Auto radiator on manual IS300? - Lexus IS Forum
 2Likes
post #1 of 16 (permalink) Old 02-15-2017, 05:24 PM Thread Starter
Quoted: 146 Post(s)
My radiator cracked today, and I need to get a new one. I called Lexus, and they want $375 + tax for a new one. I did some searching on here, and saw that Denso makes a replacement, but they only seem to make one for automatics.
More Information for DENSO 2213120
A Mishimoto is cheaper than OEM, so I might go that route, but I'd rather get a Denso for less than half the price. Has anybody with a manual transmission IS300 used the Denso 2213120 radiator with success? I'm hoping that it just has an extra fitting for the auto transmission that can be left closed off or something like that.
My job is only 5 miles away, so maybe I'll just keep some Toyota coolant in my car, and top off every time I drive...until I get a replacement.
rvalero is offline
post #2 of 16 (permalink) Old 02-15-2017, 05:40 PM
Cherisher
blkdout's Avatar
Quoted: 569 Post(s)
Should be fine. You wouldn't necessarily need to cap of the lines but if it were me, I would.
-Hiral
blkdout is offline
post #3 of 16 (permalink) Old 02-15-2017, 09:44 PM Thread Starter
Quoted: 146 Post(s)
Thanks. How would I cap the lines? Would they have something at Autozone or another local parts store to do that? I ended up applying some QuickSteel to the hairline crack in the rad. Hopefully it's just in front where I can see it. Hopefully the temporary fix lasts a week or two until I get my new radiator.
rvalero is offline
post #4 of 16 (permalink) Old 02-16-2017, 06:49 AM
Quoted: 47 Post(s)
Should be able to find some brass plugs.
post #5 of 16 (permalink) Old 02-16-2017, 12:58 PM
You'll be fine. I had to replace mine due to an impact about 50K miles ago.
I used an aftermarket replacement for an automatic and left the tranny lines unconnected.
My car still runs at the same temps as before.
NA IS300s run ridiculously cool anyway.
Unless you plan to turbocharge in the future, you'll be a-ok.
85eliminator is offline
post #6 of 16 (permalink) Old 02-16-2017, 01:42 PM
Quoted: 20 Post(s)
This is good info. I'm at 143k and I'm afraid to get stranded due to radiator crack. I think as a precaution I may just pick one of these Denso up during 150k maintenance and do a coolant flush while I'm at it.
Rey - let us know how it works out!
'03 IS300 SD TCM 5-SPD LSD
tonynca is online now
post #7 of 16 (permalink) Old 02-16-2017, 02:59 PM
Quoted: 14 Post(s)
Just buy an OE radiator its around $97 for it. My M/T went so I am using an A/T right now
2003 MSM 5MT LSD | te37 | trd neo v1 | injen intake | hks kansai service |
pjmorozov is offline
post #8 of 16 (permalink) Old 02-16-2017, 07:49 PM Thread Starter
Quoted: 146 Post(s)
Thanks for the input guys. I ended up getting a Koyo OEM replacement. I've heard good things about them, and I installed one in my old Civic. I was thinking about getting an aluminum radiator, but it would just be a waste of money for my purposes. Unless I moved out of CA, my car will never see FI. Install should be straight forward with no modification. I'll let you guys know how it goes.
+Rep for everyone...wait, what's that??
rvalero is offline
post #9 of 16 (permalink) Old 02-16-2017, 11:02 PM
Quoted: 39 Post(s)
yull be perfectly fine. I actually installed one for a friend on his manual is300
02 GGP 234k on chassis
BD11A supercharger/dezod headers/greddy catback/bc264/hks cam gear. 285whp 260tq@6000rpm
az989 is online now
post #10 of 16 (permalink) Old 02-17-2017, 09:54 AM
Cherisher
blkdout's Avatar
Quoted: 569 Post(s)
Sorry, I'm late but like mentioned, some brass plugs would be the easiest option.
Where are you picking up the Koyo? That sounds like a great option. May do the same when the time comes.
rep? Never heard of it....
-Hiral
blkdout is offline
post #11 of 16 (permalink) Old 02-17-2017, 10:45 AM
mm71522's Avatar
Quoted: 312 Post(s)
I have the same one. Works great
rvalero likes this.
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #12 of 16 (permalink) Old 02-17-2017, 07:47 PM Thread Starter
Quoted: 146 Post(s)
New radiator is in and tested
rvalero's IS300: 2006-present (Update: New motorized nav housing)
blkdout likes this.
rvalero is offline
post #13 of 16 (permalink) Old 02-19-2017, 07:26 PM
Quoted: 20 Post(s)
Your post says you went with a Koyo oem atm? I think you meant Denso?
post #14 of 16 (permalink) Old 02-19-2017, 07:33 PM Thread Starter
Quoted: 146 Post(s)
Nope. I got an ATM koyo radiator from my local Toyota.
rvalero is offline
post #15 of 16 (permalink) Old Yesterday, 07:04 PM
You can use an automatic radiator on either manual or auto car.
I never had good luck with aftermarket radiators, I had 2 that leaked at the seams where the plastic end tank meet the fins.
shiftdrift06 is offline
