Diagnose my problem. Car vibrates going 40-50 mph - Lexus IS Forum
post #1 of 12 (permalink) Old 05-05-2007, 01:30 AM Thread Starter
This is really starting to make me mad. at first i thought it was my bent rims that was causing it, well i straigtened all 4 of my rims, and that costed me 530, but the vibrating in my car is still happening, i dont know what to do. i dont want to bring it to lexus because they will rape me on the prices. i have 1 tire that has bad tread, could that be causing it? someone suggested that it could (the place that straightened my rims. another suggested that vibrating is caused by bad mount and balance, but the thing is, my car was vibrating before i straightened my rims/mount and balance them, therefore i dont think that is the problem. i also need an alignment, but from what i understand, alignments dont cause vibrations, they cause steering wheels to steer to the left/right.
i need advice, my car ONLY shakes between 40-50 mph, if i go 70 mph, it doesnt shake. it shakes so bad that i feel it's dangerous to drive. please help
rlee is offline
post #2 of 12 (permalink) Old 05-05-2007, 02:19 AM
did you balance your tires when you had your rims straightened? sounds like off-balance tires could cause this.
01SBM
jooowan is offline
post #3 of 12 (permalink) Old 05-05-2007, 10:49 AM Thread Starter
yes they were mounted and balanced after they were straightened. even before i straightened, the vibration happened. so unless the previous people that did my tires off balanced them, or if the straightening people off-balanced them, i dont think that is the problem since it was vibrating before and after i straightened
rlee is offline
post #4 of 12 (permalink) Old 05-05-2007, 11:01 AM
From experience, tires have a play in this as well. I recall tire wear having some effect on vibration, but i don't know if one worn tire can cause the extensive vibration that you speak about. Make sure the tires are properly inflated (by this I mean the appropriate PSI)? Sometimes that plays a part in vibration and ride quality. Since you need an alignment, get that done first and see if the problem persists. If it does, then bring it to a shop other than the Lexus dealership and get them to test drive the car. Hopefully they will be able to diagnose the problem.
For the time being, since the car vibrates a great deal, just be sure to check your wheel bearings and retorque your lug nuts every now and then (if you have stock lugs, then you maybe fine...but better be safe than sorry).
All the best. Hope things work out for you.
LEXIGRL.
Lady Lexotic Concepts
2004 - 2010
LEXIGRL is offline
post #5 of 12 (permalink) Old 05-05-2007, 11:27 AM
Sounds like you have alot of things you need to take care of anyways! So...
1) Get an alignment.
- When I dropped my car 1", the wheels were so out of whack, the car just felt like shit to drive. $100 for a 4-wheel laser alignment (camber, caster and toe)
2) You need new tires...at least two anyways.
- Get yourself some tires, $200 a pop?
3) Driving on bent rims? WTF
- So they're fixed right? balanced too?
4) All the other things, tire pressure, check your rotors for warpage
All else fails, you can always take the car to Lexus for diagnoses and get it fixed elsewhere.
HappySMP
2002 Stage II L-Tuned IS300 - My Build Thread
happysmp is offline
post #6 of 12 (permalink) Old 05-05-2007, 11:45 AM Thread Starter
i think im just going to bring it to lexus to avoid any headaches, except that it will cost me an arm and a leg.
i checked my tire pressure, they're all good.
rlee is offline
post #7 of 12 (permalink) Old 05-06-2007, 11:01 AM
Add a bad shock to the list above and you did say you bent the rims so you may have suspension damage.
clubfoot is offline
post #8 of 12 (permalink) Old 05-07-2007, 06:49 AM
I have owned 2 sets of 18" rims. Both sets make the car vibrate at about 55mph. Wierd. I had mounting and balancing done, new tires, and alignment a few times with no help. In the winter when I put the stock 17's on mounted on Blizzack's the car rides smooth as silk.
01 IS300T 21psi 2.00 60' 12.0@125 -current-
01 IS300T 17psi 1.64 60' 11.8@120 -RIP-
06 Audi S4 6MT daily driver
94 Supra Single Turbo 6spd. SOLD
diablooffire03 is offline
post #9 of 12 (permalink) Old 05-07-2007, 03:55 PM
I've seen this type of issue many times before at the speeds you describe. It is almost always a shifted belt inside the tire. Basicly your tire isn't round while rolling with a load.
Wheel balance issues (unless its reall really off) will start around 50, and get worse as speed picks up.
you said yourself you have a bad tire. What more do you want? replace the tire, actually, replace two tires.
Lextech1 is offline
post #10 of 12 (permalink) Old 05-08-2007, 12:10 AM
From what I know if your car starts vibrating at 50 and past 70 its smooth again. then you have a mounting and balancing issue. If your tires are not round then they would have spotted that problem doing your mounting and balancing.
Maybe they did a bad job. Next time when you go get your tires mounted and balance stand close to your car and watch them balance it to see if they did it right and not goof it up. I remember working at Arospeed/Speed and style they would get lazy in the back and goof with the balancing part but when the customers were watching they would straigten out and do there job.
DIN300 is offline
post #11 of 12 (permalink) Old 05-18-2007, 05:59 PM
Prob. could be as many people have stated....
mount and balance...esp. the balancing part
bad tires
bad wheels (even if it is bent back to be not bent anymore)
worse case transmission during the 40-50 mph shiftchange....might be torque converter....but let's hope not.....
PapaMochi is offline
post #12 of 12 (permalink) Old 05-19-2007, 04:23 PM
This is spot on - I had the same problem you're describing on my Integra 3 weeks ago before I sold it and got my IS. I replaced the tire that had "slipped a belt" according to the mechanic, and the problem disappeared.
Todd.
toddrhodes is offline
