DIY: Removing Front Bumper and Headlights (lots of pics and a video) - my.IS - Lexus IS Forum
b
Go Back   my.IS - Lexus IS Forum > Lexus IS > DIY/tutorial forum
Register Home Forum Photos Active Topics / Realtime Insurance Garage iTrader User's Guide Mark Forums Read
» Log in
Not a member yet?
Register Now!
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Old 03-02-2008, 09:07 AM   #1 (permalink)
StevenSTi's Avatar
StevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community memberStevenSTi is an elite community member
That Yahoo pictures DIY didnt work anymore, and Im sure theres another DIY out there, but I took the time to take some pics of me doin this so I'm doin this write up. Enjoy
Tools Needed:
3/8 drive socket and 10mm socket
3/8 drive extension
1/4 drive socket and 10mm socket
Flathead screwdriver
Phillipshead screwdriver
Step One:
I find it easier to remove all the under panel screws first, it will give you more play in the plastic in the wheel well and make it easier to pull the bumper around it when that time comes. All the bolts at 10mm around the bottom.
Step Two:
Remove the front two plastic push rivets from each side with a flathead screwdriver. Just pop the head out and the rest will will come out too with a little force of the flathead
Step Three:
Pop the plastic out form behind the bumper and pull it back a little. It will take a little force to pop it out around the top, but it will come out, just pull.
Step Four:
Unscrew the top bolt on the inside of the plastic. As you do this, you will begin to see the bumper drop down at the corners just under the headlight. This is also a 10mm socket, just find it and unscrew it.
Step Five:
Remove the 4 plastic screws on the outside of the grill and the screw in the center of the grill. You don't have to take the grill completely off, the bumper will still drop with the tabs attached
Step Six:
Start pulling on the bumper until you have it off all the way around and then drop it down to the ground. I always lay a towel out so that the bumper doesn't set directly on the ground
Step Seven:
This step will be different for most other people since i have HID fogs, but you can just unplug the connector from the fog light bulb (depending on the length of your wire you may have to reach behind the bumper before you pull it off to do this so you have enough room to set it on the ground)
Your bumper is now off the car. Now on to the headlight removal.
Step Eight:
Unbolt the screw on the top of the headlight. 10mm screw
Step Nine:
you have to get inside the wheel well to see these two bolts on the back of the headlight. They are a pain in the ass to get, the bottom one can be gotten with the 3/8 drive socket, but the top one is easier to get with a 1/4 drive, especially if you have big hands like me. They are both 10mm
Step Ten:
You will have to wiggle the headlight out as far as it will go and then pull it up and out. If you do it right, it will sound like you broke something, like two piece of plastic were snapped apart. See the video to hear this and see how to pull it out
If you need to take the headlight all the way out, just pull the connectors off all of the bulbs and any thing else that needs to be unplugged and pull it out. Hope this helps anyone out and if you have any questions, PM me of post them up.
©2006 my.IS
2005 Subaru STi
StevenSTi is offline   Reply With Quote
Old 03-02-2008, 09:26 AM   #2 (permalink)
aschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community memberaschueler is an elite community member
nice +rep
2003 IBP 5-speed (GONE)
2007 Audi S4 DTM
Miltek / Deval / KW V3 / APR / Hawk / AR Rotors
aschueler is offline   Reply With Quote
Old 05-24-2008, 02:28 PM   #3 (permalink)
Location: Pulled over to the side with red and blue in the rearview, CT
Xentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community memberXentix is an elite community member
This was a huge help. I might add tho, you dont need to fully drop the bumper down to remove the headlights altho it is a little bit of a help.
Thanks for this write up. +rep
_Xen aka Craig :)
avid do-it-MYselfer
01 DWP IS300
K&N FIPK| REVOTEC stb| ALPINE/KENWOOD| SCANGUAGEII| CDX "L" GRILLE
MATCHING GUNMETAL *all* AAC 10k DEMON EYES| AAC HALO DARKENED TAILS| DARKENED FOGS + Oracle 6K HID UPGRADE
04 Sonic Blue F150 Lightning
"Bike Hauler" - Built Engine ;)
AAC DUAL SMD HALOS - ALL Oracle HIDs - Retro LED Tails
08 Aprilia RSV1000R Black/Red
MiVV GP Titanium Exhaust| PowerCommander III USB| Oracle 8K HIDs
Xentix is offline   Reply With Quote
Old 05-24-2008, 10:12 PM   #4 (permalink)
ins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community memberins0mnia is an elite community member
why you takin out ur lights just curious?
'02 GGP SportX
Black Headlight Housings | DDE's | Stand-Alone Fog Mod | Switched Full Power DRL's | SRT Hi-Fi Intake | Pioneer AVIC-D3 Navi
ins0mnia is offline   Reply With Quote
Old 05-25-2008, 07:47 AM   #5 (permalink)
StevenSTi's Avatar
just to do the writeup...I was bored at that time, and there were 4 or 5 people on the old DIY thread that were complaining about the pics not workin. I also did the DIY inner trunk light removal the same time, that one was easier
©2006 my.IS
2005 Subaru STi
Old 05-25-2008, 08:08 AM   #6 (permalink)
BBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community memberBBAtl6 is an elite community member
^^he's the kind of guy who would take the out just for fun and clean the underside of the light for the hell of it (even though nobody would ever see it)
2005 GGP
SRT, HKS, Hotchkis, H&R, Tokico, Mazzuri, Magnaflow, AAC, Pioneer, Infinity, SD
BBAtl6 is offline   Reply With Quote
Old 06-08-2008, 11:37 AM   #7 (permalink)
HERBos HERBos HERBos HERBos HERBos HERBos HERBos HERBos HERBos HERBos HERBos
hey guys. i'm tryign to remove my headlights and im at the part where i have to take out my wiring harness. does anyone know how to disconnect it?
HERBos is offline   Reply With Quote
Old 06-08-2008, 01:01 PM   #8 (permalink)
you just need to disconnect the wires to take the headlight out? all you need to do is disconnect all of the connectors that are attached to the bulbs.
2005 GGP
Old 06-08-2008, 01:24 PM   #9 (permalink)
Patriot
diegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community memberdiegolex is an elite community member
so you can just remove the headlights whitout taking off the bumper?
2003 GGP SportX
Tein H-tech springs/Teck Grounding Kit/XERD Y-Pipe//Blitz LM filter/Nokya 2500K DRL/Z-Edition grill/Pioneer f-700bt/Vertex fenders/
diegolex is offline   Reply With Quote
Old 06-08-2008, 04:36 PM   #10 (permalink)
02isjw's Avatar
my.IS Supporter
02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member02isjw is an elite community member
Nice write-up!!!
©2006 my.IS
2004 S4 6MT: "Gertrude" Sold :-/
2002 IS300 AR 5MT: "Rhonda" Sold :-(
"Wheel gap is like vagina... The more fingers you can fit, the worse off you are."
Praise the lowered!
02isjw is offline   Reply With Quote
Old 06-08-2008, 07:22 PM   #11 (permalink)
no, you have to remove the bumper
2005 GGP
Old 09-27-2008, 10:31 PM   #12 (permalink)
eboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community membereboy0 is an elite community member
It doesn't seem like there are any bolts hidden behind the bumper itself? So i don't see why you can't take out the headlights without taking off the bumper.?
eboy0 is offline   Reply With Quote
Old 09-27-2008, 11:16 PM   #13 (permalink)
StevenSTi's Avatar
there is a way to do it, but you seem like you would scratch the paint. there are clips that you have to pop out, watch the video, you'll see when I pop the headlight out I pull up and out. It wont clear the bumper
©2006 my.IS
2005 Subaru STi
Old 09-28-2008, 01:33 PM   #14 (permalink)
Slvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community memberSlvrbullet is an elite community member
i did this recently to change the bulbs and paint the fogs what a pain in the ass but at least i had some help...
GGP IS300-2.75 srt turbo-megan coils, rotora bbk, volk le-37's,custom tinted tails, black pearl badging, lots of other stuffs..
MSM IS300-intake, chrome shortie antenna, painted calipers...
Slvrbullet is offline   Reply With Quote
Old 10-22-2008, 05:11 PM   #15 (permalink)
Kingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community memberKingu 808 is an elite community member
When your HID's go bad you'll need to remove your bumper and headlights to change the bulbs out...I recently had to change mine and it took me about 2hrs start to finish...
02' W55 Torsen - AEM Tein Hotchkis TRD Cusco JIC PLP B&M Tanabe ACT Fidanza Work FIGS Megan Blinder Titan TokenSolutions BrianCrower eBay
Kingu 808 is offline   Reply With Quote
You may not post new threads
You may not post replies
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
