Official IS300 Cam/Head Thread - Page 4 - Lexus IS Forum
 3Likes
post #46 of 88 (permalink) Old 12-05-2013, 03:55 PM
There new coppers on my new motor couldn't find ik22s local and wanted to get it goin last week. But I'll update whenever I change them out
polish man is offline
post #47 of 88 (permalink) Old 12-07-2013, 05:33 PM
Quoted: 10 Post(s)
Yes i got full stock exhaust other than headers.
I already have wheels and good street Nitto tires.
True, coilovers are not everything in a suspension. I did change some of the bushings though (control arms bushings , ball joints), but the suggestion of sway bars definitely sound good to me.
I am still doing some research on the 80mm tb (welding, check engine light, who can do the labor for me here in Florida and other things to consider/understand before i do it). Any good input or where to read about a complete 80mm tb install would help.
And last pulleys also sound good to me (except for the crank pulley, did some research and heard bad things about crank pulley unless is the fluidampr which is as heavy as the oem).
Thanks for the suggestion guys!
Appreciate it.
franco305 is offline
post #48 of 88 (permalink) Old 12-11-2013, 08:19 AM
Right now I have Intake and headers w/ y-pipe and SAFC-II when I get the cams will I have to retune the SAFC?
James3 is offline
post #49 of 88 (permalink) Old 12-11-2013, 08:33 AM Thread Starter
Bezik777's Avatar
Quoted: 36 Post(s)
Franco,
Id like to keep thread on topic but sways and rigid bars would be great adds, there's a couple 80mm TB threads on my.is ( there's no check engine light with this mod) and pulleys are nice add to help throttle response ( URs are nice) yes don't run crank under drive pulley...
* I've done all these mods*
Yes...retune to take full advantage of cams
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #50 of 88 (permalink) Old 12-16-2013, 01:24 PM
Quoted: 15 Post(s)
Ordered my timing belt kit today and said WHAT THE HELL i might as well do some cams! cant wait to get my 264's!
IS-ZERO is offline
post #51 of 88 (permalink) Old 12-19-2013, 05:37 PM Thread Starter
Bezik777's Avatar
Quoted: 36 Post(s)
Very nice!
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #52 of 88 (permalink) Old 12-30-2013, 08:31 PM
Hey guys, I am going to be getting the BC stage 2 cams and cam gear done also. I however have stock headers and exhaust which I do not want to change. Anyone know if there are any cons to this set up? I really do to not want to increase the noise level of the exhaust...I am not a fan of noisy exhaust on non muscle cars.
LxBeef is offline
post #53 of 88 (permalink) Old 12-31-2013, 08:08 AM Thread Starter
Bezik777's Avatar
Quoted: 36 Post(s)
Nope no cons, cams will still make a difference ... Exhaust is just a few extra HP if anything you will retain more lower Torq ..
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #54 of 88 (permalink) Old 12-31-2013, 04:29 PM
Thanks Bezik!
LxBeef is offline
post #55 of 88 (permalink) Old 01-02-2014, 09:24 AM
I'm in the process of building my extra head with all BC parts. As far as cams, ive been looking at the 264's. While researching, i keep reading that stock cams are better for FI cars than going higher duration. any thoughts??
setup is: gte block,gte HG(although want to change back to ge HG) stock head for now/80mm throttle body/water meth/
garrett gtx3076r/93 pump gas/greddy eman ult
02 MSM/gte/ Garrett GTX3076R
MikeNice is offline
post #56 of 88 (permalink) Old 01-03-2014, 01:32 AM Thread Starter
Bezik777's Avatar
Quoted: 36 Post(s)
You've been misinformed ... 264s love boost and out perform stock any day...
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #57 of 88 (permalink) Old 01-09-2014, 06:50 PM
Quoted: 10 Post(s)
Thanks Bezik, I found some good info on the 80mm tb without throwing a check engine light (check engine light was due to something else leak i believe).
So back to the topic.... a different engine noise after installing the cams is normal right? It's hard to describe the new noise,let's say is a little louder on the exhaust side, but just to make sure when re-shimming the valve clearance it had to be adjusted to the tight side of the OEM specs right? That will be intake 0.006" and exhaust 0.010"
post #58 of 88 (permalink) Old 02-04-2014, 09:47 AM
Nice thread good info for us Vvti/NA-T guys.
98 VVTi SC300,Wet 100 Shot of NOS,Front LS400 BBK Calipers painted gold,Goodridge stainless steel braided brake lines,Blacken Emblems,Polished Intake,Tanabe Springs,8k Hid's 6k fogs,Tranny cooler w/fan,EXE Konvex Front 19x8.5,Rear 19x9.5.
14.1@96mph on NOS
NA-T-4" intake,Borg Warner 83-75,Stainless steel manifold,Tial 38mm WG,2 Blitz BOV,Aeromotive FPR,850cc,Twin in tank Walbro fuel pump,FFIM,AEM standalone,Aem Wideband,HKS Cam Gear,Blitz SBC i-D boost Controller(Need to Tune)
98$c300vvti is offline
post #59 of 88 (permalink) Old 02-05-2014, 11:48 AM
Quoted: 16 Post(s)
Seems the cams give more torque and pop and overall more fun to drive factor for our cars...but I read that mpg gets cut to about 14-15 mpg? Is that true? Id like more input from folks who already have this setup..thanks!
Rayson is offline
post #60 of 88 (permalink) Old 02-05-2014, 12:31 PM
after getting them installed and dyno'ed they gave gains of 11+whp on e-shift
dunno about MPG, but after 2 weeks of them it seems similar
lazyIS is offline
