Another IS300T thread. *v161/BW S366 pg.9* - Page 2 - Lexus IS Forum
post #16 of 136 (permalink) Old 11-04-2011, 10:27 AM Thread Starter
Well I never did any homework in highschool so might as well start sometime right. I'll even be goin for the extra credit with this build.
2003 Is300 GGP
lexusis3double0 is offline
post #17 of 136 (permalink) Old 11-04-2011, 11:15 AM
your lucky your dad has a machine shop. Should save you some coin. Keep us updated man!
Whats the wheel size/offset/tires?
Jerm__ is offline
post #18 of 136 (permalink) Old 11-08-2011, 03:57 AM Thread Starter
well I got the motor today. and thats about it. was my daughters birthday so as soon as it came in I unwrapped coverd the inlets and put it in corner and left all in all looks in pretty good shape.
from the quick look I got to take everything was just cut. wires, hoses, even the exhaust dp was just plasma cut off. they took zero extra time to remove this engine. both motor mounts are missing from the rubber piece down, looks like they just cut everything and hooked up the motor and just lifted till the mounts tore off. but other than that everythings there and in good looking shape.
getting it out of the truck.
MY NEW TWINS!!!!
intake side
EDIT:scratched this last part, motor is 100% 98+ vvti. misread something somewhere
2003 Is300 GGP
Last edited by lexusis3double0; 11-08-2011 at 09:42 AM. Reason: def a 98+ thanks all
post #19 of 136 (permalink) Old 11-08-2011, 05:21 AM
That is not a 94+ motor, that's a 98+ - they didn't have VVTI GTE's before 98. valve cover shows that its vvti. You'll be fine.
I would HIGHLY recommend going single off the bat. The twins are going to get boring quick, and when you want to remove them - HA! Good luck. They are hard enough while on a motor stand.
Also, take off the head and check the internals. I made the mistake of only compression testing it - and now I'm in deep for a rebuild.
If you need any advice or information that you can't immediatley find in the Go Faster or DIYs - shoot me a PM or email mike[dot]autooptics[at]gmail[dot]com
fiveohfour is offline
post #20 of 136 (permalink) Old 11-08-2011, 06:56 AM
Sounds like you're going a route very similar to what I'm planning
Japanese motors that I've seen always come like that (harnesses, hoses, etc simply chopped). It saves TONS of time at the scrap yard, and time = $$$
Lookin forward to updates!
1995 Everette Green Eclipse RS(T) (sold)
1995 Everette Green Eclipse GSX (sold)
1995 Everette Green Eclipse GST (sold)
2004 Black Neon SRT-4 (totaled)
2001 Black Onyx IS300
wiggyx is offline
post #21 of 136 (permalink) Old 11-08-2011, 08:02 AM
Quoted: 18 Post(s)
Very nice bro! I am excited for you. I am just building my GE motor but maybe a few years later Ill sell my set up and go GTE.
DsouthMia07 is offline
post #22 of 136 (permalink) Old 11-08-2011, 09:10 AM
Bezik777's Avatar
Quoted: 35 Post(s)
Hope everything checks out with the engine (it is 98+), do to that uncertainty is the main reason I'm just building my GE block with GTE internals just as good if not better then GTE , GE head flows better also ...
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #23 of 136 (permalink) Old 11-08-2011, 09:39 AM Thread Starter
ok I def misread something somewhere. My head was spinning when I saw that and I was reading up after. so I have reeducated myself and all vvti motors are 98+, turbos are only ceramic in non vvti pre 98. thanks. made myself look stupid, for all followers... get used to it. lol.... I swear I know what im doing about 80%. The rest Ill have a staring contest with the motor till I figure it out. and the rest of the rest, i have you guys for.
2003 Is300 GGP
post #24 of 136 (permalink) Old 11-08-2011, 09:47 AM Thread Starter
+rep to those that helped out (except 504 gadda spread the love).
in about an hour im going to go inspect the head and if I have time the turbo&intake side.
but first I have to get off the tranny and get it on a stand.
wish me luck
first set of parts I ordered will be here sometime next week!!!
2003 Is300 GGP
post #25 of 136 (permalink) Old 11-08-2011, 10:41 AM
wish me luck
Hey no worries, there's a lot going on with these swaps - its easy to get buried in the information. Lord knows I had several posts in the Go Faster as I was doing the swap... little things like vacuum ports, or "whats this?" or "whats that?". No problem man - this swap is still not very common in regards to Supra NA swaps.... so we're still treading new ground everyday with these things.
Oh, and no worries - I do need to spread the rep around. I'm just here for the moral support, I can do without digital rep if needed
As for the front main seals (cam and crank) it will be the same part number as the GE. GTE=GE front seals.
post #26 of 136 (permalink) Old 11-08-2011, 11:24 AM
isn't this a common misconception. wasn't it proved with charts that the GTE is a slightly better flowing head?
Jerm__ is offline
post #27 of 136 (permalink) Old 11-08-2011, 11:43 AM
IS_BoostByPsi's Avatar
Sweet! Looks like mine! Dont worry what everyone says, the twins are fun! I spanked the shit out of faster cars with the twins because I had 0 lag time for spool up. Just keep em around 17psi and youll be fine.
LMK if you want to sell your old GE motor. PM Me!
IS_BoostByPsi is offline
post #28 of 136 (permalink) Old 11-08-2011, 11:44 AM
They both flow well. But for boosting purposes the GTE VVTi head has been shown to be beneficial to be kept with the gte block.
Both ge head and gte head on a gte block make great power.
Its all about volumetric efficiency, and both heads are usable.
post #29 of 136 (permalink) Old 11-08-2011, 12:38 PM
That looks beautiful. Happy Birthday to your daughter also. Hopefully you can get this in soon! Excited to see how this build goes, especially with the custom pod. I'm trying to get ideas on how to make one myself when the time comes.
mynameisgoose is offline
post #30 of 136 (permalink) Old 11-08-2011, 12:47 PM Thread Starter
I'm keeping them for three reasons. And they are
1. I paid for and own them(even tho I only need a manifold for a single conversion because I have kit for the ge. But I wanna sell that... I think)
2. Stock 5speed ( less lag and I know it goes agains all holey things to say this but to keep power DOWN. Lol)
3. TWIN TURBO. Nuf said. Lol.
And about the GE. It's not even old. It's only got 75k on it. I wanna keep it as a spare but I allready have soooo many parts in my old mans garage I think hell kill me if I add a motor to the pile. If he makes me get rid of it it's all yours. I'll know by the time the swaps up and running for sure. I'll pm you when I know.
2003 Is300 GGP
