Dr. Colorchip DIY/Review (PICS) - Lexus IS Forum
post #1 of 83 (permalink) Old 03-07-2009, 07:21 PM Thread Starter
This is what most people have been waiting for. A review/ show and tell of the Dr. Colorchip System. I got the package Friday night and this is what it included:
^^ the paint according to the color of my car, the sealant, a small two sided brush, and the glove to spread the paint. also some directions and tips were included there as well.
^^ close-up of the paint and the sealant containers
^^ as you can see...this code matches my factory paint code for millennium silver metallic which is 1C0
^^close-up pic of what the brush looks like
2005 MSM Lexus IS300
Stock?
SupraMan1784 is offline
post #2 of 83 (permalink) Old 03-07-2009, 07:25 PM Thread Starter
^^the sexy car, had to pull it partly into the garage to get it out of the sunlight...which never showed haha. so the pic is dark and you cant really see the damage...but its there
^^just some of the places showing the damage that needed to be taken care of. most of it was on the front of the hood and the bumper. also had a scratch from a dealer and a few scratches in the rear that had to be taken care of. i only took pics of a few spots..they basically look the same...silver with a bunch of rock chips....love that Lexus Premium Paint right?
Stock?
post #3 of 83 (permalink) Old 03-07-2009, 07:33 PM Thread Starter
^^ look at the open bottle of paint...smells and looks just like the oem touch up paint from the dealer.
^^armed with the brush and the glove im pretty much ready to get to work.
^^my car looks like it has freckles haha. pretty much followed the directions. gave it a quick wash and dry in the morning and once the car was dry i started applying the colorchip paint. i didnt use the small side of the brush...mainly the broader end...dabbed the paint on the chip and smeared it with the glove. ***be sure to smear it flat while keeping the chip still painted. otherwise it will make the process a little more difficult later...which i will elaborate on when i get there. but as you can see i did a large area... which extended the amount of time i was working on the car. at this point it tells you the chips dry in 2 mins...but should be left on the car a max of 2 hours for better adhesion of the paint... at this point i just went back inside to grab a bite to eat and came out about an hour later
Stock?
post #4 of 83 (permalink) Old 03-07-2009, 07:39 PM Thread Starter
once i came back out. i used the blender/sealant on a clean, old tshirt....again following the instructions which told me to moisten a small piece of the cloth so i can start buffing away. this part took me forever because i did such a large area ***this is also the reason why you should try and keep your smears flat... it takes some time for the blending agent to kick in...which when buffing removes the excess paint on the clear coat while leaving the paint on the chip. i rubbed it gently...too hard and the paint in the chip starts to come out and you basically have to start over again. i would say it took me about 2 hours and a little bit to buff all the excess paint away. here are the results:
Stock?
post #5 of 83 (permalink) Old 03-07-2009, 07:48 PM Thread Starter
REVIEW:
here is my review on the Dr. Colorchip system. Honestly, when I first got it I thought it was going to fill in the chips and make it smooth like how it came from the factory. as i progressed i realized that wasnt the case, what it basically does is paint the chip like touch-up paint would do and blend it in with the rest of the hood so it looks like there was no damage. the process, in general, was pretty simple. no tricks or secrets to anything. just dab the paint smear it in and wait for it to dry. once it was dry buff the painted area with the blender/sealant and its good to go. for the smaller rock chips as you can see from my pics it does an excellent job of blending it in with the rest of the paint. the larger scratches, not so much. even some of the larger rock chips came out pretty nice...there's a good part and a bad part about it though. the good part is from about one or two steps away it looks perfect...the bad news is once you get up close and personal you can still see all the chips...except theyre painted, so i guess its not that bad. some of the basic tips i already spoke about...like not putting globs of paint everywhere...the reason..it makes it harder to buff because you gotta use more effort and time to get those off the car. also...the next time i do it i would probably do smaller areas at a time...since doing a larger area consumes a lot of time. all in all i was pretty happy with the results and i saved the glove and brush because i still have a bunch of paint and sealer left for another job. on a scale of 1-10 on how effective it was...i would probably give it an 8/8.5....my only problem with it was...i wish it would fill the chip in haha but i still yielded some real good results. if you have any questions just post them up and ill answer them when i get a chance. thanks guys.
Stock?
post #6 of 83 (permalink) Old 03-07-2009, 07:53 PM
Very nice write up! +rep when I can
-HKS-VOLK RACING-ROTORA-TEIN-JIC-LTUNED
destron25 is offline
post #7 of 83 (permalink) Old 03-07-2009, 08:49 PM
Quoted: 150 Post(s)
Excellent DIY, thank you! Did you try getting the same spot twice to see if the chip fills more than the first time? Are the painted chips good to go, or would it be a good idea to cover them with a clear coat and then do step 2 again? Last question: which kit did you get...Sandard? +REP!
rvalero is online now
post #8 of 83 (permalink) Old 03-07-2009, 10:00 PM
Photographer
excellent write up
SingleLens
altezzagita is offline
post #9 of 83 (permalink) Old 03-07-2009, 10:33 PM
Jedi Knight
Tigger's Avatar
Interesting. +rep
2003 Lexus IS300 - Graphite Gray Pearl 5MT (sold)
2010 Lexus RX350 - Starfire Pearl
2014 Mercedes-Benz E350 Sports - Polar White
2015 Toyota Sienna Swagger Wagon - Super White
Tigger is offline
post #10 of 83 (permalink) Old 03-08-2009, 09:37 AM Thread Starter
hmm i didnt try the same spot twice...good idea i might go out again to see if that would work on a few spots. well according to what i read, after doing the colorchip youre supposed to apply wax. the reason i did it this weekend is because im getting the car detailed next week so ill have to wait till then to get it officially sealed. yea i got the basic kit, it was more than enough. you can be liberal with the paint but like i stated...it gets to be kind of a bitch when you keep buffing away to get that excess paint off.
Stock?
post #11 of 83 (permalink) Old 03-08-2009, 11:09 AM
well done sir.... +rep
01 BO IS300 E-SHIFT LSD
Pioneer AVH-P4100DVD, JOE Z INTAKE, MUFFLER DELETE, FOGLIGHT MOD, JDM SHORTY ANTENNA, 15% TINTS
best mods are cheap mods
sotsyndicate.com where being Super Off Topic is being on topic
agoodall is offline
post #12 of 83 (permalink) Old 03-09-2009, 05:38 PM
Awesome detail!! I have a few small chips just like you so I will probably place an order as well. You mentioned that it only paints the chip, not fills it. Do you think that if you applied multiple coats it would fill it/even it out?
If your baby needs a washin', shoot me a PM.
04 C32 AMG
04 IS300
redfarsi is offline
post #13 of 83 (permalink) Old 03-09-2009, 06:01 PM
Quoted: 150 Post(s)
This should answer most people's questions: Dr. ColorChip paint chip repair tips and FAQ's about our kits.
I put in an order too.
post #14 of 83 (permalink) Old 03-09-2009, 07:50 PM
Patriot
Hmmm... Interesting.
From the pictures, it looks like it did a great job. Thanks for sharing your review and DIY, it'll come in handy! +Rep
AznStrike is offline
post #15 of 83 (permalink) Old 03-10-2009, 06:59 AM Thread Starter
im gonna find out sometime this week...when it stops raining
Stock?
