DIY: TB coolant line delete. - Lexus IS Forum
post #1 of 14 (permalink) Old 11-20-2015, 01:20 PM Thread Starter
Quoted: 39 Post(s)
People has been asking me how i did my tb coolant line delete and the correct line size and adapters they should use so i decided to write a simple DIY post for future references.
Pros:.Cooler throttle body
.easier to remove throttle body since you dont need to wait for the engine to cool down due to the coolant lines attached to the throttle body.
.Also this is very easy so why not.
Cons:
.I guess areas that experience extremely cold weather may suffer from doing this mod because apparently the coolant keeps the throttle body butterfly from freezing up, but i never heard anyone saying that it happened before, just that its a possibility.
Required Materials:
30-60 Mins of labor
3/8" double barb ends
4 hose clamps
Vaper 19345 3/8" Hose Mender - Air Tool Fittings - Amazon.com Vaper 19345 3/8" Hose Mender - Air Tool Fittings - Amazon.com
3ft of 3/8" fuel line
Amazon.com: Allstar Performance (ALL40356)  Fuel Line, 3/8" x 3': Automotive Amazon.com: Allstar Performance (ALL40356) Fuel Line, 3/8" x 3': Automotive
Step 1: Remove throttle body there's DIY in the forums that will show you how to remove the throttle body
Step 2: Remove the two hoses connected to the throttle body.
Step 3: Put the barb adapters into the fuel line and cut the line to the length you want as long as you can connect it to the other port.
Step 4: Make sure everything is clamped down. you dont want this to be leaking on you.
Step 5: enjoy the cooler throttle body and the ease when changing spark plugs.
02 GGP 234k on chassis
BD11A supercharger/dezod headers/greddy catback/bc264/hks cam gear. 285whp 260tq@6000rpm
az989 is offline
post #2 of 14 (permalink) Old 11-21-2015, 04:16 PM
Quoted: 16 Post(s)
Cons:
Required Materials:
30-60 Mins of labor
4 hose clamps
Great write up but your catch can is a fire hazard.
2002 IS300 GGP
NA for now, going boost
sulaman58 is offline
post #3 of 14 (permalink) Old 11-21-2015, 04:28 PM Thread Starter
Quoted: 39 Post(s)
yea needa relocate it somewhere. The catchcan never fills up with oil at all tho.
az989 is offline
post #4 of 14 (permalink) Old 11-22-2015, 07:38 AM
Quoted: 16 Post(s)
I've never noticed a massive amount of oil come through that line. It's fairly low pressure air. I would hook a catch can up to the one on the other side of the throttle body.
I swapped to a 80mm gs throttle body so I'm running all the vacuum lines to a block>catch can>back to the engine that way I can catch oil coming from any port. The one you have it hooked up to I just have a breather filter on.
2002 IS300 GGP
post #5 of 14 (permalink) Old 12-14-2015, 01:02 AM
Quoted: 22 Post(s)
great write up man , when there is some free time ill pop the hood and get to it , i live in a hot area already so this will out whenever i wanna clean the throttle etc...
2002 MSM
Manual 5 speed , LSD
ME?: buy a car, fix it, mod it , KEEP IT
My noob intro + my mods http://my.is/forums/f257/one-more-20...-right-564042/
DarK StaR is offline
post #6 of 14 (permalink) Old 12-14-2015, 09:51 AM
Quoted: 224 Post(s)
Cons:
Is the hose then resting on the valve covers? No issues with heat or anything?
Luke 6:41-42.
The Nuke is offline
post #7 of 14 (permalink) Old 12-14-2015, 03:28 PM Thread Starter
Quoted: 39 Post(s)
the hose is wedged between the TCM and the engine cover mount, in this picture its on the valve cover i dont think it would matter. No issues with heat at all.
az989 is offline
post #8 of 14 (permalink) Old 12-17-2015, 02:58 PM
gs400???
Gengles is offline
post #9 of 14 (permalink) Old 12-18-2015, 09:24 AM
Quoted: 16 Post(s)
Originally Posted by Gengles View Post
gs400???
yah gs400 throttle body
2002 IS300 GGP
post #10 of 14 (permalink) Old 02-01-2016, 04:25 PM
Quoted: 40 Post(s)
Did you plug the holes on the throttle body where the coolant went to before or are they just left open?
allturbo98 is offline
post #11 of 14 (permalink) Old 02-01-2016, 06:47 PM
Quoted: 16 Post(s)
I just left it open.
2002 IS300 GGP
post #12 of 14 (permalink) Old 08-08-2016, 03:14 PM
I did this a couple of months ago and seems to running fine with no problems. Great and easy mod.
allturbo is offline
post #13 of 14 (permalink) Old 01-22-2017, 02:22 PM
I might be doing this. I think mine TB ic clogged. Whenever I blow air from one end, it doesn't come out the other end. I was wondering if it will effect anything but obviously not. Thank you
Vi3tguy2000 is offline
post #14 of 14 (permalink) Old 01-22-2017, 04:00 PM
Quoted: 147 Post(s)
Ok since this is a throttle body thread, has there been a TB spacer made yet for our cars? If your looking to squeeze every lil bit of performance off the TB, I feel this would help. Anyone know about a spacer?
VEHEMENCE is offline
