Greddy Emanage ultimate basics for noobs - Page 4 - Lexus IS Forum
post #46 of 57 (permalink) Old 06-22-2015, 11:50 PM
Quoted: 148 Post(s)
Do you have your jumpers set properly?
2JZ GTE VVTi worked for me and the airflow TY-HW5, rpm signal will depend on how you have it physically wired.
Injector settings aren't really discussed here, but they will depend on the setup.
whatthe is offline
post #47 of 57 (permalink) Old 10-15-2015, 08:11 PM
Im pretty sure the jumpers are set up correctly. The car turns over but doesn't start. Im going to try and play around with the parameters again tomorrow. While inspecting my board I noticed that mine is a revision C, IIRC it is the revision with the ign chip problem. Is there away to troubleshoot to find out if that is my problem. I have looked at the board and I don't seem to see any missing/loose chips or burns.
Flemmsta is offline
post #48 of 57 (permalink) Old 03-11-2016, 12:57 PM
I'm just trying to get my car to start with these basic parameter settings. Sorry to bring up an old thread but I have the same setup, 2002 stock is300 with the 02 boomslang pnp harness. I should be able to start the car with (engine code: 3uz-fe(uzs), size: 3000, # of cylinders: 6, vehicle speed pulse: 4, RPM signal type: ignition). Everything else was left unchanged. The motor cranks but won't start. Does anyone else have the same problem?
esimmons9312 is offline
post #49 of 57 (permalink) Old 03-20-2016, 12:31 PM
I'm having an issue with using the 3UZ-FE(UZS). It's not letting me change the input changes to 3 in the ignition tab. Any help?
coi125 is offline
post #50 of 57 (permalink) Old 03-20-2016, 04:31 PM
Quoted: 81 Post(s)
Many have it working with the 2jz-gte vvti. Try that and read blkaltezza build thread, around page 10 or 11 I believe.
isthisme is offline
post #51 of 57 (permalink) Old 07-17-2016, 08:01 AM
Any idea what is causing this distrubance on the rev and ignition advance signal? JZS161 Aristo with a bolt on harness from GReddy. It is usually when on boost.
Krister is offline
post #52 of 57 (permalink) Old 11-18-2016, 02:33 PM
This may be a pretty dumb question but i have the Emanage ultimate and the boomslang plug and play harness and hooking that up is straight forward, but im wondering where the emanage unit itself is suppose to be kept after hooking it up to the factory ecu because, unless i missed something there is no room at all for it and the bulky harness where the ecu is located lol
saxbyja is offline
post #53 of 57 (permalink) Old 11-18-2016, 06:53 PM
Quoted: 75 Post(s)
I mounted mine under the steering column behind the panel.
post #54 of 57 (permalink) Old 11-19-2016, 04:46 AM
Not related directly to an IS300 but EMU related, greddy sells an o2 adapter which works great. I used it on a 2004 S/C Matrix(Last model with mechanical throttle) and did some tests to see if it really worked. I riched(10.0 or lower AFRs, can't tell if lower because the wideband gauge only goes down to 10.0) the fck out of the car and the ECU never intervened. You can control when you want to tell the ECU that the AFRs are "14.7" so you can tune to your liking. I also use a couple of the functions including the rev limit. Im looking forward to any future setups, I might be interested into fitting a Greddy in my IS
b0rr0 is offline
post #55 of 57 (permalink) Old 12-20-2016, 12:10 PM
I'm curious greddy O2 adapter can work(force open loop) to IS300?
tony9189 is offline
post #56 of 57 (permalink) Old 12-23-2016, 07:24 AM
Quoted: 29 Post(s)
It won't force open loop. But the factory ECU will think all is well in open loop and you can override it without ill effect.
<--- Doesn't believe in stock vehicles
2002 IS300 VVTi GTE v161 Built single - TeCKis300's old car
1995 240sx - NASA PTD trim
Hardrvin is offline
post #57 of 57 (permalink) Old 12-23-2016, 10:32 AM
Quoted: 151 Post(s)
Ill be tuning my build with the EMU and this sounds very tempting to check out.
VEHEMENCE is offline
