Seshween's 2JZGTE VVTi Single Turbo w/AR5 IS300 Build - Lexus IS Forum
Curran
 4Likes
  • 1 Post By Seshween
  • 2 Post By Seshween
post #1 of 15 (permalink) Old 08-24-2016, 03:49 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
Thumbs Up Seshween's 2JZGTE VVTi Single Turbo w/AR5 IS300 Build
What's up guys !
New to the is300 community and thought I'd share my experiences with this build. I come from a Nissan/Infiniti background but have always loved Toyota/Lexus as well. I've owned multiple 240s with numorous different set-ups, and have been daily driving a Y33 q45 for 4 years. Always was a dream to have a IS300 as a kid and the opportunity presented itself a couple months ago when I acquired this one. '02 auto big bird yellow lol I heard the yellow ones are rare but not my style. It will end up being black.
I've done extensive online research on what it'll take to achieve this swap ( thanks to member "Curran" ) and others that have put R&D time into this beautiful chassis. Now for pictures of the car and parts I've already acquired to get a head start ! Thank you for reading and I hope you enjoy 👍
Here's my daily
Here's the project - '02 auto with black interior
2JZGTE VVTi from an Aristo - purchased from 'JDM California'
Pulled the twins
Future Fab ceramic coated v-band manifold
R154 external slave set up pieces for the AR5
JZX110 shifter and jacket with breather
5 speed pedal set with master cylinder
Single turbo AN oil lines, Status Leguna carbon Kevlar seat, Vertex steering wheel, Greddy intercooler
Have the trans on the way as well ! Will be updating when teardown starts in a week or so. Still looking at turbo set ups and a couple clutch set ups but have my eyes on a Garret GTX3582R with tial v-band housing and drift motion oem Aisin upgraded pressure plate with the six puck disk.
Thank you again ! Have a good day
whatthe likes this.
post #2 of 15 (permalink) Old 08-24-2016, 07:22 PM
Quoted: 147 Post(s)
Looks like you'll have your hands full for a bit. Welcome. Way to dive in bro.
VEHEMENCE is offline
post #3 of 15 (permalink) Old 08-24-2016, 08:26 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
TRUE ! Lol thanks man.
post #4 of 15 (permalink) Old 08-24-2016, 08:27 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
Couple more parts showed up today - R154 clutch fork and flywheel inspection plates
post #5 of 15 (permalink) Old 08-27-2016, 11:18 AM
Quoted: 10 Post(s)
welcome. this is off to a great start already.
01 Solar Yellow IS300
siboosted is offline
post #6 of 15 (permalink) Old 09-01-2016, 10:00 AM
I am parting out my 02 is300 turbo may have a bunch of things that would be useful to you located in huntington wv pm me if interested
xI OxY Ix is offline
post #7 of 15 (permalink) Old 09-12-2016, 10:00 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
My account got deactivated for a while but i guess were good to go now. Got the engine out of the car, have everything pulled from the engine bay, have the is300 engine harness (GE) transferred over to the GTE - * NOTE : the only plug harness i had to extend was the water temp sender (used the GE sender). Everything else was able to extend with unlooming. Also not a fan of ABS brakes - so i deleted the abs module and ran custom hard lines, not worried about any abs, traction, or check engine lights, Im registering the vehicle where smog is exempt. Purchased AEM FIC with the plug and play harness, AEM tru boost gauge and controller, and AEM wideband. PICTURES:
Ran the harness under the intake manifold
Rear brake line tee for the ABS delete
AEM tru boost and wideband
AEM FIC - I know its not the best, but will work until im ready to upgrade to a standalone
post #8 of 15 (permalink) Old 09-30-2016, 04:18 PM
thats going to be a sweet set up with the GT3582. perfect turbo for a VVTi 2j. what are you going to use for fuel?
scottiedawg66 is offline
post #9 of 15 (permalink) Old 10-07-2016, 02:32 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
Thanks man ! Planning on running 91 pump gas.
post #10 of 15 (permalink) Old 10-07-2016, 02:43 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
Update ! Pressure washed the engine bay and scuffed for paint.
AR5 trans showed up, Bell housing, Tomei fuel pressure regulator (Large Diaphram) with Tomei gauge, and the AN lines I'm using for the FPR too. Finished the ABS delete with hard lines, and drilled holes for the master cylinder (unfortunately someone had already drilled a couple holes where the clutch master goes to run an amplifier power cord )
siboosted and abj like this.
post #11 of 15 (permalink) Old 10-08-2016, 09:09 AM
Quoted: 10 Post(s)
I am planning something like this in future so looking forward to following the progress of your build.
post #12 of 15 (permalink) Old 02-21-2017, 06:30 PM
Seshween
Guest
Posts: n/a
Quoted: Post(s)
Account got deactivated again, here are some updates on the build...
Garrett GTX3582R came in , sold T3 hot side, Tial V-band .82 ar on the way
Assembled AR5 Trans and the external slave set-up
Finished upper control arm boxes and Raysfactory stitch welded engine bay
Painted engine bay 202 black and painted subframe, replaced lower control arm bushings, tension rod bushings, ball joints and tie rod ends
Installed Brake booster, brake master cylinder and clutch master
Dropped the motor in and mocked up the manifold
Heres how it sits now
Ended up selling the AEM fic and tru boost... will be going with Pro EFI 48
abj likes this.
post #13 of 15 (permalink) Old 02-22-2017, 12:57 PM
This is a sweet build, Could you tell me some of the benefits/why you choose to use the AR5 transmission? I am not too familiar with that swap.
shiftdrift06 is offline
post #14 of 15 (permalink) Old 02-22-2017, 05:36 PM
Quoted: 20 Post(s)
It's a cheap alternative to the R154. It will shift better than any R154 as well and not as noisy.
'03 IS300 SD TCM 5-SPD LSD
tonynca is offline
post #15 of 15 (permalink) Old 03-24-2017, 07:19 PM
Any updates to this thread?? Looks like a cool build.
ESSENCE GARAGE
i.rashid is offline
