mixing Toyota red coolant with long life PEAK: a no no? - Lexus IS Forum
post #1 of 12 (permalink) Old 07-04-2010, 07:52 PM Thread Starter
Quoted: 71 Post(s)
Okay so I got mixed answers with this simple question. Have an 02 with 50k and has red coolant in it from when I changed it at 35k. I recently bought PEAK extended long life green coolant which states safe for all makes and models...to just top off. When I asked the dealer they said it would be ok to top off with this green coolant and is compatible with Toyota red.....as it does contain ethylene glycol and no silicates. But then I hear only use red with red and mixing is bad as it causes plaque internally. Since I only used maybe only 20 oz of this to top off....did I make a mistake and is the dealer wrong. Meaning....should I drain and refill or is that unnecessary??? Input appreciated fellows....
post #2 of 12 (permalink) Old 07-04-2010, 08:26 PM
TB_
If you're in a pinch, sure, it'll work. Personally, I'd use the proper fluid, long term. Why didn't you buy the red for top offs?
2001 IS300 - SOLD
TB_ is offline
post #3 of 12 (permalink) Old 07-04-2010, 08:44 PM Thread Starter
Quoted: 71 Post(s)
well...im not real close to a dealer and my resovior tank was empty. after asking the dealer parts guy he said sure...green PEAK...thats fine and compatible. not a good excuse for me...i realize this....but wanted to see what your take was on this fellows. i wasnt going to drain/replace for another 20k or so.....and not 100% sure the real compatabilty....other than what i have heard or seen and want to make sure so i dont damage the coolant system. if i made a stupid mistake by not keeping the fluid the same...then i will change it all out.
post #4 of 12 (permalink) Old 07-04-2010, 09:22 PM
Geezer
bartkat's Avatar
If you're concerned, change it out. Personally I only top off with the Toyota fluid.
MOLON LABE
bartkat is offline
post #5 of 12 (permalink) Old 07-04-2010, 09:52 PM Thread Starter
Quoted: 71 Post(s)
might just be the way to go...i guess....just wanted to see what fellow is'ers thought....and if they have ever had any issues doing this. thanks for the input thus far. when something says compatable with all makes and models...that kinda makes me weary...especially with a higher performance vehicle. Lexus told me any ethylene glycol coolant should be compatable no matter the color. oh well...figured id ask
post #6 of 12 (permalink) Old 07-05-2010, 12:40 AM
Whoa whoa hold on just a second. The bigger problem here is that your coolant reservoir was completely empty, and you changed it 15K ago. It's somewhat common to "top off" the coolant, but that doesn't refer to filling the entire reservoir. It sounds like you may have a leak, and I'd worry more about where the coolant is going before I worried about which type was compatible.
* 2001 SpectraBlueMica E-Shift LSD IS300 *
Can I Scream?
Rapture Cabaret is offline
post #7 of 12 (permalink) Old 07-05-2010, 01:05 AM
Geezer
bartkat's Avatar
I just always try to play it on the safe side. There's more to coolant than EG, that's been used for years. Additives also lubricate the water pump etc.
As for it being low, did you make sure you circulated and filled the entire system including the heater core when you changed it?
MOLON LABE
bartkat is offline
post #8 of 12 (permalink) Old 07-05-2010, 06:15 AM Thread Starter
Quoted: 71 Post(s)
Good point. Looking back 4 years ago when I did the drain....I don't remember touching the reservoir tank....so I believe if it was low...then it stayed low until now. I can't remember...but if I neglected to do so.....I must have just forgot.not sure. Anyway... I defiantly will monitor the level here on out to be sure. As for changing it all out b/c I added 1/4 gal of green PEAK....I'm not sure.
post #9 of 12 (permalink) Old 07-05-2010, 08:30 AM
Geezer
bartkat's Avatar
bartkat is offline
post #10 of 12 (permalink) Old 07-05-2010, 09:08 AM Thread Starter
Quoted: 71 Post(s)
Thanks for that link....think I'm going to do a rad drain/refill to play it safe with Toyota brand. I only used 1/3 gallon of 50/50 PEAK....so hopefully that should be good and get rid of most of it....meaning I don't plan on draining the engine block. Thanks again.
post #11 of 12 (permalink) Old 07-05-2010, 09:25 AM
Under House Arrest
mikefate's Avatar
i also use redline water wetter when i replace my coolant. and i always use the toyota red fluid. works great.
mikefate is offline
post #12 of 12 (permalink) Old 07-05-2010, 04:03 PM Thread Starter
Quoted: 71 Post(s)
Okay....its confirmed. PEAK LONG LIFE 50/50 GREEN coolant is ok to use with factory red. After taking the trip to get the red Toyota stuff....I compared the ingredients. The only difference is that the red contains organic acid salt and hydrated inorganic salt. The PEAK stuff is all the same but NO salt additives EXCEPT ingredient NJTSRN QT1 which is an inorganic acid...which I found was put in to deter animals. Trust me....even the substance numbers are the same. I even read that this particular Peak has no phosphates or silicates. They pretty much do away from those ingredients with this brand nowadays...as I've read. So the Lex tech is right....as long as you don't mind a red-brownish color....you are ok with this brand. And yes....I did spend the $28 for Toyota coolant....which is crazy....but hey...you are paying for the added salts. Me personally, I drained the rad, the engine block, and put new RED in. Just wanted to let everyone know after extensive looking into PEAK LONG LIFE GREEN coolant/antifreeze IS compatable and end all debates. Don't know about prestone etc.....
