LexusSpeed01 1JZGTE VVTI Tomei Build **Updated** **Dyno Results** 6-25-15 - Page 6 - Lexus IS Forum
 5Likes
post #76 of 92 (permalink) Old 06-30-2015, 08:02 AM Thread Starter
Quoted: 9 Post(s)
Originally Posted by The Nuke View Post
Couple of quick questions...
1) How much is the manifold supposed to improve air flow? I've heard the stock 1j manifold is pretty restrictive? Does the Tomei mani look somewhat OEM?
2) How does the Tomei turbo upgrade feel vs stock? Obviously better, but how is it for the street? How's spool? etc.
2a.) Does the Tomei turbo upgrade look OEM? I'm torn between the Tomei or just sending the stock turbo somewhere for a 60-1 upgrade when the time comes. I want a clean, factory-looking turbo setup.. kinda sleeper-esque.
1. This information I don't have access to. I could ask and probably find out some specs for you. Yes it looks oem just its black and pretty.
2. My stock turbo was horrible wouldn't hold boost and was leaking. I was also tuned by a POS tuner that later found out why it felt like crap. The spool comes in slightly later but when it kicks in it is hard pull at power it makes.
3. As far as stock look unless I tell someone they don't have a clue its not the stock one.
The Nuke likes this.
1992 Toyota Celica GT 5speed 3sgte swapped - SOLD
1992 Toyota Celica All-Trac - SOLD
1997 Civic EX Turbo 300whp 295tq - SOLD
2001 IS300 Auto - SOLD
2010 Subaru WRX Stage 3 328awhp - 387awtq - SOLD
2003 IS300 Pearl White 1jzgte VVTi - R154 - LSD - Tomei M8280 - 22psi - 418rwhp - 380rwtq
www.radfordracing.com
LexusSpeed01 is offline
post #77 of 92 (permalink) Old 06-30-2015, 08:41 AM
Quoted: 224 Post(s)
Sounds like a winner. I bet it's nice to have a reliable steel wheel instead of the ceramic...
Luke 6:41-42.
The Nuke is offline
post #78 of 92 (permalink) Old 08-19-2015, 02:51 PM
Quoted: 18 Post(s)
Great build. Nice to see your starting to enjoy it!
03 5SP LSD LTHR GPS TV CF MODELLISTA
[AEMv2][TT's] [WISECO] [264] [MCR154] [DSS] [GT35R] [FIC775cc] [SRT]
/ BP Short Shifter l Suede Headliner\
DsouthMia07 is offline
post #79 of 92 (permalink) Old 09-06-2015, 10:48 AM Thread Starter
Quoted: 9 Post(s)
I would start enjoying it more if it would stop breaking camshafts is really starting to tick me off. I am dropping it off this week at TES performance to check the head for issues causing it. I am clueless what to look for at this point valve lash is correct.
I also got the drag radials powered to match the other wheels finally.
post #80 of 92 (permalink) Old 11-20-2015, 10:47 PM Thread Starter
Quoted: 9 Post(s)
The car is under taking some new measures. I purchased a used 1jzgte vvti head off ebay and having it rebuilt to see if this cam issue is something with this head. I am also pulling the motor and prepping for more boost
post #81 of 92 (permalink) Old 08-15-2016, 10:12 AM Thread Starter
Quoted: 9 Post(s)
Well a lot has changed and most of the updates have been done on my blog. The car is running again but I am still hearing the tapping noise from the VVTI gear area where it keeps breaking. At this point it has a completely rebuilt head.
Visit the Site:
post #82 of 92 (permalink) Old 09-16-2016, 02:39 PM
I just read thought your build thread, makes me want to sell my frs just to do 1jz is300 swap
'13 FRS Series 10 6MT- l PBM Coilovers l Cusco LCA l Nameless Muffler l Takeda Intake l
Looking for IS300 soon...
'04 BSM (8N6) IS300 5MT LSD - 1/19/13- Sold 2014
RUBBISH is offline
post #83 of 92 (permalink) Old 09-30-2016, 10:10 AM Thread Starter
Quoted: 9 Post(s)
At this point i am about to rip everything Tomei off and sell. The cam shaft has broken again just last night. However I have managed to find someone else with the same issue at this point.
To Tomei Cams or Not to Tomei Cams - Dyno and Tuning - JZX World Forums
post #84 of 92 (permalink) Old 10-14-2016, 12:46 AM
Quoted: 144 Post(s)
Definitely way too soon to see another cam failure like that.
'If' you try another one, I would sand smooth any edges and rough casting around that hole... or at least recommend that to them. Putting it under the microscope one could tell for sure, but any rough spots around a weak spot like that hole typically create a great place for cracks to start on 'brittle' materials.
I had one car where the exhaust cam snapped on me. The casting on it was rougher than others I had seen and failed where there was a hole drilled through the cam similar to yours. Where the failure started was for sure one of the imperfections in my case.
whatthe is offline
post #85 of 92 (permalink) Old 10-14-2016, 11:34 AM
Awesome work man, I wish I had the time, money and patience to do that!
ceej989 is offline
post #86 of 92 (permalink) Old 11-12-2016, 08:30 AM Thread Starter
Quoted: 9 Post(s)
Well I called Tomei and told them that i was tired of the cam breaking and switching back to stock or different brand. Well after this they said they would get me a HKS intake cam. Well that came in and what a hell of difference in quality from there's. However is it something I am doing installing that is causing them to break? I am following the 2jz service manual when installing cause the 1jz manual is none existent. I always cleaned the other ones with break cleaner really good then coated it with oil. But i am wondering right there where the VVTI solenoid sits if i am putting the silicone in wrong places cause it is different than the 2jz pictures and if the torque specs are different and I am to tight right there.
Thanks,
Dereck
post #87 of 92 (permalink) Old 11-13-2016, 06:29 AM
I have also heard tomei poncams have failed.
Ahmerm is offline
post #88 of 92 (permalink) Old 02-26-2017, 10:55 AM
This is the 3rd person I have heard of breaking the cams.
Any updates with the HKS cams?
ESSENCE GARAGE
i.rashid is offline
post #89 of 92 (permalink) Old 03-04-2017, 08:20 AM Thread Starter
Quoted: 9 Post(s)
The HKS cam is in just finished this couple days ago. I guess time will tell again if we run into issues. The car seems to make the exact same tapping noise right where the vvti gear is.
post #90 of 92 (permalink) Old 03-05-2017, 05:36 AM
1jzgte build
Hi LexusSpeed01
i built my lexus is200 with a 1jzgte vvti and i'm running a standard turbo and cams and i asked my tuner and he told me that he disabled the vvti cause, he told me that it will snap the cams if they enable it only the original ecu can run it, so we disconnected the solenoid and my car runs perfectly so maybe that might help you. My car is running a spitronics standalone and its a South African made ecu, Aem is a far better ecu but i would say to get the vvti disabled and see if that helps the hks cams are perfect for it.
Lexus=1jzgte is offline
