Cil's 02 IS300 Build *MK4DR* - Page 12 - Lexus IS Forum
c1L
 128Likes
post #166 of 177 (permalink) Old 03-14-2017, 11:52 AM
Originally Posted by c1L View Post
Stock 3.7 LSD for now. will not be beating on the car on high boost until i get a new rear end put in. Still debating what to go with.
Yeah Im trying to find out what to do with my build,... frs/2jz with m85 or???
What are the options for a new rear end? is there a way to build the m85 with stronger gears?
rob 2fast4u is offline
post #167 of 177 (permalink) Old 03-14-2017, 01:45 PM Thread Starter
c1L
Quoted: 49 Post(s)
The stock diff or BRZ are out of the question if your putting constant abuse on it after 700hp i feel. Im looking into a Supra Diff with a real LSD (Kaaz/OSG) or a Ford 8.8 conversion. If the stock torsen diff blows up it can send your car out of control very easily.
ProEFI / V160 IS300 742rwhp Alpha Tuned
Spring Setup: 10:1 GTE Motor, V160, Proefi128, S369SXE...
My Build Thread
ig - cillyotta
RIP MIKEY #msperformance
c1L is offline
post #168 of 177 (permalink) Old 03-14-2017, 03:17 PM
Yeah the stock frs diff won't cut it especially with the 4.x gearing I need it atleast in the 3.7 or below that since I will be using a cd009 trans. but I'm just questioning the m85 and its strength... I just wish you could rebuild an m85 with stronger components. There is a company that makes a kit to put a 8.8 in the frs subframe but they want 7,000$ for it
post #169 of 177 (permalink) Old 03-14-2017, 05:39 PM
Quoted: 64 Post(s)
Just buy a 3.7 gear. Build the setup you need.
post #170 of 177 (permalink) Old 03-14-2017, 05:51 PM
Cherisher
blkdout's Avatar
Quoted: 580 Post(s)
Transmission and engine come first when building for strength. Rear end last. It's the strongest component in the drivetrain. Even the axles will hold 1,000HP.
c1L likes this.
-Hiral
blkdout is offline
post #171 of 177 (permalink) Old 03-14-2017, 06:12 PM Thread Starter
c1L
Quoted: 49 Post(s)
Exactly i just wont launch the car on high boost if i want it to last. Ill take the plunge one day and buy the FRS 8.8 Kit from Full blown when its time.
My Build Thread
ig - cillyotta
c1L is offline
post #172 of 177 (permalink) Old 03-14-2017, 08:25 PM
Cherisher
blkdout's Avatar
Quoted: 580 Post(s)
I bought the V160 combo'd with a Supra rear. I sent both to Jack's for a rebuild but they reported case damage on the rear so I returned it. It was $900. I would buy one again and mod the subframe to fit it but I'm happy with the 3.5 ratio for now.
The GS diff is another option for gearing the Getrag to 3.2ish if I remember correctly.
-Hiral
blkdout is offline
post #173 of 177 (permalink) Old 03-15-2017, 06:09 AM Thread Starter
c1L
Quoted: 49 Post(s)
Yes if i cant find a big diff (220mm) ill use a GS diff which are cheap and readily available. If i destroy my ring and pinion ill def grab a 3.5 ring until then. How do you like it so far?
My Build Thread
ig - cillyotta
c1L is offline
post #174 of 177 (permalink) Old 03-16-2017, 07:30 AM
Cherisher
blkdout's Avatar
Quoted: 580 Post(s)
So far so good. I don't have anything to compare it to but I don't find the gearing to be too short. Quite nice actually.
I had to do something with the 3.9 ring and pinion and this turned out to be a cheaper and relatively easy option.
c1L likes this.
-Hiral
blkdout is offline
post #175 of 177 (permalink) Old 03-20-2017, 06:41 AM Thread Starter
c1L
Quoted: 49 Post(s)
Intercooler is mounted and piping is done. Vanjen all around! Waiting for the exhaust to be done and then its time for startup
blkdout likes this.
My Build Thread
ig - cillyotta
c1L is offline
post #176 of 177 (permalink) Old 03-20-2017, 08:53 AM
Quoted: 40 Post(s)
Interesting placement of your Pro-EFI. I'm assuming you installed it there so a cop wouldn't be able to find it?
Piggity is offline
post #177 of 177 (permalink) Old 03-20-2017, 08:55 AM Thread Starter
c1L
Quoted: 49 Post(s)
That was as far as my harness would go, wish i was able to mount it inside the car.
My Build Thread
ig - cillyotta
c1L is offline
