N/A Supra Flywheel/Clutch Swap w/ part numbers and pics - Page 4 - Lexus IS Forum
post #46 of 267 (permalink) Old 10-18-2010, 11:42 PM Thread Starter
Vibration and MPG
If anyone knows the history of why I did this anyway... It is because I had a vibration I swore was my flywheel. And I was right. Hopefully your flywheel is balanced and everything is aligned.
I'm still pulling 24 MPG overall, and I shift at 3k rpms most of the time.
Solar Yellow E-Shift (Sold to Balig)
Absolutely Red 5 Speed/LSD (Sold to some skinny dude)
what it IS is offline
post #47 of 267 (permalink) Old 10-22-2010, 12:00 AM
Originally Posted by EdsLex View Post
Vibration in 2nd gear? That's the first time I've heard about that. What else did you change when you did the swap, and what are your current mods? Do you still have the stock shifter?
As for your MPG, that's unfortunate to hear, as the guy who created this thread said he saw a significant improvement in gas mileage and I was hoping it would do the same for me!!
I have the Ralco Short Shifter installed and from what i heard there's noticeable vibration and noise, but it was never this loud before with original clutch & flywheel setup.
I think the bad mpg is just me driving it hard. This next full tank of gas i've been driving very conservatively and shifting @ 3k rpm. It helps that it's raining so it gives me a reason to drive slower. We'll see how my mpgs turn out the next i have to fill up.
Injen CAI| Ralco | TEIN | TRD | Magnaflow | Hotchkis | BBS RS 17"x 8&9 | Bridgestone Potenza RE760
2002 IS300 IBP 5spd Manual w/ OEM Supra NA Clutch Kit+Flywheel
dLo_is300 is offline
post #48 of 267 (permalink) Old 12-11-2010, 08:23 AM
Technical Poseur
Quoted: 29 Post(s)
Originally Posted by what it IS View Post
Hey everyone, turns out if you put the N/A Supra pushrod in with the notch closest to the slave cyl it is the right length... No need to fabricate one.
Could you expand on this a little? What notch? The notch to hold the boot on the slave cylinder or a notch on the clutch release fork?
-Tom- is offline
post #49 of 267 (permalink) Old 12-11-2010, 09:45 AM Thread Starter
The notch that holds the boot in place on the rod.
post #50 of 267 (permalink) Old 12-16-2010, 05:35 PM
I've purchased AASCO flywheel (11lbs), ACT 6 puck & ACT Heavy Duty Pressure plate, was chattered alot. And change it with oem clutch, the chattered completely gone. Only whining noise came out of PLP shifter. Price wise, maybe MK4 setup more reasonable.
GGP_SXE10 is offline
post #51 of 267 (permalink) Old 12-17-2010, 11:27 AM
hey guys i pretty much have all my parts except the fly wheel.
torn between the oem supra or JUN lightweight
17lbs vs 12lbs? price diff 100+ ...
which! please help....
04 MSM 5spd no LSD :(
JDM Altezza Antenna|JDM Altezza blue tinted side mirrors|JDM Altezza Window Visors|JDM Altezza Sport Grille|JDM Altezza Centre Caps|JDM Altezza "Non-Smoker" Box|JDM Altezza "Limited" Emblems|NGK Laser Iridium IFR6T11|NGK Plug Wires|HKS Hybrid|Joe-Z|HKS HIPERMAXX III|POWERSLOT|GOODRIDGE|HAWKHPS|ATEBLUE|OBX|A'PEXiWS2|TRDRACEsways|
altezza_280t is offline
post #52 of 267 (permalink) Old 12-17-2010, 12:20 PM
chado's Avatar
as you know i've had both. JUN is too light and causes some chatter. the supra is quieter and still revs freer.
2013 Porsche 911 Carerra
2007 Aston Martin V8 Vantage
chado is offline
post #53 of 267 (permalink) Old 12-17-2010, 01:32 PM
Were you running Jun flywheel with oem clutch or racing clutch as ACT?
post #54 of 267 (permalink) Old 12-17-2010, 02:33 PM
chado's Avatar
I used both flywheels with ACT street clutch
chado is offline
post #55 of 267 (permalink) Old 12-18-2010, 09:41 AM Thread Starter
I've driven "light weight" flywheels too, and I like this setup better.
post #56 of 267 (permalink) Old 12-18-2010, 01:24 PM
I thought ACT street clutch same as OE sprung clutch, wont make chattered.
Let me try to list it, correct me if am wrong.
Chado:
Jun flywheel + ACT street clutch = Chattered
MK4 NA flywheel + ACT street clutch = Not chattered
My previous setup:
AASCO flywheel + ACT 6 puck heavy duty clutch = Chattered
AASCO flywheel + OE clutch = Not chattered
post #57 of 267 (permalink) Old 12-18-2010, 04:57 PM
chado's Avatar
Chado:
My previous setup:
OE clutch isn't sprung. but yes you are correct above. the chattering was at low rpms/high gear and with the A/C on at idle
chado is offline
post #58 of 267 (permalink) Old 12-19-2010, 06:23 PM
do u use oem pressure plate or ACT?
post #59 of 267 (permalink) Old 12-19-2010, 07:02 PM
chado's Avatar
Originally Posted by ggp_sxe10 View Post
do u use oem pressure plate or act?
act pp
chado is offline
post #60 of 267 (permalink) Old 12-20-2010, 06:54 PM
thanks guys, guess im saving a few bucks and getting the mk4 flywheel
i'll b using a sachs clutch setup let you guys know how it goes
now i need to save for labour lol
