WHY DO I CARE?
What Is OBD?
WHERE CAN YOU BUY THEM?
Here are some online sites, you can get a Denso 02 Sensors:
Denso starters, alternators, iridium plugs, fuel pumps and glow plugs,
OELEXUSPARTS.com, or
Sewell Lexus Parts and Accessories Online - All Genuine Lexus Original Equipment Parts. They are all around the $100-$150 neighborhood with shippine. Generics can be as much as half that amount.
WHAT ARE THE PART NUMBERS?
Bank 1 Sensor 1:
89465-53090 (2001) *
89465-53140 (2001) *
89465-53210 (02+) **
Bank 1 Sensor 2:
89465-53110 (2001) *
89465-53200 (02+) **
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
89465-53190 (02+) **
Bank 2 Sensor 2:
89465-53150 **
HAS ANYBODY DONE A DIY YET?
IS300 P0161 B2S2 o2 Sensor Replacement
IS300 P0161 or P0141 o2 Heater Malfunction FREE Fix
IS300 How To Install o2 Simulator
IS300 o2 Simulators for Dummies
