New! Tein Street Advance Coilovers - Lexus IS Forum
post #1 of 1 (permalink) Old 12-28-2011, 12:32 PM Thread Starter
Supporting Vendor
Dezod Motorsports's Avatar
Quoted: 21 Post(s)
Near equivalent to the Super Streets at less cost.
Additional Features
• Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• 16-way Damping adjustment with over 200% increase in damping force change.*
• Ride Height adjustable via spring seat
• Powder coated damper body
• Non-welded ZT coated Adjustment Tube
• Full-Length Dust Boots
• 1-piece Aluminum Spring Seat with Delrin Thrust Washer
• Available for Overhaul
• 1-year Manufacturers Defect Warranty
*over comparable Super street damper, based on damping dyno graph data. Increase in damping force over comparable Super Street damper may vary for specific vehicle applications.
Features of the new Street Advance dampers include:
*16-way damping adjustment (compression & rebound together) using our new Advance Needle design, enabling a wider damping force adjustment range. An increase of over 200% from the Super Street dampers!
*New base valve design offering a longer service life.
* ZT coating (inner and outer) on the non-welded threaded tube for improved rust protection and smooth ride height adjustment.
*Newly developed Blast Finish + 2-layer/1-bake Powercoat for improved protection from extreme weather conditions.
*New Spring Seat design with a low-friction Delrin Thrust Washer, making height adjustment change easier.
Dezod Motorsports. Tein Street Advance Coilover-IS300 01-05 (EDFC compatible part # EDK05-12120)
Dezod Motorsports is offline
