whole assembly. Again, these things don't really go bad. My car had total 100,000 miles on stock mounts and I looked at the mounts and they look damn near new...
Don't waste your money...
If you need a real shop to look at everything for you and install things, you can call Tach Motor Works, 516-608-9930. They do all things IS300 and they're in NY. Ask for Lucky.
By the way, OEM is CHEAP. $60 for each front mount and rear is like $20 each side for the bushing cushions (upper and lower). --> total is around $160.
You can get them at L-tuned parts (Carson Toyota).
Fully Built 2JZGTE VVTI , HEADGAMES Ferrea Head, FOUR RINGS Perf. Block, IP Cstm Pistons/Manley TurboTuff/Calico/ARP
Precision 6766HP CEA, 272 VVTI Cams, STG3 V160, Clutchmster Twin, ETS Twin Scroll, Tial, GS400 Rear, TRD LSD, Supra Axles,
Stoptech 4Whl BBK, Full Figs Suspension, KW V3, ProEFI 128, ID2000, Squash DBL Pumpr, Dual Tanabe Exhst
Check out my Build Thread =) Hiral's Build Thread
Yogujuhere is offline
post #3 of 14 (permalink) Old 02-11-2012, 04:12 PM Thread Starter
Lexus IS300 Shock and Strut Mount - Free Shipping - KYB, Monroe
at auto parts warehouse what should i be looking to buy the kyb fronts and what else? thanks for the help
post #4 of 14 (permalink) Old 02-11-2012, 04:36 PM
Yogujuhere's Avatar
Print it out and show it to your mechanic and ask him what you need.
post #5 of 14 (permalink) Old 02-11-2012, 05:03 PM Thread Starter
Thanks will do! I appreciate the help man
post #6 of 14 (permalink) Old 02-12-2012, 10:43 PM
i think you may be replacing the strut mount bushings, not the actual strut mounts. there isn't a reason to need to replace the studs unless you snapped one in half. the bushings on the other hand wear out after 10 years / 100k miles.
02' Crystal White e-Shift
Koni Yellows / Eibach Prokit / Hotchikis Sway Bars
Cusco Camber Kit / Megan Traction Bar / Stomptech SS Lines
af22 is offline
post #7 of 14 (permalink) Old 08-04-2014, 12:27 AM
Does anyone know why the strut mounts have a (L) and (R) on them and also arrows? They seem symmetrical so I'm not getting it. I searched the net and no one really talks about it. thanks.
mumathew is offline
post #8 of 14 (permalink) Old 08-04-2014, 07:22 AM
Quoted: 462 Post(s)
The center shaft hole isn't symmetric. It leans. The L and R are telling how to position the top hat when you install them on the SHOCK. You're right though, nothing is documented. I position the top hat so, the arrow points forwards and in the direction of the letter so, L = arrow pointing to the left front. I don't know if this is correct but, it seems to work for me.
I know I'm being pedantic but, we don't have struts. We have coilover shocks. The difference between a strut and a shock is a strut is structural, it actually holds the top of the wheel into place. A coilover shock, is just a shock, with a spring around it. It doesn't actually hold the wheel on.
post #9 of 14 (permalink) Old 08-04-2014, 07:55 AM
I had a place do my shocks a few years ago and they didn't bother using the arrows for anything so it may be backwards. I'm going to look into it. Thanks for the quick reply.
mumathew is offline
post #10 of 14 (permalink) Old 08-04-2014, 08:31 AM
Quoted: 462 Post(s)
The top of the mount is a rubber bushing so, I imagine it's just bending in the direction it needs to bend. If you're not having any issues, I probably wouldn't mess with it.
post #11 of 14 (permalink) Old 08-04-2014, 06:13 PM
Does anyone else have any other info on this as to whether or not it matters which way the arrows point?
mumathew is offline
post #12 of 14 (permalink) Old 08-04-2014, 06:38 PM
Quoted: 462 Post(s)
Use a bit of logic.
Do you think Lexus would mark them if the marks weren't supposed to be used? If they were truly symmetric they wouldn't have marks.
post #13 of 14 (permalink) Old 08-04-2014, 06:57 PM
Use a bit of logic.
Random arrows don't tell much of a story. The shop manual doesn't mention anything about arrows. I was planning on rotating the strut mounts but was hoping for more info on this.
mumathew is offline
post #14 of 14 (permalink) Old 08-04-2014, 08:03 PM
Quoted: 462 Post(s)
More power to you.
I just reinstalled mine the other day. Removed lowering springs and swiched to GC coilovers on Koni shocks. It's so much easier to do with GC's. Don't even need a spring compressor. Remember, everything has to be lined up before you release the spring compressor. The top hats and the ABS Sensor mounts.
