DIY: LS400 Caliper Install - Lexus IS Forum
post #1 of 52 (permalink) Old 01-21-2011, 09:37 PM Thread Starter
Install Guide DIY: LS400 Caliper Install
this swap is from a 95-00 LS400 to the 01-05 IS300
Begin by collecting all the parts:
LS400 Calipers,
LS400 EBC greenstuff pads:
LS400 EBC Rotors:
FIGS RCA Spacer (contact for purchase):
Caliper adapters (FIGS):
'EARLS' Brake Lines 12"/Fittings/adapters:
MOTUL Brake Fluid:
Brake Parts Lubricant:
-- You have the option to choose whatever brands fits your preferences, this is what i have used and what i recommend. however there are many other very good brands for a variety of purposes and price points. this DIY will work for all brands! --
-- Also, i have chosen to use aftermarket SS braided lines and all new fittings. owever, stock lines/fittings will work with the LS400 calipers. --
TOOLS:
-breaker bar, or air
-ratchet
-sockets: 14, 17 (deep or small extension)
-allen socket: 10
-wrenches: 10, 13, 15, 18,
(may differ depending on the lines and hard ware you use)
-oil pan
-brake bleeder
-cut-off tool
-file (optional)
-pliers
-rubber mallet
-a press: decent sized hammer and deep socket works too, etc...
-coilover wrenches (optional)
-jack and jack stands
-lift
Once your car is up on the lift OR the front end is jacked up, on stands, and wheels are off...LET'S BEGIN!
Using Stock lines:
- remove the banjo bolt from the stock caliper lines on the caliper only.
- and position it out of your way during the install
Using aftermarket lines:
- Disconnect brake line from hard line using the 10 wrench, dont strip it, it may be a tad hard to break loose.
- pull the clip that is holding the line in position
- you can leave the other end of the line (the banjo bolt/fitting) attached to the caliper
Caliper/Rotor Removal
Remove stock caliper by removing the two 17 bolts that hold it on from behind.
Remove stock rotor using either a rubber mallet or threading a bolt into the small hole near the center of the rotor to break the rotor loose, if it does not just pull right off.
RCA spacer install
Remove the two 17 bolts on the bottom behind the hub that are facing upward, where we will install the FIGS spacer!
with both bolts out, insert spacer...it will only go in one way. and reassemble using the longer bolts supplied by FIGS with the 10 allen socket:
Fully reassembled and re-tightened. Torque to 90 ft/lbs.
The spacer will also lower the front of the vehicle 1" so remember to raise your coilovers to compensate for the difference. this may be a good time to do that. (this may not apply to you if you do not have an adjustable suspension set up)
Dust Shield
Cut back dust shield, top and bottom, to clear the rotor. File edges (optional):
TOP:
BOTTOM:
DUST SHIELD FINISHED:
Place rotor on hub, secure with two lug nuts, and check for any rubbing. you may have to bend in or lightly hammer out the small divit in the center on the bottom of the dust shield and bend back the edges/corners of the dust shield using a pair of pliers for additional clearance. once all is clear, remove rotor.
Install the FIGS Caliper Adapters into the calipers. these are tapered and will only go in one way! however, they must be installed so that the holes are on the outside/farthest apart, and pressed in.
Install caliper with the two 17 bolts and 17 socket and ratchet to double check clearance and fitment, then remove.
Install the adapter onto the hard line using the 10 and 15, then secure with pin. install banjo fitting and tighten onto caliper using the 14 socket.
Install rotor and temporarily secure with 2 lug nuts. install caliper using the two 17 bolts and 17 socket and ratchet. tighten until snug, once again torque specs unknown, however they are not critical. just make sure they are tight!
Install brake line onto the banjo fitting with the 13 wrench, and then to the hard line adapter using the 13 and 15 wrench.
AND YOU ARE DONE WITH THE LS400 CALIPER SWAP!
Remember you still must bleed your brakes, reinstall your wheels, and lower your car from the jacks before you can hit the road! also follow the guidelines for proper rotor/pad break in.
+ 2JZ-GTE IS300 +
stirlingw is offline
post #2 of 52 (permalink) Old 01-21-2011, 11:31 PM
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Torque RCA bolts to 90ft-lbs
when aligning the adapter inserts, I suggest that you do this loosely on the vehicle to position the adapters such that the caliper looks hubcentric. This is just getting the adapter aligned and starting on its taper so that the knuling is grabbing. Then when you remove the caliper, it should be aligned to press in. A shop press is really the best way to do it and make sure that no powdercoating or anything else is in these holes, other wise the adapters will have a hard time going in...and you make damange them..and you may call me asking me why they are so hard to press in
Other than that, great write up. Glad you finally got around to doing this and DIY'ing it
As an aside, what kind of front sway do you have there?
Fig is offline
post #3 of 52 (permalink) Old 01-21-2011, 11:51 PM
well done with the writeup!!
2002 GGP IS300 5MT w/ LSD
shenmecar is offline
post #4 of 52 (permalink) Old 01-22-2011, 12:40 PM Thread Starter
yeah, thats what i did at first and its just a tad tricky because the bolts arent quite long enough to reach the threads on the adapters. but they went it fairly smoothly, and worked out great!
actually, im not sure what sways they are...came on the car and dont have nay tags or name on them. i thought they were stock for the longest time lol
+ 2JZ-GTE IS300 +
post #5 of 52 (permalink) Old 01-22-2011, 07:07 PM
Do you need new brake lines? Or is it possible to use the OEM lines?
'01 OB IS300 E-Shift (mkIII Supra LSD)
FUJITSUBO / Leon Hardiritt / Megan / VERSION:SELECT / TRD(replica) / AC Schnitzer / SPC / ICHIBA
eye ess is offline
post #6 of 52 (permalink) Old 01-22-2011, 10:08 PM
OEM lines will work.
Nice write up, I did this install too. Hardest part was getting the stock calipers off LOL whats the silver square piece on the back of the caliper? I dont have that on mine
brettdotcom14 is offline
post #7 of 52 (permalink) Old 01-22-2011, 11:11 PM Thread Starter
thats just the banjo fitting for the brake lines...i didnt know the stock lines would work. thats good to know though, thanks!
+ 2JZ-GTE IS300 +
post #8 of 52 (permalink) Old 01-24-2011, 12:50 PM
Nice write up Sir!
04 ricer is offline
post #9 of 52 (permalink) Old 02-04-2011, 08:39 PM
Will the brakes clear is300 rims...
2001 IS300 2jzgte vvti (Airsto Mines ecu)
suspectis300 is offline
post #10 of 52 (permalink) Old 02-04-2011, 09:32 PM
Is that a IS rotor or LS rotor? Nice write up BTW.
05 BO is300 Tein... bought and sold in a month...lol. The game is not the same
MeVersusThem
kraven9 is offline
post #11 of 52 (permalink) Old 02-05-2011, 12:30 PM
^^Kev, I think that these are LS rotors.
'02 MSM IS300 E-Shift
TTE / Figs / Work Varianza T1s / Hawk / K&N / Greddy / Tokico / TRD / Falken / Dropzone / Kenwood
sugzz is offline
post #12 of 52 (permalink) Old 02-05-2011, 12:33 PM Thread Starter
yeah, LS rotors.
i dont believe these clear stock wheels, not 100% though
+ 2JZ-GTE IS300 +
post #13 of 52 (permalink) Old 02-05-2011, 05:34 PM
Originally Posted by sugzz View Post
^^Kev, I think that the LS rotor.
Thanks.
Originally Posted by stirlingw View Post
yeah, LS rotors.
Thanks. It will probably clear with a 5mm spacer, like the supra brakes.
MeVersusThem
kraven9 is offline
post #14 of 52 (permalink) Old 02-06-2011, 11:43 AM Thread Starter
i have a stock wheel actually, so next time i have em off i can check the clearance
+ 2JZ-GTE IS300 +
post #15 of 52 (permalink) Old 02-09-2011, 09:29 AM
Man I can't believe I missed this thread.
Time to get my calipers back from Fig, and order the TT and RCA adapters (sold the figs TT adapters awhile ago, doh!)
Will the stock IS300 braided brake lines work? I already have some Stoptechs on there.
Moderator Old School.
DonCorleone is offline
