Lexus IS Reverse/Backup LED Bulbs! Install Video! Ships Same-Day! Plug & Play - Lexus IS Forum
post #1 of 20 (permalink) Old 06-18-2015, 09:48 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 14 Post(s)
Arrow Lexus IS Reverse/Backup LED Bulbs! Install Video! Ships Same-Day! Plug & Play
Lexus IS Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your reverse light or backup light bulb. We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs, for perfect fitment in your Lexus IS Model Year Selection.
Bulb Design
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
Fitment. All three bulbs use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 20 (permalink) Old 07-23-2015, 02:59 PM
Quoted: 178 Post(s)
Would you please pm me a quote for these shipped to 95687?
Dome Light LED for 2003 Lexus IS Sedan
Color: Cool White (6000K)
Bulb Model: SMD12 Board (118 lumens)
License Plate LEDs for 2003 Lexus IS Sedan (pair)
Bulb Model: HP5 (92 lumens)
2003 Lexus IS Sedan Trunk Light LED
Bulb Model: FlexLight (200 lumens)
Thank you!
White2003Lexus is offline
post #3 of 20 (permalink) Old 07-23-2015, 03:29 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Send us a PM to receive the code for free-shipping @White2003Lexus
Thanks!
Nick C.
post #4 of 20 (permalink) Old 07-23-2015, 05:59 PM
Quoted: 178 Post(s)
Sent! Thanks!
Diode Dynamics likes this.
post #5 of 20 (permalink) Old 08-18-2015, 09:19 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Thanks for ordering with us!
Nick C.
post #6 of 20 (permalink) Old 11-01-2016, 05:06 AM
Quoted: 11 Post(s)
this is so awesome
TLT Strategies is offline
post #7 of 20 (permalink) Old 11-01-2016, 05:06 AM
Quoted: 11 Post(s)
Do you guys handle custom headlight retrofits?
post #8 of 20 (permalink) Old 11-09-2016, 11:41 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
We manufacture components for custom headlight builds. If you need a referral to a professional installer, please feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
post #9 of 20 (permalink) Old 03-31-2017, 08:13 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
(314) 205-3033
post #10 of 20 (permalink) Old 04-02-2017, 04:33 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
post #11 of 20 (permalink) Old 04-03-2017, 06:37 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
PM responses sent!
Nick C.
post #12 of 20 (permalink) Old 04-04-2017, 03:51 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Our dealer locator tool has been updated, check it out to find a dealer near you:
Diode Dynamics Dealer Locator Map
Thanks!
Nick C.
post #13 of 20 (permalink) Old 04-06-2017, 09:31 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
post #14 of 20 (permalink) Old 04-11-2017, 03:48 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
PM responses sent!
Thank you,
Nick C.
post #15 of 20 (permalink) Old 04-13-2017, 09:59 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Send questions to: Contact@diodedynamics.com
  Lexus IS Forum > Supporting Vendors > Diode Dynamics
