Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010) - Lexus IS Forum
post #1 of 11 (permalink) Old 05-15-2008, 05:06 PM Thread Starter
Übercargeek
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-19_in_forged_alloy_wheels_1.jpgOn 30 October 2007, we posted our initial story on Lexus' F-Sport line of accessories for the 2nd-generation Lexus IS. Debuting at the 2007 SEMA show in Las Vegas, information came out in slow dribs and drabs since then, as shown by the numerous posts following our initial article. Thus, now that these parts are finally on sale, and pricing and parts numbers have been issued, we felt that a follow-up story was in order. And, with the subsequent addition of F-Sport Floor Mats and Shift Knob to the line, not to mention the summer 2009 expansion of the F-Sport line to the IS 250 AWD, IS C and 3rd-generation Lexus GS, we carried out our first update to this story on September 2009. Then, with the printing of the second edition of Lexus' F-Sport accessories brochure, we learned of further updates to Sway Bar and Floor Mats parts numbers, which are noted below in their respective sections. And, in September 2010, the 19" Full-Face Forged Alloy Wheels and the Onboard Tire Repair System join the F-Sport Accessory line.
Before we get into that, however, a couple of caveats are in order. First of all, be sure to check out the F-Sport accessory Warranty Information. F-Sport Accessories, when installed by an authorized Lexus dealer, are warranted for the balance of the new-car or Certified Pre-Owned (CPO) warranty, or for 12 months from the date of installation, whichever is greater. If, on the other hand, you prefer to install the parts yourself (or have your wrench monkey buddy or your trusted independent mechanic do it), you might save on labor but the warranty will be strictly for 12 months.
Also, we remind you that the prices listed are MSRP, which is short for Manufacturer's Suggested Retail Price. Your local dealer is free to sell them for more or for less than those prices. It may also be worthwhile checking with my.IS Supporting Vendors such as Sewell Lexus Online, L-TunedParts.com and Lexus of Watertown.
Without further ado, these are the goodies that Lexus is offering for the 2nd-generation Lexus IS (except the IS F), 3rd-generation GS and IS C:
18" 10-Spoke Forged Alloy Wheels
This lightweight forged alloy wheel, exclusively designed in a dark graphite finish, is a new offering for IS AWD sedans, and includes a non-staggered fitment with 18" X 8" front and rear wheels. Recommended tire size is 225/40R18. (Tires not included in prices below)
PTR45-53083: $439 each
Set of 2 Front and 2 Rear Wheels: $1,756
Wheel Lug & Lock Kit (Vehicle Set) for AWD models PTR27-53090: $165
19" 10-Spoke Forged Alloy Wheels
This lightweight forged alloy wheel, exclusively designed in a dark graphite finish, includes a staggered fitment with 19" X 8" front wheels and 19" X 9" rear wheels for all RWD IS, IS C and GS models, with recommended tire sizes of 225/35R19 in the front and 255/35R19 in the rear. For the GS350 AWD, a non-staggered fitment of 19" X 8" wheels with 225/40R19 tires is recommended. (Tires not included in prices below)
Front Wheel for RWD / Front & Rear Wheel for AWD PTR45-53081: $499 each
Rear Wheel for RWD PTR45-53082: $599 each
Set of 2 Front and 2 Rear Wheels for RWD: $2,196
Set of 2 Front and 2 Rear Wheels for AWD: $1,996
Wheel Lug & Lock Kit (Vehicle Set) for RWD models PTR27-53080: $150
The Lexus F Sport Accessory line's newest items-19_in_full_face_forged_alloy_wheels_rwd_1.jpg19" Full-Face Forged Alloy Wheels
This lightweight forged alloy wheel, exclusively designed in a distinctive liquid silver high-gloss finish, includes a staggered fitment with 19" X 8" front wheels and 19" X 9" rear wheels for all RWD IS, IS C and GS models, with recommended tire sizes of 225/35R19 in the front and 255/35R19 in the rear. For the GS350 AWD, a non-staggered fitment of 19" X 8" wheels with 225/40R19 tires is recommended. (Tires not included in prices below)
Front Wheel for RWD / Front & Rear Wheel for AWD PTR45-30102: $499 each
Rear Wheel for RWD PTR45-30103: $599 each
Wheel Lug & Lock Kit (Vehicle Set) PTR27-30010: $135
Front Brake Upgrade
The Front Brake Upgrade provides a firmer pedal feel and improved fade resistance in repeated severe duty use. The kit features six piston fixed calipers, and drilled cast-iron 355mm diameter rotors with a patented internal fin design mounted on anodized aluminum hubs. Braided stainless steel brake lines and low-dust performance brake pads are included, and the upgrade can be used with stock rear brakes or in conjunction with the F-Sport Rear Brake Upgrade. With the Front Brake Upgrade, the compact spare tire cannot be used. In the event of a flat, the tire must be repaired or replaced.
IS250, IS250 AWD and IS250C PTR09-53080: $3,025
IS350, IS350C, GS350 and CS350 AWD PTR09-53081: $3,025
Rear Brake Upgrade
Similar in construction to the F-Sport Front Brake Upgrade, the rear brake upgrade features four piston fixed calipers and drilled cast-iron 345mm diameter rotors. Braided stainless steel brake lines and low-dust performance brake pads are also included. The Rear Brake Upgrade may only be used in conjunction with the F-Sport Front Brake Upgrade. With the Rear Brake Upgrade, the compact spare tire cannot be used. In the event of a flat, the tire must be repaired or replaced.
IS250 and IS250 AWD PTR09-53082: $2,550
IS350 and IS350C PTR09-53083: $2,550
IS250C, GS350 and GS350 AWD PTR09-53100: $2,550
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-lowering_spring_set_1.jpgLowering Spring Set
This feature lowers the vehicle approximately 1" in the front and rear for a more aggressive appearance and a lower center of gravity. The spring set is engineered to deliver lowered ride height without bottoming out or creating a harsh ride. The feature can be used with either the stock or F-Sport Shock Absorber Set.
Set of four springs for IS sedans PTR07-53090: $299
Set of four springs for IS C PTR07-53100: $299
Set of four springs for GS RWD PTR07-30090: $299
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-bilstein_shock_absorber_set_1.jpgBilstein Shock Absorber Set
Developed in cooperation with Bilstein and available exclusively through the F-Sport Performance Accessory program, this shock absorber set offers sport-tuned suspension dampening without sacrificing ride quality.
Right Front Shock for IS and GS RWD sedans PTR13-53093: $185
Left Front Shock for IS and GS RWD sedans PTR13-53094: $185
Rear Shock for IS and GS RWD sedans PTR13-53095: $185 each
Right Front Shock for IS250 AWD PTR13-53090: $185
Left Front Shock for IS250 AWD PTR13-53091: $185
Rear Shock for IS250 AWD PTR13-53092: $185 each
Right Front Shock for IS C PTR13-53080: $185
Left Front Shock for IS C PTR13-53081: $185
Rear Shock for IS C PTR13-53098: $185 each
Set of 2 Front and 2 Rear Shocks: $740
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-sway_bar_kit_rwd_1.jpgSway Bar Kit
This includes larger diameter, replacement sway bar(s) that offer reduced body roll and flatter cornering. High-durometer rubber bushings are also included to replace the original bushings.
2006-2008 IS RWD sedans PTR02-53082: $495
2009-2010 IS RWD sedans PTR02-53094: $495
IS250 AWD PTR02-53096: $549
IS C PTR02-53100: $495
GS350 RWD PTR02-30090: $495
GS350 AWD PTR02-30091: $549
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-rear_chassis_member_brace_1.jpgRear Chassis Member Brace
To enhance chassis stiffness under aggressive driving conditions and provide a more responsive feel during cornering, the F-Sport Rear Chassis Member Brace joins key rear chassis and suspension mounting points through a tubular steel brace design. (Not applicable to IS C and GS models)
PTR02-53081: $375
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-exhaust_system_1.jpgExhaust System
This system features all stainless steel construction with fully polished mufflers and double-wall exhaust tips. In addition to an outstanding appearance, it delivers a powerful, sport-tuned exhaust sound.
IS sedans PTR08-53090: $1,470
IS C PTR08-53100: $1,470
GS PTR08-30090: $1,670
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-clutch_1.jpgClutch
The F-Sport Clutch increases clamping force approximately 15% to handle higher torque capacity and provide improved feel. (IS250 and IS250 C Manual only)
PTR15-53080: $599
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-quick_shifter_1.jpgQuick Shifter
Engineered and machined from billet aluminum, the F-Sport Quick Shifter decreases shift throw by approximately 30% for positive shifting. (IS250 and IS250 C Manual only)
IS250 sedan PTR46-53080: $300
IS250 C PTR46-53100: $300
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-carbon_fiber_engine_cover_1.jpgCarbon Fiber Engine Cover
Constructed from real carbon fiber, this very light and durable engine cover provides a high-tech appearance underhood. This is a direct replacement for the original cover.
IS250 and IS250 C PTR48-53080: $865
IS350, IS350C and GS350 PTR48-53081: $865
Lexus F-Sport Accessories for the IS C, 2nd-gen IS & 3rd-gen GS (updated Sept 2010)-air_intake_assembly_1.jpgAir Intake Assembly
This low restriction intake and filter assembly is fully compatible with stock engine controls and is emission legal in all 50 states.
IS and GS sedans PTR03-30090: $455
IS C PTR03-53100: $455
Filter Cleaning Solution PTR03-53085: $29
The Lexus F-Sport accessory line expands its reach-f-sport_shift_knob-prv.jpgShift Knob
Made from premium leather and genuine carbon fiber, these shift knobs are direct replacements for the factory shift knob. Detailed with blue stitching, each knob features a silver F-Sport logo.
Automatic Transmission PTR51-53080: $95
Manual Transmission PTR51-53081: $95
The Lexus F-Sport accessory line expands its reach-f-sport_floor_mats-prv.jpgFloor Mats
This four-piece carpet floor mat set is made from the same 18-ounce nylon carpet as the factory mats. F-Sport mats are offered in black with a sliver embroidered logo. Aggressive backing nips and a retention clip keep the mats from sliding.
IS RWD sedans PT208-53097-02: $115
IS250 AWD PT208-53098-02: $115
IS C PT208-53095-02: $115
GS350 RWD PT208-30097-32: $115
GS350 AWD PT208-30099-32: $115
The Lexus F Sport Accessory line's newest items-onboard_tire_repair_system_1.jpgOnboard Tire Repair System
The Onboard Tire Repair System (OTRS) is intended to repair punctures of up to a quarter-inch diameter in the tread area of the tire. The tire repair is temporary. Athough the tire will last for up to 500 miles, the intention is to allow the motorist to quickly and safely complete the repair, get back on the road and proceed as soon as possible to an authorized tire repair facility to have the tire permanently repaired.
PTR53-00100: $99
ID:	16945   Click image for larger version
ID:	16946   Click image for larger version
ID:	16947   Click image for larger version
ID:	16949   Click image for larger version
ID:	16950   Click image for larger version
ID:	16951   Click image for larger version
ID:	16953   Click image for larger version
jruhi4 is offline
post #2 of 11 (permalink) Old 05-15-2008, 06:16 PM
Under House Arrest
mikefate's Avatar
Those wheels are hot. Glad to see they are stepping up the tuning game.
What are the wheel offsets? I'd sure like to have them on my first gen...
mikefate is offline
post #3 of 11 (permalink) Old 05-15-2008, 07:07 PM
It'd be nice to know the offsets of those wheels. They are really nice...
-= '03 IS . 5 SPEED . LSD =-
HKS : TRD : GReddy : H&R
junedog is offline
post #4 of 11 (permalink) Old 05-15-2008, 07:21 PM Thread Starter
Übercargeek
From the Sewell Lexus Parts F-Sport Wheel page:
Front Wheel
Size: 19 x 8 inches
Bolt Pattern: 5-114.3
Offset: 40 mm
Weight: 21.40 lbs
Accepts TPMS Sensors
Rear Wheel
Size: 19 x 9 inches
Offset: 40 mm
Weight: 20.85 lbs
I suspect, however, that the front and rear wheel weights are inverted. Shouldn't the wider rear wheels be heavier than the narrower fronts?
Source: Sewell Lexus Parts
jruhi4 is offline
post #5 of 11 (permalink) Old 05-15-2008, 11:50 PM
VERY nice, comprehensive overview.....I'm sure the rest of the IS fans can agree we're a little tired of putting the F-Sport jigsaw puzzle together.
Thanks a bunch.
P.S.: So far, I'm very pleased with both intake and exhaust.....
2008 Lexus IS 350 - Smoky Granite Mica
*OEM 18" split five-spoke alloy wheels
*OEM Rear Spoiler
*F-Sport Performance Exhaust System
*F-Sport Performance Air Intake
*F-Sport RWD Sway Bar Kit
Active Member - SCCA, NASA, ESCA
LancerEvo12 is offline
post #6 of 11 (permalink) Old 05-16-2008, 10:18 AM
Photographer
Too bad we didn't have F-Sport for the 1st gen. 50 state legal intake and headers would have been nice.
SingleLens
altezzagita is offline
post #7 of 11 (permalink) Old 05-17-2008, 02:41 PM
We did, however, have L-tuned.
ucool22 is offline
post #8 of 11 (permalink) Old 05-24-2008, 08:52 AM
When I worked at the dealership, the parts department wasn't given any part numbers to order and the only thing they could get their hands on was the wheels. And Lexus told them that they couldn't be put on IS250 or IS350's. But maybe this will change in the future?....
IS300
WRECKEDIS300 is offline
post #9 of 11 (permalink) Old 05-27-2008, 07:05 AM Thread Starter
Übercargeek
It seems your dealer was misinformed at the time. All the F-Sport accessories listed in this article are meant for the 2nd-generation IS (IS 250 and IS 350), including the wheels.
jruhi4 is offline
post #10 of 11 (permalink) Old 10-01-2008, 07:17 PM
Are they adding any additional accesories this year?
Joe Z intake
Eibach Pro Street Lowering Springs
F-Sport exhaust system
Billet Grille - upper and lower
wicked1127 is offline
post #11 of 11 (permalink) Old 10-02-2008, 06:41 AM Thread Starter
Übercargeek
Not to my knowledge.
jruhi4 is offline
  Lexus IS Forum > Site News & FAQs > News > Aftermarket Spotlight
HTML code is On
