Official IS300 Cam/Head Thread - Page 6 - Lexus IS Forum
 3Likes
post #76 of 88 (permalink) Old 01-20-2015, 07:39 AM
if you had other supporting mods, the tune would give you even more
lazyIS is offline
post #77 of 88 (permalink) Old 01-20-2015, 09:28 AM
Quoted: 224 Post(s)
I've seen people get 10+ whp on just a tune, so a tune and cams should make for a very nice feeling car. Not fast, but more alive.
The Nuke is offline
post #78 of 88 (permalink) Old 01-20-2015, 10:00 AM
I agree 100%. hence i'm waiting for headers before I get a tune too.
most people also get the cam gear, IMO it didn't do much, and if you are on automatic, you will get a CEL once in a while due to rough idle. its not an issue as it goes away after a few hundred miles, just a nuisance. after all that, the car is not fast, but does make it come alive, and as a DD it's great.
lazyIS is offline
post #79 of 88 (permalink) Old 01-20-2015, 11:38 AM
Quoted: 224 Post(s)
I will do cam gear as well, not for huge power gains by itself, but all the little things add up after awhile. Plus, I plan on doing some suspension/braking adds, so while it won't be fast it'll be a lot more fun to drive. :D
The Nuke is offline
post #80 of 88 (permalink) Old 03-16-2015, 09:43 AM
Quoted: 10 Post(s)
Originally Posted by franco305 View Post
Guys valves are getting super loud! Almost like a tickling noise. I tighted them to oem specs. Why nobody adjust the valves to what crower says?
Problem fixed, by reshimming them again. There were 2 shims that were a little loose on the intake side and we did not notice the first time (weird, maybe they move once they set in). I set clearance to the really tight side of oem specs and now at least the tickling noise is gone, but engine stills sounds like a train, a normal train though (compared to a customer's stock is300 it sounds the same).
A big plus to adjusting valves is that this time we used the toyota valve adjustment tool and an air compressor to literaly blow the shims away. The magnet stick does not work because it is too weak.
Thank you for the help guys
franco305 is offline
post #81 of 88 (permalink) Old 04-20-2015, 11:14 PM
Quoted: 30 Post(s)
most people also get the cam gear, IMO it didn't do much, and if you are on automatic, you awill get a CEL once in a while due to rough idle. its not an issue as it goes away after a few hundred miles, just a nuisance. after all that, the car is not fast, but does make it come alive, and as a DD it's great.
Q: So, e-shift/autos have a rough idle @ 1st after install? (& I'm assuming you're referring to the 264's)
'03 IS3: http://my.is/forums/f87/juicij36s-la...3/#post7846401
suspension:TeinSS/JICMagictower/CuscoAarm/CuscoTypeOS/Hotchkisanti/FIGStoe/FIGStraction/SRTsubframe/TRDlowerarm; engine/exhaust:BrianCrower264/HKSslidecam/SRTHFIw/AAFC/UnorthodoxRacingUltraSS/Dezodredhead/HKSCarbonTi; wheels/tires:WORKVS-XX/BridgestonePotenza; brakes:Rotora355X32; body:LSportline/TRD; lighting:AAC/Xetronic
juicij36 is offline
post #82 of 88 (permalink) Old 04-21-2015, 07:20 AM
Quoted: 17 Post(s)
nothing of this sort happened with my auto after i put in the 264's. unplugged the battery before first startup and smooth sailing since. and no CEL.
10roller is offline
post #83 of 88 (permalink) Old 07-13-2015, 06:40 AM Thread Starter
Bezik777's Avatar
Quoted: 36 Post(s)
Cams (264) shouldn't have ruff idle ..timing off or aftermarket cam gear (exhaust) adjusted wrong ,re check everything...
juicij36 likes this.
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #84 of 88 (permalink) Old 07-13-2015, 07:58 AM
Quoted: 30 Post(s)
Good news.
Being installed now; I'll find out shortly.
juicij36 is offline
post #85 of 88 (permalink) Old 12-15-2015, 01:47 PM
Good to know that there are cam options that will play nicely with OEM ecu and tune. Though I wonder how much of a difference you will see between a very basic cam with no changes VS an aggressive cam with a tune to compensate for differences. I guess the biggest deciding factor would be how much would it be to install a mild cam vs a moderate one plus tune divided by the price. Bang for Buck yo
Royale is offline
post #86 of 88 (permalink) Old 01-10-2016, 02:55 PM
Been driving with BC 264s for a year now, 15,000 miles later, still no CEL, solid AFRs everyday and such a blast to drive. My full BC head package is wonderful and brought new life to the car. By far the best mod i have done to my car in the over 3 years I have owned it. Do not even think twice about installing these cams. An intake and exhaust combo costs just as much and cannot beat the performance at all, get these and worry about supporting mods after!
2003 Mustang GT - Sonic Blue(sold)
2004 IS300 - GGP - 5 Speed Automatic - LSD
ACL - AEM - ARP - Brembo - BC - Eibach - Fidanza - Goodridge - NGK - Magnaflow - Megan - Mishimoto - Injen - PHR - Seibon - Spyder - Titan - Token Solutions - Tokico
Ciummo is offline
post #87 of 88 (permalink) Old 10-22-2016, 04:39 PM
I know this is old, but are there hotter spark plugs for us, and is so do they help in this car. I used Split-Fire in my old 85 Yota 4x4 w/31x11.50s, and 4.11 gears, and I did notice a difference. But, apples and oranges.
CanIHasFI is online now
post #88 of 88 (permalink) Old 01-23-2017, 12:41 PM
Quoted: 12 Post(s)
compression ratio for 264 cams and 1.3mm hg for turbo build
I posted my question in wrong thread possible here's link 2jz-ge, compression ratio w/cams just wondering ratios with set ups if known trying to calculate my build.
pfunkmixer is offline
