N/A Supra Flywheel/Clutch Swap w/ part numbers and pics - Page 7 - Lexus IS Forum
post #91 of 267 (permalink) Old 01-23-2011, 07:29 PM
Technical Poseur
Quoted: 29 Post(s)
Originally Posted by MrGregski View Post
Smart lady.
Since I didn't follow up on the other thread and only read this page I'm guessing your issue all this time was the clutch/ pressure plate?
I hope to god it is.
-Tom- is offline
post #92 of 267 (permalink) Old 01-23-2011, 07:47 PM
Trov notes of what I missed and made you go with the replacement?
Still want the measurement?
- Greg '03 BO SD 5-spd.
Originally Posted by EricK
I'm a f#$%&r then
MrGregski is offline
post #93 of 267 (permalink) Old 01-25-2011, 05:40 AM
Technical Poseur
Quoted: 29 Post(s)
Its done. What an exhausting day.
Also my flywheel springs were SHOT. There was so much play in the face of the flywheel.
I still need to adjust the master cylinder pushrod back out.
-Tom- is offline
post #94 of 267 (permalink) Old 01-26-2011, 09:57 PM Thread Starter
Flywheel springs on mine were toast too. I had about a full inch of play.
5k miles and still running stong.
Solar Yellow E-Shift (Sold to Balig)
Absolutely Red 5 Speed/LSD (Sold to some skinny dude)
what it IS is offline
post #95 of 267 (permalink) Old 01-27-2011, 05:17 AM
Technical Poseur
Quoted: 29 Post(s)
I need a transmission. Neat. 2nd gear still intermittently....doent exist. 4th grinds if I shift above 3500rpm.
-Tom- is offline
post #96 of 267 (permalink) Old 01-28-2011, 05:27 PM
so from all these problems occuring, would still be safe to get this swap for my car???
please advise!! i'm having a professional shop install this for me. god knows how much the local lexus will charge me for labor!!
jsquareD is offline
post #97 of 267 (permalink) Old 01-29-2011, 06:15 AM
Technical Poseur
Quoted: 29 Post(s)
Dude, the clutch works awesome. I have a bad transmission. I drove on a bad OEM clutch (failing pressure plate, clutch wouldnt disengage all the way) for over a month. I wrecked my transmission doing so. Its not the new clutchs' fault. Many aspects of driving improved quite a bit after the swap...I just waited too long.
-Tom- is offline
post #98 of 267 (permalink) Old 01-29-2011, 11:46 AM
ok so its still good to go? any problems with the install??
jsquareD is offline
post #99 of 267 (permalink) Old 01-29-2011, 01:41 PM
Technical Poseur
Quoted: 29 Post(s)
Removing the pilot bearing from the crank and removing the dowel pins from the old flywheel. Those were the only "problems" at all. The bolt for the bracket from the bottom of the trans to the Y-pipe was rusted but a cutting wheel fixed that...
It might be worth the extra few dollars for new dowel pins unless you have a good acetylene torch.
-Tom- is offline
post #100 of 267 (permalink) Old 01-31-2011, 09:58 PM
any thoughts on ACT clutch with fidanza flywheel? any chatter/vibrations? is it just better to go OEM?
jsquareD is offline
post #101 of 267 (permalink) Old 02-01-2011, 07:25 PM Thread Starter
Let's try to keep this thread focused on its intent. Want to kjnow about the others? Lots of threads already out there.
post #102 of 267 (permalink) Old 02-01-2011, 10:00 PM
well i want to do the N/A swap. just gettin some info
jsquareD is offline
post #103 of 267 (permalink) Old 02-02-2011, 02:53 AM
I did mines this past sunday, haven't driven a manual (stock flywheel/pp) is300 in 1.5 years. mannnn what a difference, i love how responsive it is. i went from auto to manual! sure glad i chose the lighter flywheel over my old dual mass. thanx for all the info on this thread!
+rep to OP
2002 IS300 BO, 6-Speed
2002 IS300 CW, E-Shift → 5-Speed sold
vroomRollLEX is offline
post #104 of 267 (permalink) Old 02-02-2011, 03:59 PM
+rep to OP
any problems on installation?
i'm looking into getting all the parts for this mod as soon as i get enough info from everyone whose done the swap.
jsquareD is offline
post #105 of 267 (permalink) Old 02-02-2011, 04:10 PM
no problems installing at all. I've done motor swaps, and installed turbos and what not, so i knew this was going to be a tedious job, it's not HARD, but its difficult with the room you have underneath the car, you definitely need a few friends to help you.
if you need help or info PM me, where you located if your close maybe I could help you out. good luck! don't get discouraged, the end result is awesome, i missed driving a manual is300
