Dezod Motorsports AEM EMS - Lexus IS Forum
Closed Thread
post #1 of 88 (permalink) Old 12-10-2008, 08:18 AM Thread Starter
Supporting Vendor
Dezod Motorsports's Avatar
Quoted: 21 Post(s)
As I am sure plenty of you know, and plenty already have we do offer a FULL Plug-N-Play AEM EMS for the application. The unit comes with the following components:
(1) Modified AEM EMS box
(1) Plug-and-play harness (6 ft in length)
(1) AEM Software disc
(1) Start up 1.19 CAL (Dezod made)
(1) 3 or 5 BAR MAP sensor (Choice to user)
The system features:
* Plug-N-Play technology only Dezod can offer
* V1.19 Dezod Start-up Calibration
* Free Software Upgrades from AEM
* Uses all of the factory sensors (except MAF)
* Onboard 512MB datalogger
* 16/32 Hybrid Speed Processor
* 16 General Purpose Outputs
* 7 Definable Switch Inputs
* VVT-i Control
* Anti-Lag Turbo Control (2 Styles!)
* 2 Step Launch Control (perfect launches everytime!)
* Programmable Traction Control
* Can Control Boost (with an electronic solenoid)
* Definable Cut Rev Limiters
* Definable Knock Control
* Fuel Table Automapping
* Closed Loop O2 Sensor Feedback (when used with a wideband)
* Wet & Dry Nitrous Control
* 4 EGT Inputs with Fuel Control
* Individual Cylinder Fuel & Ignition Control
* Can Datalog your Wideband O2 (with 5V analog input)
Pic of the 02-05 harness:
Will work on Autos and 5 speeds. This system retains the stock ECU for all luxuries such as, but not limited to: cruise control, A/C, P/S, ABS etc.
To purchase: Dezod Motorsports Plug-N-Play AEM EMS-IS300 01-05
Dezod Motorsports is offline
post #2 of 88 (permalink) Old 12-10-2008, 08:25 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
post #3 of 88 (permalink) Old 12-10-2008, 10:38 AM
what are these things for?
please help my rep.
big_willay is offline
post #4 of 88 (permalink) Old 12-10-2008, 01:01 PM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Standalone engine management? For 100% control over your engine to tune for optimal performance as needed
post #5 of 88 (permalink) Old 12-10-2008, 03:05 PM
Patriot
Did you guys get the CEL, traction control, o2 sensor simulator and etc... straightened out? Will you be able to pass plug in OBD II emissions tests using the AEM EMS?
'03 SportDesign Onyx IS300 | TRD | JL Audio | Lamborghini Gallardo
'01 Onyx L-Tuned Widebody Turbo IS300 | SRT 460RWHP@18PSI = GONE
'02 Onyx IS300 = SOLD | '01 MSM IS300 = SOLD
'01 Onyx Turbo IS300 | SRT 387RWHP@16PSI = SOLD
My Turbo IS300 Racing *Video* Compilation*
moiz87 is offline
post #6 of 88 (permalink) Old 12-10-2008, 03:57 PM
what he said...i got the traction control light on. yuck!
2002 IS300 BO, 6-Speed
2002 IS300 CW, E-Shift → 5-Speed sold
vroomRollLEX is offline
post #7 of 88 (permalink) Old 12-10-2008, 08:39 PM
is there a PnP AEM EMS for an 01 IS? when i go turbo this is my choice of stand alone.
Im your local smarta$$
leonard_is300 is offline
post #8 of 88 (permalink) Old 12-11-2008, 12:09 AM
yes they do have one for the 01
post #9 of 88 (permalink) Old 12-11-2008, 08:02 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Yes sir, there is one for an 01. Simply elect it in the drop down menu of the item.
CELs, yes there will be one or 2.
Traction control, no need to straighten it out. AEM has one that works better than stock.
OBD2 emissions plug in passing, you will not pass. Sorry.
post #10 of 88 (permalink) Old 12-11-2008, 12:34 PM
how about a group buy??
+ 2JZ-GTE IS300 +
stirlingw is offline
post #11 of 88 (permalink) Old 12-11-2008, 12:57 PM
Planning to get back into the boost game? Third time is the charm...get a 6 speed and stroker kit this time!
With all full standalones, you'll get a P1300 CEL if you remove the stock ignitor from the picture. This is going to be required if you want full timing control, the good news is once you simulate the ignitor traction control is back and the P1300 will never appear again. The post cat O2s can be simulated with an O2 simulator. After that you need 1 working pre cat O2 and the rest is tuning to pass the OBD2 emissions plugin test.
lambchop11078 is offline
post #12 of 88 (permalink) Old 12-11-2008, 01:05 PM
Patriot
Quoted: 20 Post(s)
so any standalone wont fully control timing unless you remove the stock ignitor?
-Adam
bigkahuna2187 is offline
post #13 of 88 (permalink) Old 12-11-2008, 01:17 PM
What I mean by removing the stock ignitor is removing the stock ECU's control of telling the ignitor when to fire the coilpacks. There are ways to implicit control timing by delaying the IGT (ignition trigger) signal to the ignitor i.e. retard timing but you'll never have precise control of timing. To have full precise control of it, you'll need to remove the control from the ECU. When the ECU fires the trigger it expects a response (IGF) back from the ignitor. If it doesn't get the IGF signal then it will register it as a problem thus the P1300.
post #14 of 88 (permalink) Old 12-12-2008, 10:50 AM
Quoted: 24 Post(s)
Very nice looking EMS.
BlackSportD is offline
post #15 of 88 (permalink) Old 12-14-2008, 06:06 PM
Yep! I figured a little less than that out through some trial and error and some reading on here. Mine works just fine! Kick ass item Dezod!!!!!
01 BO IS300 E-Shift-Project is back underway, but I think it will be all motor for now. DAMN EMISSIONS!
Dezod Motorsports came through on the AEM EMS for me...BIG ups fellas!!!
[edited due to content]
One life to live, so little time, so much to do.
djlutchi is offline
Closed Thread
