Lexus IS Fog Light LED Bulbs! Install Video! Luxeon LED Replacement Housings! - Lexus IS Forum
post #1 of 19 (permalink) Old 06-15-2015, 12:48 PM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 14 Post(s)
Lightbulb Lexus IS Fog Light LED Bulbs! Install Video! Luxeon LED Replacement Housings!
We carry LED bulbs for replacement of your Lexus IS fog lights, in all major sizes. They are available in HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go! We also offer Luxeon LED Housings for a complete replacement of your factory fog light housings (See Install Video)
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
*XML2 is available in 3000K Yellow / 4000K / 5000K / 6000K Color Temperature Options*
Luxeon LED Replacement Housing: Powered by three genuine Luxeon T LED chips per side, the perfect 5000K white color provides a brilliant LED illumiunation, with a Trulux measured output of 600 lumens. (Please note: similar styles of lamp can be found online which claim much higher output, but these numbers are highly inflated. These lamps are the brightest on the market!)
Available for the following IS Models and Model Years:
Lexus IS250 2011-2014
Lexus IS350 2011-2014
Lexus IS-F 2008-2013
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Luxeon LED Replacement Housing: Integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Lexus ISF Fog Light LED
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is offline
post #2 of 19 (permalink) Old 06-15-2015, 12:55 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
post #3 of 19 (permalink) Old 03-24-2016, 01:06 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Customer Submitted photo with Yellow XML2 Installed
Nick C.
post #4 of 19 (permalink) Old 04-12-2016, 03:48 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
H11 XP80 Installed on a 2014 IS 250
Nick C.
post #5 of 19 (permalink) Old 03-24-2017, 11:15 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Please send us a PM to receive the free-shipping code
(U.S. members only)
Thanks!
Nick C.
post #6 of 19 (permalink) Old 03-27-2017, 09:02 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
PM responses sent
post #7 of 19 (permalink) Old 03-28-2017, 05:46 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Visit our site to learn more: Diode Dynamics
post #8 of 19 (permalink) Old 03-31-2017, 09:46 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
(314) 205-3033
post #9 of 19 (permalink) Old 04-02-2017, 08:24 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
post #10 of 19 (permalink) Old 04-03-2017, 08:12 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
PM responses sent!
Nick C.
post #11 of 19 (permalink) Old 04-04-2017, 05:24 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Our dealer locator tool has been updated, check it out to find a dealer near you:
Diode Dynamics Dealer Locator Map
Thanks!
Nick C.
post #12 of 19 (permalink) Old 04-06-2017, 11:03 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
post #13 of 19 (permalink) Old 04-07-2017, 10:58 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Send us a PM to receive the free-shipping code
*U.S. members only
Thanks!
Nick C.
post #14 of 19 (permalink) Old 04-11-2017, 05:26 PM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
PM responses sent!
Thank you,
Nick C.
post #15 of 19 (permalink) Old 04-13-2017, 11:38 AM Thread Starter
Supporting Vendor
Quoted: 14 Post(s)
Send questions to: Contact@diodedynamics.com
  Lexus IS Forum > Supporting Vendors > Diode Dynamics
