Timing belt change new seals...just turning over with no spark - Lexus IS Forum
post #1 of 5 (permalink) Old 03-19-2017, 11:41 AM Thread Starter
Hi im new here but ive had my is since it was 6 months old...have alway done my own work to it and services...its a 2001 with 118k miles figured id change the timing belt and water pump...so i started back in November when it was still noce out here and didnt finish till now since working 7 days a week and the bitter cold ive red a million post on how to do this and i think i have it right...to add to the mix i have a unorthodox light weight/ underdriven pulley set that i put on the car years ago...with that said there is one notch on the pulley which represents TDC (0 on plastic cover) and i have the dots on cams lined up with the metel cover behind it...i checked and checked it a million times and with everything back together just turns over no gas smell at the exhaust no nothing...so i red about making sure teeth on crank gear are true and not broken to the crank sensor that looks fine so with the car in pieces as of now the accessorie belt is off radiator is out i have the air box on and map pluged in and im getting no spark to spark plugs i pulled on out and checked so what can be the problem what should i look to check next? This is turning in to a headache
Exlr82fast is offline
post #2 of 5 (permalink) Old 03-19-2017, 02:25 PM
Quoted: 492 Post(s)
I'd check all the fuses to start.
No spark/no fuel suggests crank position sensor.
post #3 of 5 (permalink) Old 03-19-2017, 05:29 PM Thread Starter
Checked all fuses checked the teeth on crank gear none bent or broke...can crank sensor just go bad seem unlikely but that is the thing that everything points to
post #4 of 5 (permalink) Old 03-20-2017, 07:07 AM
Quoted: 72 Post(s)
Red = the color red
Read= both present and past tense of the term "to read"
In regards to the no start, did you check the wires to the cam sensor and crank sensor? The computer wont send gas and spark unless the crank sensor shows movement. Use a multi meter and check continuity at crank sensor and power at its plug.
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #5 of 5 (permalink) Old 03-20-2017, 04:59 PM Thread Starter
Well i checked it at the plug both ends open circuit on cps and i didnt get voltage on the other side either...will just having the key in the On position turn power on the the sensor?
