b
Go Back   my.IS - Lexus IS Forum > Site News & FAQs > FAQ > Lighting
» Log in
Not a member yet?
Register Now!
» Featured Product
» Wheel & Tire Center
Sponsors
Sponsors
Old 01-07-2008, 03:51 PM   #1 (permalink)
longnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community memberlongnights is an elite community member
DRL mods (Full power and disable)
Thanks to SophieSleeps and Joe-Z for originally developing these modifications.
**Whenever working with electronics, unplug the battery, I can't be responsible if you electrocute yourself (don't let that scare you, as long as you're careful, you shouldn't have to worry). Likewise, we are also not responsible for any damage you inflict upon your car attempting these modifications.**
What You'll Need:
optional:
12mm socket wrench w/ extension
No DRLs:
electrical tape
Full Power DRLs:
short piece of wire (14ga worked well for me)
wire stripper or scissors
electrical tape
Here is where we are working, passenger side of the engine compartment, the DRL box is the small box with yellow caution label mounted on the strut tower. **The box is hot when the DRLs have been running, be careful**
This connector must be disconnected for both modifications:
The connector is very tight, you must push down on the portion that I have my thumb on to disconnect it
Here is where the two modifications diverge, first, disabling the DRLs:
cover the connector with electrical tape to seal it from the elements and protect it from shorting.
To clean it up, tuck the loose connector under the adjacent wire harness and secure with electrical tape
Full-power DRLs
Looking into the loose connector, you will see two slots with metal contacts
Cut a short length of wire (I used 14ga, 12ga was a bit too large, you don't want to go too small, otherwise the resistance may cause the wire to heat up) and strip the ends
Insert the ends of the wire into the two slots in the connector, this bypasses the box which is a regulator which provides less power than directly wiring the DRLs, thus increasing the output of the DRLs
As with the other modification, seal the connector with electrical tape and tuck it under the adjacent wire harness.
Optional for either modification: remove the DRL regulator box
Since both of these modifications remove the DRL box from the circuit, you can remove the box from the car. Simply unbolt the two nuts on the shock tower with a 12mm socket wrench with extension.
Now you're done
You now either have no DRLs or you have brighter DRLs (good for use with whiter bulbs to better match the headlights). Neither of these modifications modify any other functions of the car, including high-beams. If you also removed the DRL box, you just shaved 1/2 a pound off your car by my scale, with all this excess weight removed, you're shit will be FAST, you should easily be able to beat any car you come across provided you use 3rd gear (and the PWR button if you are E-Shift**)
**Neither I nor my.is condone illegal street racing, please test this claim in controlled conditions on a track.
Cobra Project:
longnights is offline Reply With Quote
Old 03-02-2010, 03:25 PM   #2 (permalink)
tonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community membertonynca is an elite community member
Beware when shorting the DRL plug for full power. I've seen a connector melt as a result of doing so. There must be some strong current going through to be able to do that.
'03 IS300 SD TCM 5-SPD LSD
Bilstein| Eibach Pro-Kit | Hotchkis | TRD Filter | Joe-Z | B&M
tonynca is offline Reply With Quote
Old 05-20-2010, 08:39 PM   #3 (permalink)
night2 is an unknown at this point
Tried this mod the other day and it did not work. the DRLs didn't even come on.
night2 is offline Reply With Quote
Old 05-21-2010, 05:48 AM   #4 (permalink)
dominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community memberdominicanodcora is an elite community member
Works fine for me.
dominicanodcora is offline Reply With Quote
Old 07-08-2010, 09:58 AM   #5 (permalink)
nyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community membernyt_rydr is an elite community member
Does this work on the 2001 models? I'm having the same issue getting full power to the DRL's
nyt_rydr is offline Reply With Quote
Old 07-27-2010, 06:36 PM   #6 (permalink)
highkwelity is an unknown at this point
Originally Posted by dominicanodcora View Post
Works fine for me.
What bulbs are you using? LED?
highkwelity is offline Reply With Quote
Old 08-22-2010, 06:19 PM   #7 (permalink)
LoKisSpYdR is an unknown at this point
OK, I've done exactly as described and still have half power on DRLs. Literally NO Box and 14G jumper and still have half power. Can anyone explain this?
02 SY IS300 E-Shift - Tokico Illumina, Tein S-Tech, Joe-Z Intake, Debadged, Megan Rear Arms......
02 Audi S4 6 SP - AWE RSK04 Turbo Kit, Milltek CatBack, Bilstein, Eibach Pro, AWE DTS, Debadged, etc.
01 Audi A6 4.2L V8 - GIAC Chipset E&T, Bilsteins, Eibach Pro, K&N CAI, LLTEK Splitter, Blackout Tails, Debadged
LoKisSpYdR is offline Reply With Quote
You may not post new threads
You may not post replies
vB code is On
HTML code is On
