So one more time, HEADERS! - Page 4 - Lexus IS Forum
Closed Thread
post #46 of 78 (permalink) Old 04-14-2009, 05:32 PM Thread Starter
truth versions only
Originally Posted by silver5spd View Post
I wrote them down before I installed my header, but since I have lost the data.
All I remember is that the shortest runner was appx 18 inches and the longest 24. Roughly
Owe you some rep.
I am curious though, what is the diameter of the primary and secondary runners? Can you get those for me? I know being installed you can only get the external/outside diameters but that is enough for what I am looking at
kponti is offline
post #47 of 78 (permalink) Old 04-15-2009, 05:56 AM
Originally Posted by kponti View Post
Owe you some rep.
Um....Ya I am sure I will be able to stick my measuring device somewhere in the engine to measure the primary/secondary OD runners. I will do that after work.
"I took out a live insurance policy and used that as collateral to get a loan to buy apple stock. This way if I lose money I can just kill myself and get the money back. Win-Win!"
-Justin.b
silver5spd is offline
post #48 of 78 (permalink) Old 04-16-2009, 12:14 PM
So here is another twist on the issue. First a question, What is the Stock diameter and length of the runners? If they are the same as the aftermarket headers and designed to work with stock internals (which according to others in this forum the after market headers are designed to work with stock internals as well) Who better to the designe a header that has the right length and diameter for the proper scavanging effects than the Engineers that designed the stock header. So here is my suggestion, you are already going through the effort of cutting and welding why not take the stock headers and cut the CATs out and weld in Striaght pipes the same diameter of the of the CAT pipe? The CATs are the main restriction point on the Stock header right? Just curious as to how this may, or may not, help your research. Thanks for reading my rant.
Scott
Scotte30M3 is offline
post #49 of 78 (permalink) Old 04-16-2009, 04:49 PM
The stock header is a stamped POS that was designed to be easy to manufacture and package
Cobra Project:
longnights is offline
post #50 of 78 (permalink) Old 04-16-2009, 05:24 PM
Another reason why I bring this my question to bair, If you look at the OBX shorty Header they look a lot like the Stock header with no CATs.
post #51 of 78 (permalink) Old 04-16-2009, 06:57 PM Thread Starter
truth versions only
Except look at the merge. Even the stock header has a continuously merging collector between the primary and secondary runers. The dumped collector is my biggest problem with the OBX. Short runner headers make the most HP up top with the lowest low end power. However if you notice, the OBX does not make anymore power than say the Megan/Mazzuri or Xerd.
kponti is offline
post #52 of 78 (permalink) Old 04-17-2009, 10:05 AM
Weren't there some tubular headers from Lexus installed on a GS300 sold in australia or somewhere. I think they were pretty basic but maybe you can get some insight from those as well.
evangelp is offline
post #53 of 78 (permalink) Old 04-17-2009, 12:46 PM
It would probably have fitment issues on our North American cars as the the Ausies are all right hand drive.
post #54 of 78 (permalink) Old 04-20-2009, 07:59 PM Thread Starter
truth versions only
Ok got the info on the Megan/Toyomoto/HP styled headers and surprise surprise, they are bigger than the rest. Thanks to IS3_FTW!!!
So a recap (will also update the first post):
Xerd:
Primary=1.36"-int; 1.5"-ext
Secondary=2.1"-int; 2.25"-ext
Mazzuri:
Primary=1.34"-int; 1.5"-ext
Secondary=1.88"-int; 2.0"-ext
Megan styled:
Primary=1.5"-int; 1.6"-ext
Secondary=2.13"-int; 2.25"-ext
That can explain a bit why the Megan type seem to hold power up top over at least the Mazzuri. However the difference between the Megan and the Xerd (0.14" or 3.6mm) is small enough to where I am not so sure the diameter difference matters all that much.
At this point, I am not so sure we necessarily need another Mazzuri to make the power of the Mazzuri full exhaust. That exhaust made 24rwhp and about 30rwtq. But that was a full 3" exhaust plus the very long runner header with a very good component, merged collectors!
The Xerd header plus Ypipe, coupled to the HKS exhaust made 17rwhp and over 20rwtq (dyno tested and reported in the DIY section on this site by Tony the site admin)
I think we can simply swap collectors on either the Megan or the Xerd and make nearly the same power as the Mazzuri most likely more. It seems the primary runners on the Mazzuri are not nearly as equal as we initially thought with as much as 7" difference between them
kponti is offline
post #55 of 78 (permalink) Old 04-21-2009, 11:54 PM
is300cb's Avatar
Xerd:
Mazzuri:
Megan styled:
That's exactly what I ran back ....back ....back in the day.
SRT intake, HKS cam gear, Xerd header, oem Y & B, HKS Hi-Power. I can remember exactly what I dyno'd, the above numbers sound about right. I might have a dyno on my old computer, I'll check it out. Lol, heres an old youTube vid
----467rwhp IS300 -sold----
---402rwhp CTS-V-sold---
--321rwhp M3 vert-sold--
-429rwhp e92 335i- 538rwhp CLS55 -
is300cb is offline
post #56 of 78 (permalink) Old 04-22-2009, 01:05 AM
I believe you can still get an XERD header, one of our vendors- MVP has this on their website; (it looks a little different, though?)
Originally Posted by MVP Motorsports 2JZGE Header!
Part # MVP Header SC
How does 17rwhp for less than $500 sound? That's exactly what the MVP Motorsports Exhaust Manifold gives you. For years people have been using the XERD Exhaust Manifold and while it's always been a great product, the service from XERD has been poor and has resulted in this item being very hard to get.
Not anymore! MVP has contacted XERD's manufacturer direct and is bringing it to you at the same price as before while keeping it in stock at all times for quick delivery.
When it comes to increasing horsepower on the Lexus, nothing comes close to offering the gains for the money spent as the MVP Exhaust Manifold does!
It's listed at $449.00 on their site but pm Chops@MVP and see what he can do for you.
Or... you can buy used from our marketplace forum
Moderator Old School.
DonCorleone is offline
post #57 of 78 (permalink) Old 04-22-2009, 11:32 AM Thread Starter
truth versions only
So I think we may have found another way to get what the Mazzuri offered with better fitment and more top end power. IMO this is how it should go.
Stock camshaft/stock heads/bolt ons
= 1st Mazzuri will be the best overall; 2nd Megan/xerd with merged collectors; 3rd Megan/xerd out of the box
HKS/BC camshafts(264)/stock heads/bolt-ons = 1st Xerd with merged collectors: 2nd Megan with merged collectors will be a close second: 3rd out of the box Mazzuri/Xerd/Megan
Reworked heads/Camshafts (264 or 272)/TB with modified intake manifold/bolt-ons = 1st Megan with merged collectors; 2nd Xerd with merged collectors; 3rd Megan and Xerd with dump collectors; 4th Mazzuri will be last here (probably not really even worth it at this point)
This IMO will be the best order for picking headers. You have to match your setup with your exhaust, so if you are sure this is the route you are going (especially in the near future), this will be the way to go.
I have the Xerd header in my possesion and will be doing some dyno testing between the Xerd with merged collectors against the Mazzuri this summer. After which I will be installing camshafts and repeating the dyno tests
kponti is offline
post #58 of 78 (permalink) Old 04-22-2009, 01:24 PM
[QUOTE=kponti;5833869]So I think we may have found another way to get what the Mazzuri offered with better fitment and more top end power. IMO this is how it should go.
So, from what you are saying, mazzuri still offers more hp/trq for bolt-on setups like myself. I only have aftermarket intake/exhaust cam/2.5"exhaust on a auto 01. I installed the mazzuri V2 couple months ago, I do notice a lot of low end torque loss and relatively gain on the high end(cuz I don't drive on high way that much). I will try get it dyno this summer and see how much I got out of the whole set up.
BTW: Thank you for your hardwork and efforts at providing these valuable info to myis members!!
2001 TRD LSD + TRD FINAL GEAR 4.1
LTUNED/TEIN/VIS/SEIBON/ESCORT/GRAMLIGHT/JVC/ALPINE/COMPUSTAR
aznbboytse is offline
post #59 of 78 (permalink) Old 04-22-2009, 02:55 PM Thread Starter
truth versions only
Sounds pretty good. I had the Dragger cos I felt the Hiper had too much drone, but not too bad
kponti is offline
post #60 of 78 (permalink) Old 04-22-2009, 11:11 PM
megan header
hondatech44 is offline
Closed Thread
