Dyno Charts... - Page 2 - Lexus IS Forum
 4Likes
post #16 of 25 (permalink) Old 06-30-2012, 02:41 PM
that would mean that you only lost 10%, that's pretty impressive!
Jerm__ is offline
post #17 of 25 (permalink) Old 06-30-2012, 03:43 PM
**my old tune at 7psi , i dont have my current dyno sheet**
Motor type: 2JZ GE with TT HG
Power: 326
Torque: 332
Tuner/Where it was tuned: Ramey Built in Virginia Beach, VA
graph
01' IS300 2JZ-GTE Aristo Stock Twins (for now)~ Current
01' MSM IS300 NA-T 380whp@11psi~ Sold
joney3jonez is offline
post #18 of 25 (permalink) Old 10-18-2012, 10:26 PM
Quoted: 9 Post(s)
I figure my new setup is worth a post in here
Engine: 2JZ-GE, Wiseco pistons ~9.5CR, GTE rods, GTE HG, Ported head/manifolds, BC 264 cams, Crower valvesprings/retainers, Titan cam gear.
Power: 520whp @ 7720 rpm
Torque: 368 ft lbs @ 5450 rpm
Turbo: GT4088R 0.95 AR
Boost: 16psi
Tuner: Dynamotorsports (Toronto, Canada)
520 whp / 368 lbft
Build thread: http://my.is/forums/f219/gt40r-is300...eo-too-437118/
Dyno Video!!
exist3nce is offline
post #19 of 25 (permalink) Old 10-21-2012, 04:35 PM
Motor type: 2002 ls1, mild cam, rear mount china made t76, e85
Power: 562
Torque: 525
Tuner/Where it was tuned: hptuners, self tuned on the street
another ls1 swap work log
Name:	6psi vs 11psi.jpg
2002 is300. cam only ls1, 4l60e, ~3200 stall
12.67@107 NA, 11.22@120 w 125shot. 1.55 60', 340rwhp na, 440rwhp n02
now with rear mount china t76 turbo, 560rwhp, no new track time.
parish8 is offline
post #20 of 25 (permalink) Old 10-27-2013, 12:50 AM
2jz-ge Fully Built pte 6766
706rwhp @ 22psi
501rwtq
Tuner - Don't want to talk about it/ Next tune will be Excessive motor Sports in Sioux Falls, SD (will shoot for 1000rwhp)
Build Thread- http://my.is/forums/f219/my-pursuit-...0-25-a-439657/
2002 L-Tuned Stage II (Build in progress!!!)
showexc419 is offline
post #21 of 25 (permalink) Old 05-06-2014, 09:01 PM
Bumping this thread because I am updating my setup.
PT6766 with .96ar, 3.0 10:1 compression ,CP pistons, Carillo H Beam Rods, Carr Rod bolts, ACL bearings, ARP studs, BC VVTI 264 cams, BC springs & retainers, ID2000's, etc...
Power = 771 @ 25lbs on 76% e85
Torque = 635
Tuner/Where it was tuned: Alpha / Induction Performance
c1L likes this.
ezzejacobs is offline
post #22 of 25 (permalink) Old 05-23-2014, 08:46 AM
Quoted: 9 Post(s)
Updated setup - 615whp
Dyno worthy update here..
Engine: 2JZ-GE, Wiseco pistons ~9.5CR, GTE rods, GTE HG, Ported head/manifolds, BC 264 cams, Crower valvesprings/retainers, Titan cam gear, Varex 3.5"
Transmission: Stock R154, TRD 3.91 LSD, Custom modified OEM driveshaft
Power: 615whp @ 8200 rpm
Torque: 400 lbft @ 5300 rpm
Fuel: Pump 94 oct with water/meth injection
Boost: 21psi
Build thread: http://my.is/forums/f219/gt40r-is300...200rpm-437118/
615 whp / 400 lbft
Dyno Video!!
post #23 of 25 (permalink) Old 06-29-2014, 12:04 PM
Specs: 2JZ 3.0L, -GE head (not ported), -GE block, CP pistons, Carillo Conrods, ARP head studs, ARP main studs, Supertech valves-valve springs-retainers, BC 272 camshafts, ACL bearings
Precision PTH6766 DBB, ID1000, 2x Walbro 255lph
Result: 676BHP & 689NM (508lb-ft TQ) @ 1,6bar (23PSI) Boost
on ROZ100 pump fuel
Video Link:
https://www.youtube.com/watch?v=DgsQSdhP92Q
Click Link to... .
My Project II
RoadRash is offline
post #24 of 25 (permalink) Old 09-20-2015, 04:36 AM
Quoted: 16 Post(s)
Going for more when the new ignition wires and exhaust are done.
Pretty cool to see 130rwhp increase from removing the mid-pipe!
7675+pro-EFI 40lbs on last pull
28psi other two pulls
David
Name:	is300 dynos.jpg
ezzejacobs likes this.
greasepower is offline
post #25 of 25 (permalink) Old 01-03-2016, 06:39 PM
1102RWHP 836TQ
Tuned at SP in chicago.
ID:	89810   Click image for larger version
Name:	is dyno sp.jpg
ezzejacobs and c1L like this.
03 IS300 GGP SD -- 2JZilla
VisBits is offline
