Official IS300 Cam/Head Thread - Page 5 - Lexus IS Forum
 3Likes
post #61 of 88 (permalink) Old 02-05-2014, 02:16 PM
Quoted: 15 Post(s)
Originally Posted by lazyIS View Post
after getting them installed and dyno'ed they gave gains of 11+whp on e-shift
dunno about MPG, but after 2 weeks of them it seems similar
how is the powerband compared to what others have stated in this thread? comparable?
02 E-Shift GTE INTERNALS l BC264 l PTE6262 l AEM V2 l FIGS RB BBK l FORTUNE AUTO
461whp/404lb-tq Built and Tuned by JMS Racing
IG: j_is3k
IS-ZERO is offline
post #62 of 88 (permalink) Old 02-06-2014, 05:30 AM Thread Starter
Bezik777's Avatar
Quoted: 36 Post(s)
Why don't you believe us?!?!?^^^€
Mpg don't change do to 264 cams it's your right foot that decreases mpg.
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #63 of 88 (permalink) Old 02-06-2014, 06:44 AM
yeah everything that needs to be said about cams have been repeated many times
my experiences are exactly the same as others that have posted on here
lazyIS is offline
post #64 of 88 (permalink) Old 02-06-2014, 08:39 AM
Quoted: 15 Post(s)
Its not that I dont believe you'll...trust me ive taken the tanagable feedback completly to heart.. thats why I intially bought them, it just sucks i had to sell them :/ just wanted another persons view since every driver is different
thanks lazyIS
IG: j_is3k
IS-ZERO is offline
post #65 of 88 (permalink) Old 02-06-2014, 11:14 AM
[QUOTE=Bezik777;7317617]I was going to say sounds like plugs or plug wires or timing issue....keep me updated
ended up bein an issue with my emanage ultimate started loosing spark and idle worsened. anyway it wasnt a cam issue set back to 0 now
polish man is offline
post #66 of 88 (permalink) Old 02-06-2014, 03:09 PM
Quoted: 16 Post(s)
Thats good to hear.
Am I correct that its an initial bolt-on part and be done with OR if you want to fine tune, some will go the route of adding a Greddy emanage to piggy back their ecu for optimum results??
Thanks!
Rayson is offline
post #67 of 88 (permalink) Old 02-06-2014, 08:05 PM
Originally Posted by Rayson View Post
Thats good to hear.
Thanks!
For the most part, you're correct. Many have been able to simply install the cams, and call it good with a noticeable difference in the feel and power of the ride. I haven't seen an instance yet where you needed to re-shim, but it's good practice to verify this upon install. I can't speak for the greddy emanage, but I'll bet Bezik777 will chime in regarding engine management and tuning.
________________
'02 AR IS300
Stance GR+ / Work
My Build
jimboozy is offline
post #68 of 88 (permalink) Old 02-07-2014, 02:10 PM
Quoted: 10 Post(s)
Guys valves are getting super loud! Almost like a tickling noise. I tighted them to oem specs. Why nobody adjust the valves to what crower says?
franco305 is offline
post #69 of 88 (permalink) Old 08-08-2014, 10:39 AM
sorry for asking a question that may have an obvious answer but when reshimming to the tight side of oem spec, does that mean very close to the maximum shim thickness? As in slightly less than .010 for intake and slightly less than .014 for exhaust?
2003 Mustang GT - Sonic Blue(sold)
2004 IS300 - GGP - 5 Speed Automatic - LSD
ACL - AEM - ARP - Brembo - BC - Eibach - Fidanza - Goodridge - NGK - Magnaflow - Megan - Mishimoto - Injen - PHR - Seibon - Spyder - Titan - Token Solutions - Tokico
Ciummo is offline
post #70 of 88 (permalink) Old 08-09-2014, 05:18 PM
Quoted: 29 Post(s)
Unless I'm horribly mistaken, which happens sometimes, you want the clearances set to tight side as in smaller spaces between the shim and the lobe. I suppose that would mean the actual shims would be "thicker" too.
You do seem a bit confused so to clarify. The 0.010 or 0.014 are clearance values, not shims. The shims are metal pieces with varying thicknesses, something similar in shape and size to a quarter coin. Every valve has a shim. WHen you install the new cams (or check clearances) you measure the clearance and if it is too loose or too tight you swap in a thicker or thinner shim respectively.
When I did my cams recently I tried to get my intake and exhaust side clearances closest to but not less than the recommended tight side of spec. Intake spec is between .006-.010 inches and exhaust is between .010-.014 inches. For me, all intake clearances were between.006-.007 and exhaust was 0.010-0.011 when I was finished. I did have to move 6 shims around the head but I guess I got lucky and didn't have to buy any new ones. So far so good!
juicij36 likes this.
Savage_IS300 is offline
post #71 of 88 (permalink) Old 08-10-2014, 12:53 PM
Thanks for the info man. I hope I still have good low end once I get these things in
Ciummo is offline
post #72 of 88 (permalink) Old 08-12-2014, 09:20 AM
Quoted: 29 Post(s)
You won't be disappointed. I don't think you will actually lose any power but the bottom end won't "feel" as strong as the rest of the power band because the real gains come at higher RPM. To me it felt like they improved the entire powerband, especially the mid and top end. With the cam gear the car acts a bit like an excited puppy when you go from a complete stop. All excited and not sure what to do with itself and then it just bursts.
post #73 of 88 (permalink) Old 01-19-2015, 05:44 PM
Quoted: 224 Post(s)
Is that with a tune of some sort? Or just on stock ECU?
The Nuke is offline
post #74 of 88 (permalink) Old 01-20-2015, 06:34 AM
Stock ECU
2002 e-shift 230 000km
lazyIS is offline
post #75 of 88 (permalink) Old 01-20-2015, 07:29 AM
Quoted: 224 Post(s)
Stock ECU
Very nice. Based on that, if I tune for it, easily 15+ whp. That will be a very nice feeling. I think I'll be installing these come summer time
The Nuke is offline
