Turbo kit - Lexus IS Forum
 6Likes
post #1 of 16 (permalink) Old 03-08-2017, 02:24 PM Thread Starter
Quoted: 53 Post(s)
Turbo kit
Can anyone tell me if this is a XS power turbo kit. They say it is but I thought that XS used the same intercooler as CX Racing does or did they use a different one when they first come out?
https://www.ebay.com/itm/122052844482
allturbo98 is offline
post #2 of 16 (permalink) Old 03-08-2017, 04:25 PM
Quoted: 60 Post(s)
I wouldn't trust this kit. It says GE or GTE even though the exhaust and intake manifold is different. That intercooler is probably just a generic one. The CX intercooler that you are thinking of is IS300 specific. And this is advertised as a universal kit. Don't buy it.
jesuspuppy is offline
post #3 of 16 (permalink) Old 03-08-2017, 07:03 PM
Quoted: 132 Post(s)
Yeah I would never ever trust that.
cleansleeper is offline
post #4 of 16 (permalink) Old 03-09-2017, 07:42 AM
Quoted: 19 Post(s)
hijacking this thread some....
What exactly is involved in adding turbo?
Im by no means a mechanic so speak english if possible...
Everything I read is "swap out for Supra engine"
Why cant you add turbo to stock IS300 engine? And if you can, is it drop and go? Or are modifications needed? If so, what kind?
noloc4545 is offline
post #5 of 16 (permalink) Old 03-09-2017, 08:08 AM
Quoted: 132 Post(s)
Search more. This is probably the most talked about topic on this site and it's been answers thousands of times.
Touge2jz likes this.
post #6 of 16 (permalink) Old 03-09-2017, 10:10 AM
Quoted: 60 Post(s)
There is so much involved with boost. I'm not trying to be a dick but there are some threads that are stickied at the top that can help. It's not as simple as adding a turbo. There are plenty of modifications that need to be done besides that.
post #7 of 16 (permalink) Old 03-09-2017, 10:26 AM Thread Starter
Quoted: 53 Post(s)
Yeah, I was just wondering if there was ever a kit like this. I don't really trust it because it just seemed like I have never seen any kit like this just wanted to see if anyone else has seen this.
post #8 of 16 (permalink) Old 03-09-2017, 10:28 AM
Quoted: 41 Post(s)
As easy as 1,2,3.
blkdout, c1L, Touge2jz and 1 others like this.
IS3TT
FRaCTioNaL is offline
post #9 of 16 (permalink) Old 03-09-2017, 10:52 AM
Quoted: 19 Post(s)
Enough said.
I have no dreams of racing or anything.
I was just curious.
post #10 of 16 (permalink) Old 03-09-2017, 03:16 PM
Quoted: 60 Post(s)
Enough said.
I was just curious.
I see. Basically when building this specific car you start by swapping out the stock headers for a turbo manifold. Obviously with a turbo. You drill into the oil pan for a return line. Tap into an oil pressure source for an oil feed to the turbo. You'll have a custom downpipe with your wideband sensor that measures A/F ratios and transmits that data to your engine management of choice. A lot of people choose to get a piggyback system. The piggyback basic alters signals coming into it from the stock harness. Rather than just controlling it by itself. In its most basic form... The best way to do it in a street car is to go standalone running in parallel with the stock ECU. This way the stock ECU controls things like AC, and traction control, while the standalone controls things like fuel and ignition... It's easier to tune on a standalone and it's more reliable. You are going to need an array of different aftermarket sensors with it too. Next is fuel... We typically get bigger injectors and a larger fuel pump. It's also a good idea to set up a fuel return, but it's not needed. You'll have gauges that measure boost, A/F ratio, oil temp, etc. Really it's whatever you want... You can technically go without it.. but it's a good idea to have just in case it starts over boosting. There is also the wastegate that limits the amount of pressure that builds up in the turbo (effectively controlling the amount of boost you have) you might have a boost solenoid working in tandem with the wastegate so you can manually set the point that the valve inside the wastegate opens. On the compressor outlet of the turbo typically there is the intercooler piping that runs to a front mount intercooler that simply cools the air going into the intake. Somewhere on there is the blow off valve the relieves pressure when letting off the throttle to prevent surge. Most people opt for having colder spark plugs . I personally use densos coppers and gap them.
That's all building on the GE without even touching the engine. For serious power most people swap out for GTE internals , with ARP hardware, and a fresh rebuild to ensure reliability. Some people use the GTE headgasket to lower the compression. I am not one of those people. Everything else is really just extra.
You can go with a lot more. Or maybe even a little less. I probably forgot a few things... But I'm sure someone might be able to fill in somewhere.
I was curious too one day. And now I'm a broke college student with a turbo IS300. Haha take care.
post #11 of 16 (permalink) Old 03-09-2017, 03:26 PM
Quoted: 224 Post(s)
OP - the thing I don't like about this kit is one picture is with a GS300 and another with a Supra... Seems like a universal kit to me, which means you may run into fitment issues.
Luke 6:41-42.
The Nuke is offline
post #12 of 16 (permalink) Old 03-10-2017, 07:45 AM Thread Starter
Quoted: 53 Post(s)
Yeah, I noticed that too. I was just searching to see if there were any other alternatives to turboing the GE besides CX or XS kits. I might just piece one together. Its the whole engine management that gets me trying figure out the one to get.
post #13 of 16 (permalink) Old 03-13-2017, 03:06 AM
just go with the gte swap
andy_qzn is offline
post #14 of 16 (permalink) Old 03-13-2017, 08:08 AM
Quoted: 41 Post(s)
You are telling someone who cannot identify a turbo kit to do an engine swap. That hardly seems like good advice and more like an "I just want to play" comment.
IS3TT
post #15 of 16 (permalink) Old 03-13-2017, 12:19 PM
Quoted: 60 Post(s)
Lol, 100% .
