how did you get the o2 sensor in on the y-pipe, my crap hits the wall when i try to put it on with the defouler...did you just have to do some major shoving on the y-pipe?
I just shaved a little bit of that rubber where ur 02 is hitting.
LeX LuGeR aKa Da PeOpLez ChAmP
_____________________________
02 IBP E-Shift
Joe Z Intake
Greddy Evo II Exhaust
Custom Ground Wire Kit
Tokico HP's
Road Magnet Race Springs
JVC 6.5" Double Din
04 Blue Lagoon VW Jetta GLI
UNITRONIC CH!PPED Stage 2
Samco T.I.P.
K&N Typhoon CAI
GFB Hybrid 50/50 DV
Custom 3" Turbo Back Exhaust
18" TSW Snetterton
Nitto NeoGen Tires
KYB/H&R Cup Kit
H&R Race Springs
GReddy Turbo Timer
Custom FMIC Kit
maybe it's in the wrong bungs? I only have 1 defouler on the header itself post cat and no cels for about a month 1/2 now. battery was unplugged for no more than a couple of seconds
In case nobody mentioned on the mazzuri header ypipe there is only 2 bungs for the primary o2's. Your secondary cat effeciency o2's get tucked away so you will need an o2 simulator. Or you can go get 2 more bungs welded in and do this method and solve the problem theorotically. I have not tried it since I will probably just get a simulator for the after cat o2 sensors. and Im wiring both my primarys together as one.
Usually people take the negative battery terminal off for about 10-15mins... I don't know if that is actually how long it takes to reset the ECU, but maybe you just have a bad 02 sensor.
02 IBP E-Shift
Joe Z Intake
Tokico HP's
JVC 6.5" Double Din
Samco T.I.P.
K&N Typhoon CAI
GFB Hybrid 50/50 DV
18" TSW Snetterton
Nitto NeoGen Tires
KYB/H&R Cup Kit
H&R Race Springs
GReddy Turbo Timer
Custom FMIC Kit
man i just got the 2 foulers on and cel still came back? how long do u have to reset the ecu for i only pulled the battery for 15 secs
did you put in a total of 4 non foulers (the longer ones). 2for the 1st bank sencondary o2 and 2 for 2nd bank secondary o2. I didn't have to reset the car, it will reset itself if you put them in right. I have had this for over 2 years now with no problems whatsoever.
hey guys i just put my HP headers and Y-PIPE i have a cel and the trac light is going of and on. i installed only one fouler on the y-pipe and the 02sencer closest to the firewall and i reset the ecu and the cel came back on. what should i do. help help please
Chuck Norris is currently suing NBC, claiming Law and Order are trademarked names for his left and right legs.
