Rear main seal project questions? - Lexus IS Forum
 3Likes
  • 1 Post By reklipz
  • 2 Post By IS3_FTW
post #1 of 15 (permalink) Old 10-07-2016, 08:06 PM Thread Starter
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 541 Post(s)
I am planning to get my rear main seal and front pump seal done on my 01 IS300.
What parts would I need and if possible, part number would help. I have googled and found some parts, but I want to make sure I am ordering the correct parts
FYI, I will be going OEM for this stuff. Price is no object is what I am saying
Thank in Advance
Phil
2001 IS300
IS3_FTW is offline
post #2 of 15 (permalink) Old 10-10-2016, 10:28 PM Thread Starter
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 541 Post(s)
Bump Bump
Phil
2001 IS300
IS3_FTW is offline
post #3 of 15 (permalink) Old 10-11-2016, 12:18 AM
90311-38029
Seal, Oil (For Front Oil Pump)
90311-38070
Seal, Oil (For Rear Differential Carrier)
90311-43001
Seal, Oil (For Rear Differential Side Gear Shaft)
Not sure if that's what you're looking for.
All found here: 2001 Lexus IS300 Parts - LexusPartsNow.com
First seal can be found under: Powertrain/Chassis > Torque Converter, Front Oil Pump & Chain (ATM)
Second and third seals can be found under: Powertrain/Chassis > Rear Axle Housing & Differential
You will need multiples of some of those seals, the site will tell you how many you need in the description of each one.
TrippF is offline
post #4 of 15 (permalink) Old 10-11-2016, 04:41 AM
Quoted: 476 Post(s)
I'd do the timing belt too while you have the front off the engine. You have to take the timing belt off already to even get at the front main seal.
Do you have the engine out? Wondering how you plan on getting at the rear main seal.
Ek9B18 is online now
post #5 of 15 (permalink) Old 10-11-2016, 06:40 AM
Quoted: 67 Post(s)
The rear crankshaft seal is 90311-90006
post #6 of 15 (permalink) Old 10-11-2016, 11:55 AM
Quoted: 70 Post(s)
DriftMotion has these parts in stock, too:
1JZ/2JZ Rear Main Seal, Factory Toyota
1JZ/2JZ Oil Pump O-Ring Set
1JZ/2JZ Front Main Seal
JZ Oil Pan O-Ring
You're going to have to drop the transmission too in order to get at this, right?
reklipz is offline
post #7 of 15 (permalink) Old 10-12-2016, 06:40 PM
Quoted: 39 Post(s)
since you in there, might as well do cam seal and the vvti seal kit from drift motion.
02 GGP 234k on chassis
BD11A supercharger/dezod headers/greddy catback/bc264/hks cam gear. 285whp 260tq@6000rpm
az989 is offline
post #8 of 15 (permalink) Old 10-12-2016, 08:03 PM Thread Starter
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 541 Post(s)
Originally Posted by TrippF View Post
90311-38029
90311-38070
90311-43001
I dont know what I am looking at without some knowledge. The rear of the engine/trans is a whole new world for me. I didnt even know where the front pump seal was located
When I google, it doesnt really help me all that much. Wish someone had done this before and taken pics of the process. Do you know where to find torque specs on the bolts for the torque converter, flexplate, trans housing to engine, etc?
Do I need to replace the rear diff seals? Im not completely taking off the driveshaft, other than the front where it attaches to the trans
Dropping the trans and working on jack stands
why rear crankshaft seal?
JZ Oil Pan O-Ring
Yessir
Front pump seal. Not going to touch the front of the engine. Had the timing belt stuff done less than a year ago.
Wont be touching the front of the engine
Phil
2001 IS300
IS3_FTW is offline
post #9 of 15 (permalink) Old 10-12-2016, 09:14 PM
Quoted: 70 Post(s)
The service manual has all of that information. It's available on this very site; it shows part diagrams (exploded breakdowns) denoting torque values and "single-use" components and what not. The (torque, and various other) information is also available in tables that summarize the relevant specs from various "systems".
Rear main seal project questions?-em-78.jpg Rear main seal project questions?-em-79.jpg Rear main seal project questions?-em-80.jpg
Not unless it's in need of replacing, or due for some sort of interval/preventative change. What your doing shouldn't harm that at all, though it may wind up being easier to just remove it out of the way (I'm not sure!).
Don't fret; get it securely supported (quality jack-stands, safe and secure location under vehicle, four corners) and as high off the ground as you're comfortable with and you'll be fine. Just be smart and take your time if you get frustrated, .
rear crankshaft seal == rear main seal
The front pump seal is in the front of the engine, as the diagram shows. It's the front crankshaft seal.
Take note of the first step in the procedure: mount the engine to an engine stand. That's how invasive what you're looking to do really is. That's not to say it can't be done on the ground with the engine on jack-stands, just that you ought to make sure you're aware just how shitty this creek you're about to wade through could become if you aren't careful.
Curious, how do you have >10k posts?
ID:	102962   Click image for larger version
ID:	102970   Click image for larger version
IS3_FTW likes this.
reklipz is offline
post #10 of 15 (permalink) Old 10-12-2016, 11:32 PM
Quoted: 145 Post(s)
Manual transmission? You will have to take off flywheel/clutch off anyway, so it's a good time to do mods to your clutch if manual. Would also recommend new bolts for flexplate or flywheel whatever the case.
The seal itself can be a giant pain once you do make it to that point. If it goes in a little bit crooked, and you straighten it out, chances are you will have damaged the lip on it and will need a new seal. I ended up building a tool to press it in after messing up some seals in the past.
whatthe is online now
post #11 of 15 (permalink) Old 10-13-2016, 12:11 AM Thread Starter
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 541 Post(s)
Front pump seal is the seal between the torque converter and trans. Its like a crank seal, but for the transmission shaft
This place was really active from 2007-2012
Autotragic
Im going to add some oil or grease to the rubber part of the seal, so it doesnt rip.
I have heard horror stories of damaged seals. I will likely buy 2, since its only $10 each
Phil
2001 IS300
IS3_FTW is offline
post #12 of 15 (permalink) Old 10-13-2016, 12:55 AM
Quoted: 145 Post(s)
Autotragic
Ah fair enough on the auto. I lubed mine with oil and tried some other various super-lubes I had and still damaged a couple seals. One I thought went well until oil started leaking on my floor a week later. The dust lip on the outside always looks 100% fine, but there is a really fine edge on what is the sealing edge on the inside that tears suuuper easy if it goes in a tiny bit out of alignment.
It may have been partly this particular 2J in my car, or even just all newer seals... but when I was installing it on my car, the seal went slightly out of alignment at the start of pushing it in, tapped more on the other side to level it out, and even though it was not in all the way, the seal edge was damaged already at that point.
post #13 of 15 (permalink) Old 10-13-2016, 06:46 PM
Quoted: 70 Post(s)
Ah, okay; I admit I've focused on the manual-trans IS 300 applications, but the service manual calls out both (and even Sedan vs Wagon), so I figured I'd notice it. I assume then, e.g. that it (this "front pump seal" for the transmission) is only applicable to the auto-trans IS 300 application. Is there a separate "pump" in that application (for e.g. the torque/trans fluid/lube), that is different than the engine oil pump (which is on the front of the engine, and has its own set of seals)?
It's not in the diagrams I shared above (about servicing the rear main seal), and when I look at the diagrams in the "Automatic Transmission" section of the manual, nothing jumps out at me there either.
It seems to me that you mean to refer to what I'd call the "transmission input shaft seal;" not the "[engine] front pump seal."
Also, the service manual calls out two procedures for changing the engine front and rear crankshaft/main seals; one where the oil pump/seal retainer is removed from the cylinder block, and one where they're still attached. The differences are 1) how you remove the old seal ("press out" as a whole vs "cut and pry" as pieces; respectively) and 2) how you install it (grease seal lip after install vs grease seal lip before; again, respectively).
ID:	103026   Click image for larger version
reklipz is offline
post #14 of 15 (permalink) Old 10-13-2016, 09:49 PM Thread Starter
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 541 Post(s)
First of all, I would like to thank you for the torque specs on the flex plate to block and flex plate to torque converter
Im not sure how I am going to take out the front pump seal, but its gonna need to be done. Im hoping its only the seal and not the whole assembly
This link shows the name of the oil pump seal for the trans with the pic below in 35301A.
Courtesy of mm7 (aka L-tuned Mike) for the bottom pic of his
SEAL, OIL (FOR FRONT OIL PUMP COVER); SEAL, OIL (FOR FRONT OIL PUMP) for 2001 LEXUS IS300. #9031138020
mm71522 and reklipz like this.
Phil
2001 IS300
IS3_FTW is offline
post #15 of 15 (permalink) Old 03-19-2017, 01:18 AM
Quoted: 70 Post(s)
Bump. Did you get this done, then?
reklipz is offline
