N/A Supra Flywheel/Clutch Swap w/ part numbers and pics - Page 6 - Lexus IS Forum
post #76 of 267 (permalink) Old 01-16-2011, 10:11 AM
Parts sold, sorry guys. Pms replied
2002 Absolutey Red 5 speed IS300 w/LSD
For Go: RPS street pro clutch kit, CDD+TDD mods, Greddy EVO2 exhaust, SRT intake w/R-ECU, Titan CamGear, MeganRacing y-pipe
For Show: UGO roof spoiler, Eibach Pro Kit, Altezza Grille, JDM rubber antenna, SportDesign Headlights/Tailights, DRL mod, 25% tints
EdsLex is offline
post #77 of 267 (permalink) Old 01-18-2011, 02:42 PM
Need some help
I've tried searching, but I cannot find a step by step procedure on how to change out this clutch. My buddy is actually doing the work for me and he is telling me that when he put everything back together, that the throwout bearing comes off the tranny fork when it's pushed far enough to make up for the 1/2" thinner flywheel. Has anyone else had this issue? Any thoughts on why this would happen?
I bought all the parts recommended (thanks EdsLex!):
N/A Supra flywheel 13405-46040
Flywheel bolts (X8) 90910-02103
Slave cyl push rod 31473-14030
N/A sprung clutch disc 31250-30391-84
Pilot bearing 90363-12002-77
Release bearing 31230-22101
Rear main seal 90311-90006
Pressure plate 31210-30261-84
I'd really like to get the car back on the road, so any help is much appeciated!
Lexgirl is offline
post #78 of 267 (permalink) Old 01-18-2011, 03:29 PM
Technical Poseur
Quoted: 29 Post(s)
I would also like my unanswered question of which way does the spring pack face on the clutch disk.
-Tom- is offline
post #79 of 267 (permalink) Old 01-20-2011, 03:00 AM
it only goes in one way, i think it's spring pack towards flywheel, iirc
2002 IS300 BO, 6-Speed
2002 IS300 CW, E-Shift → 5-Speed sold
vroomRollLEX is offline
post #80 of 267 (permalink) Old 01-20-2011, 01:21 PM
Technical Poseur
Quoted: 29 Post(s)
I put the assembly together on my counter, the disk will sit on the flywheel either way and the disk will mate to the pressure plate either way. Flipping the disk changes the offset of the splined hub so it has to be one way or another.
-Tom- is offline
post #81 of 267 (permalink) Old 01-21-2011, 04:47 PM
I second the request for this answer, as I have this mess apart in my shop right this second...
GGP 03 5MT LSD & TRD TF2's w/Yokohama Parada Spec 2's.
aonghus is offline
post #82 of 267 (permalink) Old 01-21-2011, 07:19 PM
Technical Poseur
Quoted: 29 Post(s)
I'm downloading the factory Supra service manual as we speak.
-Tom- is offline
post #83 of 267 (permalink) Old 01-21-2011, 07:53 PM
Technical Poseur
Quoted: 29 Post(s)
Ok so a friend showed up...we put two bolts into the flywheel then held the flywheel up and set the disk on there both ways. Yeah its obvious. The spring pack hits the bolt heads so much that the disk doesnt even touch the flywheel.
Clutch pack out towards the pressure plate. That is the answer.
-Tom- is offline
post #84 of 267 (permalink) Old 01-22-2011, 06:21 PM
Tom, you rock. My greasy hands are getting off the laptop now and back under the IS.
Any chance I might be able to get a copy of that Supra Service Manual from ya?
aonghus is offline
post #85 of 267 (permalink) Old 01-23-2011, 03:45 AM
Technical Poseur
Quoted: 29 Post(s)
http://www.torrentreactor.net/torren...ra-MKIV-Manual
-Tom- is offline
post #86 of 267 (permalink) Old 01-23-2011, 04:29 AM
ahh glad thats cleared up, when are you planning on doing this?
post #87 of 267 (permalink) Old 01-23-2011, 05:01 AM
Technical Poseur
Quoted: 29 Post(s)
Montag. Also what is the bare minimum of stuff that needs to be removed for this to be done? Does the exhaust manifold actually need to be undone? (Or does it make things significantly easier to do so?) I've heard people referencing loosening the engine mounts but upon reading the service manual I see no reference to it...
Can some one give me a basic rundown of what they actually did/removed to replace the clutch? I'm not really down with removing pretty much the entire exhaust system if I dont have to.
-Tom- is offline
post #88 of 267 (permalink) Old 01-23-2011, 12:41 PM
When i did the clutch in mine I removed the driveshaft and exhaust (including manifold back to the axle), a number of plastic panels, and i believe the starter. Use a good impact and extensions and you can have everything torn down quite quickly. I never loosened my engine mounts but I did take a hammer to the tunnel after dropping the transmission, you'll see that it is quite a tight fit when you try to get spline into your new clutch assembly.
Did you get yourself a new rear main seal?
Nick
2008 Tundra TRD Supercharged
2004 Black Onyx Sport Design - sold
Proud Toyota owner since 2006.
04AltezzaSport is offline
post #89 of 267 (permalink) Old 01-23-2011, 04:19 PM
Technical Poseur
Quoted: 29 Post(s)
I sure did.
-Tom- is offline
post #90 of 267 (permalink) Old 01-23-2011, 06:48 PM
I sure did.
Smart lady.
Since I didn't follow up on the other thread and only read this page I'm guessing your issue all this time was the clutch/ pressure plate?
- Greg '03 BO SD 5-spd.
Originally Posted by EricK
I'm a f#$%&r then
MrGregski is offline
